08-09-2007, 09:23 PM | #1 |
Member#: 101484
International
Vehicle:2002 jdm sti {gt35r} sti blue |
autronic
08-13-2007, 09:03 PM | #2 |
Member#: 67958
Vehicle:MY96 Time Attack and 06 STI daily |
Yes I use the Autronic SM4 on my Subaru and on some customer's cars. I'm a dealer as well as a tuner.
08-14-2007, 09:13 PM | #3 |
Member#: 51047
Vehicle:1999 gc8 RS/sti-ra White |
I am using the plug n play w/ a v4 sti. So far so good.
08-17-2007, 08:57 AM | #4 |
Member#: 49087
RMIC
Vehicle:1998 RST V8 STi swap '05 R6 '95 BMW V8 hotness |
The Autronic is the best standalone on the market bar none you are a retard if you disagree end of thread.
Seriously though. Unless you need all of the extra inputs/outputs of the Motec there is nothing in existence that can touch the Autronic. In the last 6 months using an Autronic system we have: Tuned two open class rally cars (most of the really fast guys in Rally America run the system). Installed it on a pair of civics we built. Both make over 600 wheel on our Dyno Dynamics and drive with the street manners of stock cars. We're currently waiting on a set of cams from Cosworth for an STi that wears a GT40r that runs Autronic. Last year every Subaru that ran the pikes peak hill climb was ran on our Dyno at some point and every one that was fast had an Autronic. I'm starting to horde parts for my new project with my RS. Should be the first Subaru in the 10's with no turbo. It's running an Autronic. |
08-17-2007, 12:55 PM | #5 |
Member#: 66066
Vehicle:04 STi black on sold |
has anyone used SM4 on a 2004 USDM STi.
i know the Plugin ECU page says that the USDM STi is no good. i'm looking to run Anti-Lag for the Auto-X along with a 2 stage limiter and WOT shifting. and can't seem to figure out if i want the Motec M800 or the Autronic SM4. |
08-18-2007, 08:41 PM | #6 |
Member#: 90110
W. Canada
Vehicle:2004 wrx wagon WRB |
Rummor has it that Autronic has a Drive by Wire solution, but one could always switch to drive by cable if your impatiant.
08-18-2007, 09:10 PM | #7 | |
Member#: 67958
08-19-2007, 12:06 AM | #8 |
Member#: 49087
RMIC
The issue with the STi is in the trigger setup. The autronic as it sits needs a cam/crank signal with an even number of pickup points. The US market STi cams only have 3 pickup points. The chips to run odd numbered pickups have been out for a short while... but it's still not a plug and play solution.
Converting to cable throttle bodies is easy. I'm still using my USDM STi manifold with a cable TB. As for a plug and play solution... a little birdie has told me to wait. |
09-03-2007, 03:52 PM | #9 |
Member#: 67958
I've been running my US STi engine with an SM4 for about a week now. Ray figured out why the US setup is different and that was all it took. She fired right up and I've put around 500 miles on it so far.
Some new hardware is coming out as well to add functionality for A/C, TGV's, etc. all of which I'm not using on mine. -Mike |
09-03-2007, 06:10 PM | #10 |
Member#: 101484
International
well guys i have the sm4 in a jdm 02 sti running for awhile now. Its pritty good in my opinion but the car breaths hard at 25psi{the greddy catch can pushing out oil} on our local 90 pump gas yes i live in the Caribbean island {jamaica} at 15psi the car feel fast{but not fast enough} i have the smallest of the gt35s series of turbo with 2.5 bottom half{cp pistons,eagle rods,stock crank, port and polish heads ect} but i don't think i reach no were near 450hp yet so i am just wondering if its the tuning or what
09-05-2007, 09:13 AM | #11 |
Member#: 67958
Don't expect to make big numbers on 90 octane. It's as simple as that. Adding a water injection kit would probably help a ton on that setup.
09-05-2007, 02:23 PM | #12 |
Member#: 100624
BAIC
Vehicle:2004 WRX Wagon PSM |
Do anyone know how much a Autronic SM4 cost?
09-05-2007, 04:04 PM | #13 |
Member#: 51047
autronic.com has vendors listed.
09-05-2007, 06:09 PM | #14 |
Member#: 40638
NESIC
Vehicle:'04 PSM STi Has some work done... ;) |
09-06-2007, 02:51 AM | #15 | ||
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
...and if I had the coin and were building a Subie the way I would LIKE to build it......an Autronic ECU would almost certainly be my choice |
09-06-2007, 10:59 AM | #16 |
Member#: 67958
Sanjay I'll pm you.
09-06-2007, 11:10 AM | #17 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
I've tuned an Autronic, it's by far the best EM that I have used once you get over the DOS style interface. I built a map from the ground up and have to say that the Autronic gives you all the control you need, plus more.
I see an Autronic in my cars future. Going to break it in with the ECU/UTEC combo and then switch to an Autronic One small issue is the Autronic has no knock detection module for the Subaru. Tuning with det cans is required. |
09-06-2007, 03:45 PM | #18 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
or add a j&s
09-09-2007, 09:28 PM | #19 |
Member#: 101484
International
forget to add that i also have a water injection kit from snow performance ...i am not look for big number the car feels torque but i at least expect it to feel like 400+ car {planing on carrying it to the dyno in the future}
09-09-2007, 09:29 PM | #20 |
Member#: 101484
International
09-10-2007, 05:58 AM | #21 |
Member#: 63953
Vehicle:04 STi WR Blue |
J&S Safeguard^^^
09-15-2007, 12:38 AM | #22 |
Member#: 2036
Vehicle:2000 Intrepid silver |
Thanks to all our supporters on this forum.
I'm trying to market my latest system to the Ford guys. Very difficult. Widebands rule over there. Drop a term like "det cans" and you are likely to get "WTF's?". But then, most are satisfied with 650hp, so they aren't pushing their engines as hard as you guys are. Oh, they still worry about detonation, but their little pea brains haven't figured out that it might be a good thing to listen for it. They just want a "safe tune", doncha' know. I signed up as a supporting vendor on modularfords. One guy did me a fave and posted a thread called "products that work". Not a vendor on svtperformance, but I mention knock sensors in tuning threads and they must have me on ignore. If you have some time to kill, search my screen name on both forums. To see my latest version, click on the Vampire link at the top of my homepage. Won't work with the later Subaru coils, though. Need access to the coil negative wires. Very cool, though. No wires to cut, and any J&S wire can go to any coil! |
09-15-2007, 10:29 PM | #23 |
Member#: 46177
Vehicle:2002 WRB WRX 99 RSTi Coupe |
Just got a plug n play Autotronic ecu used and can't find what the wires go where for the air intake temp sensor. Two wire Red and black. What wires do i cut and use off of the maf sensor?
James |
09-16-2007, 12:30 PM | #24 |
Member#: 90110
W. Canada
Didnt you get a manual? I'm pretty sure it told me how to do it.
09-16-2007, 12:55 PM | #25 |
Member#: 46177
Anyone with Autronic or knows someone who sells Autronic. Need Help | STEALTH-WRX | Engine Management & Tuning | 14 | 09-05-2003 07:15 PM |
Autronic prices for those curious | MadWagon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 04-11-2002 08:14 PM |
Autronic ECUs | Conduit | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 04-11-2002 02:02 PM |
Help with Autronic Wideband O2 (Shiv) | Austin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 03-04-2002 10:32 PM |
Q: ECU- Autronic? | imprezausa | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 04-22-2001 06:34 PM |
