Old 08-09-2007, 10:35 PM   #1
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
Default Bottom end on its way heads may be shoot tell me what you think
I think i might be screwed with my heads off my 02 wrx...i knew i was misfireing but the carbon build up is just grose, it there a some what cheeper way i can go about fixing this because this was totally unforscene. Has anyone fulled there heads off and seen something like this before?
http://s204.photobucket.com/albums/b...t=CIMG2810.jpg
The good
http://s204.photobucket.com/albums/b...t=CIMG2811.jpg
The Bad
http://s204.photobucket.com/albums/b...t=CIMG2812.jpg
perrin247 is offline   Reply With Quote
Old 08-09-2007, 10:48 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I'd guess that the rings or ringlands on #3 are toast. But on the bright side I bet the heads will be fine once you clean them up.
LiquidForce is offline   Reply With Quote
Old 08-09-2007, 11:03 PM   #3
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
my dad was saying once i clean them up they might be fine but im still very nervous about them. what can i use to clean them up?
Old 08-10-2007, 11:35 AM   #4
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Pay the money to have them hot tanked, machined(if necessary)and vacuum and pressure tested. It's well worth it. 150-250bucks depending on the shop. You need to address the bigger problem in cylinder #3 before you do ANYTHING.
Acostafan is offline   Reply With Quote
Old 08-10-2007, 12:00 PM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
send them out to be hot tanked!
modaddict is offline   Reply With Quote
Old 08-10-2007, 12:18 PM   #6
T_A_C_H
Member#: 100196
2007 STI
I second the motion
T_A_C_H is offline   Reply With Quote
Old 08-10-2007, 01:45 PM   #7
p1prodrive
Member#: 149827
2000 600 bhp p1
sonic blue
no head fault there, its your rings for sure
p1prodrive is offline   Reply With Quote
Old 08-10-2007, 03:39 PM   #8
beavis820
Member#: 44572
2005 STi
Built and Ported
looks cracked in the top right corner into the coolant passage?
beavis820 is offline   Reply With Quote
Old 08-10-2007, 03:41 PM   #9
Acostafan
Member#: 67398
2002 Now with 100%
^^^you might be right, could be a bit of sludge though. What say you OP?
Old 08-10-2007, 06:45 PM   #10
modaddict
Member#: 95840
sold to a good bud
awaiting next car
if it was cracked to the coolant passage, the combustion chamber would most likely be clean.
Old 08-10-2007, 07:15 PM   #11
Starkiller
Member#: 82741
2007 350Z Silver
I paid 120 for a local shop to disassemble heads and glass bead the combustion chamber clean.
Starkiller is offline   Reply With Quote
Old 08-12-2007, 07:07 PM   #12
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
A friend of my dad owns a race engine shop hes going to hot tank them and do a leak down test. Hopfully there in good enough shape to get my car back up.
Old 08-14-2007, 07:34 PM   #13
stu
Member#: 25768
35R bugeye
Slowbaru
I was told not to hottank an aluminum head. it could actually warp the head I think steam cleaning them would work better and save you anymore trouble.
stu is offline   Reply With Quote
Old 08-15-2007, 04:02 PM   #14
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
how would i go about steam cleaning them...can i take the shims that sit on top of the valves off or do i have to number each one and put them back in the same order...or are they all the same. Thanks again for the help everyone.
Old 08-15-2007, 04:55 PM   #15
Starkiller
Member#: 82741
2007 350Z Silver
You can also have them cleaned via glass beading
Old 08-15-2007, 05:17 PM   #16
Acostafan
Member#: 67398
2002 Now with 100%
You need to mark those shims and put them back where they came, it's very important.
I may have found the source of my leak. Tell me what you think! ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-07-2007 03:35 PM
my photo porfolio. tell me what you think. be brutally honest D-I-Z-Z-L-E Off-Topic 51 08-13-2004 08:14 PM
check one for gold on silver tell me what you think pestysti Tire & Wheel 7 03-11-2004 12:55 PM
winter blues driving me to be irrational? pls tell me what you think. Lafora Motorsports 10 02-18-2004 02:33 PM
I'm on a roll. Tell me what you think of this idea steppin16 Off-Topic 17 03-21-2003 12:39 PM
