Old 08-10-2007, 08:13 AM   #1
bmooney33
Member#: 130012
04 wrx w/sti block
Default Dave Brown tuned me to 411whp on a 95 degree day
went to no limit motorsport in medford, ny on 8/1...the temp in the shop was 95 degrees.... and dave brown still managed to pull crazy (safe) power outta my car!
check it out
on pump
spraying meth
here's a list of the mods that matter
04 wrx
sti short block, w/ported wrx heads
turbochargers.com 8cm frank 50 (externally gated)
SMC meth kit
perrin big maf
alsong with several other less important goodies......
bmooney33 is offline   Reply With Quote
Old 08-10-2007, 10:02 AM   #2
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
In exactly a week I go in for tuning with most likely the same conditions and very similar mods. Great numbers - I'll be on a Dyno Dynamics as well.
The Head is offline   Reply With Quote
Old 08-10-2007, 10:36 AM   #3
Paul
Member#: 56203
00 RSTI Coupe
why would you port the heads and use stock wrx cams??? Sti ones can be had for cheap and are a decent upgrade.
Old 08-10-2007, 10:37 AM   #4
xsblack
Member#: 26530
2004 Sti
JBP
Whats up with the nose dive in tq after 5K, were you able to hold boost till redline or was it tapering?
xsblack is offline   Reply With Quote
Old 08-10-2007, 10:45 AM   #5
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
^^^ cams??
aps2fast4u is offline   Reply With Quote
Old 08-10-2007, 10:47 AM   #6
Paul
Member#: 56203
00 RSTI Coupe
def cams
Old 08-10-2007, 11:12 AM   #7
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
once i raised the boost levels with the water/meth she would only take a certain amount of timing-higher compression-.i agree with youm guys on the cams.
dave/mspt
PerformanceAutoSolutions is offline   Reply With Quote
Old 08-10-2007, 11:55 AM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
What's the dyno CF?
corrected/uncorrected?
modaddict is offline   Reply With Quote
Old 08-10-2007, 08:13 PM   #9
bmooney33
Member#: 130012
04 wrx w/sti block
i blew my wrx 2.0 block back in december, and i was on a budget during this rebuild.... so, since the stock heads were off the wrx block, figured i might as well port em....
Old 08-10-2007, 08:16 PM   #10
Paul
Member#: 56203
00 RSTI Coupe
should have spent the money towards cams, then porting.....Like i said sti cams can easily be had for under 250 and would have made a difference
Old 08-10-2007, 10:38 PM   #11
lev98
Member#: 140529
01 Ferrari 360 spy
Nice numbers on a fellow Frank 50.
lev98 is offline   Reply With Quote
Old 08-11-2007, 04:46 PM   #12
wuuusaa
Member#: 92894
how do you like that turbo?
b/c i heard nothing but bad reviews from turbochargers.com and their turbos.
Thank for Stopping to Help on I 95 XXXGVRSTI4XXX Mid Atlantic Impreza Club -- MAIC 11 12-24-2008 02:39 PM
Give me the truth on a 95 impreza OBD1 or OBD2 help mellow65 Subaru Conversions 14 02-19-2007 08:26 PM
Alright who was in the Darkred and silver BAJA that wanted to tango on Rt.95? subafreak Baja Forum 12 03-12-2005 10:45 AM
what to put on car for track day protection Jerry Seagreaves Interior & Exterior Modification 1 02-28-2003 12:36 AM
Message Board Statistics All times are GMT -4. The time now is 01:56 AM.
