Old 08-09-2007, 10:40 PM   #1
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Default Metallic ringing noise from right front wheel??!?
I've got a 2001 Legacy w/ ~80,000 miles on it that has a intermittent quiet metallic ringing noise (sounds like something rubbing on the brake disk). I have put the brake pad quieter on, sanded the brake pads, and stoned the disk and this has no effect. I am pretty certain that it is not brake pad related at this point. I even pushed the brake cylinders back in and drove around using the hand brake - the noise was still there.
The noise seems to occur mainly on when turning left (and sometimes when going straight). It seems to get a bit louder if you turn hard. Braking does seem to stop the noise (but am not 100% sure). It will also ring if I drive in reverse turning right.
Could this be a wheel bearing going bad? Something else rubbing on the disk? Tie rod end? CV joint?
I was convinced it was brakes but I don't hear it when I lift up the front end and slowly rotate the front wheel.
Any help before I give up and take it to a mechanic?
paddleboy is offline   Reply With Quote
Old 08-10-2007, 12:23 PM   #2
SLI99
Member#: 134819
2005 Ford F150 FX4
i have the SAME problem right now....99 legacy GT with 106,000 miles...It only rings when im turning left. If the wheel is straight or right there is no noise...what could this beeeeeee. keep me informed
SLI99 is offline   Reply With Quote
Old 08-10-2007, 12:46 PM   #3
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Is this front or back??
MYfirst00 is offline   Reply With Quote
Old 08-10-2007, 08:21 PM   #4
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Default Front right side...
Does this sound like a bearing issue?
Old 08-10-2007, 08:32 PM   #5
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Normally I would lean toward a poorly performing caliper piston, but usually whhen you mess around with each part of the brake like you did the noise would go away for at least a few days...so I'd lean more toward the bearing now. If I recall correctly the rear ones are usually a low resonating noise and the fronts are a loud high squeal. Not cheap.
Old 08-11-2007, 07:53 AM   #6
DanThom
Member#: 23396
2003 WRX Sedan
I had a '98 that did this, and it ended up being the axle seal. Whether it was defective or damaged from some dealer-performed work, I don't know, but it would lightly drag against the axle and give a squealing/ringing noise when it was hot.
FWIW, my wife's '06 Outback is doing the same thing, so maybe it's not an uncommon problem.
Dan
DanThom is offline   Reply With Quote
Old 08-11-2007, 12:03 PM   #7
breakfasteatre
Member#: 131662
1996 Legacy LS
****. Bearings?
When im driving around, my front end makes a sound as well. Im not sure if i would call it a ringing, but maybe more like a light pulseing sound. I have a torn cv boot, could this just be the axle going? i have a new one to replace it
breakfasteatre is offline   Reply With Quote
Old 08-11-2007, 12:33 PM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
does it stop (while moving) if you lightly touch the brakes?
omahasubaru is offline   Reply With Quote
Old 08-11-2007, 03:42 PM   #9
spdracr00
Member#: 65823
1996 Impreza L
Red
here's another thing to check..
i had the same sound and it turned out to be rocks caught between my brake dust shield and the rotor... thanks ODOT! but thats what i get for driving to the mtn.. so i cut those suckers off and i've never heard the sound since..
spdracr00 is offline   Reply With Quote
Loud screeching/metal grinding noise from passenger rear wheel! ASpec818 Brakes, Steering & Suspension 7 02-17-2007 06:52 PM
rubbing/ grinding noise from right front? mpaone Brakes, Steering & Suspension 3 11-04-2004 02:22 PM
PLZ Help!!!...Clicking noise from right front! esbee Transmission (AT/MT) & Driveline 2 08-04-2004 06:30 PM
noise from right front suspension DriftnWRX Brakes, Steering & Suspension 3 02-09-2004 03:38 PM
Noise from right front during left turns with bumps in road beaster Brakes, Steering & Suspension 9 10-12-2001 11:46 AM
