Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-10-2007, 02:02 AM   #1
grizz3000
Member#: 127437
1990 Loyale
Default Getting clicking, all turns, even straight
A mystery here? New half axles and yet I still have 'clicking' every so often when I turn OR when I start-off from a stop.
Any guesses?
grizz3000 is offline   Reply With Quote
Old 08-10-2007, 02:15 AM   #2
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
elaborate on 'new'....
I've had TERRIBLE luck with remanufactured ones. had one fail (not clicking, just little chunks of metal everywhere) within 24 hours of purchase. Napa, autozone, checker, etc. all junk
AND, did you do the install yourself? did you make sure everything is good and snug? retorque that axle nut after driving around for a bit? check the condition of tie rod ends and ball joints while in there? how about wheel bearings?
AAAAND, describe the clicking. repeating noise that changes with speed? or just a single click?
Numbchux is offline   Reply With Quote
Old 08-22-2007, 04:14 PM   #3
TeamCF
Member#: 156638
1983 GL 4WD
Flat Black
Check the CV boot clamps.
I had mine start with a 'clicking' on me last week.
turns out it was just a CV boot clamp that found its way off of the boot and was hitting the steering knuckle.
I headed over to the dealer and they carry tons of them so I had to just clean up and replace the lost grease and install a new clamp. (only drove it for about 6 miles in clear weather with the boot loose)
If it's not the clamps then you could have gotten a bunk axle.
TeamCF is offline   Reply With Quote
Old 08-22-2007, 06:13 PM   #4
bgd73
Member#: 125088
Any guesses?
if boots aren't ripped, wiggle stuff around. the outer should be tight, the inner flops around.
try retorque. if you have ever seen the axles apart, you'll see that there is a little spline within the outer cv joint. the inner one doesn't need the torque like the outer, the outer can literally strip itself out internally- I believe there is a chance of it on your problem due to it happening going straight. Even if it is stripped BTW, it can still grip with over 140 ft lbs torque, it makes its own splines at oh 300 ft lbs .
Be sure the axle nut turns freely enough so accurate reading of wrench is ok. I do not use torque wrench, I stand on a 4 foot pipe until it is felt right .
bgd73 is offline   Reply With Quote
Old 08-22-2007, 11:23 PM   #5
grizz3000
Member#: 127437
1990 Loyale
Numbchux:
Yes, I did both half-axles myself. Since the knucklea were apart I did the ball joints, tierods, wheel bearings, and brakes.
I have since pulled the engine and completed a gasket kit project.
After I put in the new clutch, the engine will go back in. Then I can re-address this issue.
Standby for news.
Old 08-24-2007, 02:10 AM   #6
ej22bratman
Member#: 138704
Please explain how you would have an accurate reading wrench, and then not use a torque wrench...
ej22bratman is offline   Reply With Quote
Old 08-24-2007, 03:42 AM   #7
Bucky92
Member#: 108798
08 2.5i 5door
Satin White Pearl
bdg is smoking something again...or maybe he sat down and did the math of his weight ratio plus 4 ft breaker bar= perfect..we all know his way is the only right way and every torque wrench ever made in the world is wrong.
As for clicky axles..you said it was just once in awhile? has it gotten worse? I would also go with the checking of the axle nut and rechecking the boots.
( I need to read up on all this since I have 5 of them that need replaced....both fronts on my Loyale and 3 on my XT6)
Bucky92 is offline   Reply With Quote
Old 08-24-2007, 06:55 PM   #8
ej22bratman
Member#: 138704
Just use your magic wand to tighten the castle nuts, and your crystal ball to check the boots.
If that method fails, grab your known calibrated torque wrench(being calibrated is key, they do loose accuracy over time rendering them useless or severely prone to damaging key parts[like bolts]). The castle nuts should be at least torqued to 150 ft/lbs. And boots are simple, if they are cracked and or flinging grease... You know what to do.
Is there any change in the noise if you are breaking?
Old 08-24-2007, 11:44 PM   #9
grizz3000
Member#: 127437
1990 Loyale
I got the engine back in today, along with all the other 'stuff'.
I tried cranking her over but apparently I have a timing issue.
I'll tackle the timing tomorrow (Sat), it's time for a cold beer.
The clicking issue will be re-addressed once it's on the road again.
I got many good views of the boots during engine removal/installation, they look great.
Old 09-11-2007, 08:45 PM   #10
wagehan 1992 loyale
Member#: 158891
1992 loyale
blue gray
dont do the timing acording to chiltons manual i did it on my loyale and it didnt work proporly
wagehan 1992 loyale is offline   Reply With Quote
Old 09-15-2007, 03:54 PM   #11
wagehan 1992 loyale
Member#: 158891
1992 loyale
blue gray
i had the same problem on my car it was the capler draging you should check that too
Old 04-08-2008, 09:58 PM   #12
benham84GL
Member#: 174081
Default might help
I have the same problem on my 85 suby right now, I've replaced the tranny (with a 50K mile unit), CV joint and wheel bearings. Still clicks. Must be the backlash on the shaft (of the "new" 50K mile tranny. Its externally adjustable but have not built a spanner wrench for it yet.
benham84GL is offline   Reply With Quote
Please Help!!! Very fast clicking when turning over! ceecel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-17-2009 05:50 PM
Help, turning steeringwheel gets heavy all of a sudden! subierider Brakes, Steering & Suspension 7 09-13-2008 03:14 AM
loud clicking while turning?? 88rxn/a Normally Aspirated Powertrain 7 01-13-2008 07:38 PM
Resistance and a click when turning right bren wrx Brakes, Steering & Suspension 6 02-01-2006 03:18 PM
clicking when turning? HolyCrikey Brakes, Steering & Suspension 9 10-11-2005 09:17 AM
