Old 08-10-2007, 12:01 PM   #1
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
Default can i flash a 04-05 base map onto an 02 ecu?
is this possible? i ask because i'm looking for a VF map so i can drive to my tuner but i cant find one for an 02 ecu, will i cause any problems to my ecu if i flash a 04-05 map on there?
thnaks
sgmongoose is offline   Reply With Quote
Old 08-10-2007, 12:17 PM   #2
Tea cups
Member#: 103136
no, you cannot flash a 04/05 map onto an 02 or 03. They are not compatible.
Tea cups is offline   Reply With Quote
Old 08-10-2007, 12:29 PM   #3
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
damn, do you know if there are any vf base maps online for an 02 ecu?
also, to my knowledge i have an 04 engine running off a 02 ecu. my wiring harness uses the 04 flash connecter. would i beable to just swap out to an 04 ecu? thanks
Old 08-10-2007, 12:37 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Just open the 04 ROM and copy the appropriate tables into the 02 ROM. Takes only a few minutes.
blkscooby is offline   Reply With Quote
Old 08-10-2007, 02:27 PM   #5
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
oh true. all the 04 tables will be capatable with the 02's right?
Old 08-10-2007, 02:43 PM   #6
Freon
Member#: 88322
2009 BMW 135i
They're probably almost the same size or the same size (i.e. 10x12, etc). I wouldn't count on it reacting exactly same way, but it will get you most of the way there. You should still go back and retune it and make sure AFR, timing, and boost are what you intended.
Freon is offline   Reply With Quote
Old 08-10-2007, 02:50 PM   #7
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
well i just downloaded a stage 2.5 map for a 04 ecu and looking at the scaling its slightly differnt then some of the maps for my 02 ecu. in some cases, the range is less/more, or the increments are differnt. should i change the increments of my stock 02 table to match the 04 ones or?... i plan on having the car tuned, its just a matter or driving the car there.
Old 08-10-2007, 03:22 PM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
The 02 map is 1 column wider than the 04-05 wrx maps. You can copy them over but as long as you aren't doing full boost pulls your chances of jumping into the last column are slim. Just make sure the load on the final column is higher than the one to the left of it.
Its too bad I can't access my laptop from here, I've got a map already converted/tuned for a VF series in a 2002 map. If you want I can e-mail it tonight (like REAL late, midnight or so pacific time).
Old 08-10-2007, 03:25 PM   #9
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
that'd be awsome, i'll pm you my email adress, thanks!
Old 08-11-2007, 12:56 AM   #10
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
whats your mods? i have map for wrx 02
Hefe_sti_Pma is offline   Reply With Quote
Old 08-16-2007, 01:18 PM   #11
EdWRX
Member#: 108068
05 WRX Enginuity'd
WRB Stg II y00!
No!!!!!
EdWRX is offline   Reply With Quote
04-05 Rear bumper on an 02? burtonboy759 Interior & Exterior Modification 11 06-12-2008 09:06 PM
05 sti hubs onto an 04? misterwaterfallin Brakes, Steering & Suspension 10 03-18-2008 03:37 PM
looking to start a 04/05 sti swap in an 02/03 bugeye need shopping list 02MidnightPearlRS Subaru Conversions 2 03-09-2008 04:08 AM
02 map on an 03 ecu Dragula Commercial ECU Reflashes 9 04-18-2007 08:25 PM
04-05 STi interior into an 02 WRX? designfate Interior & Exterior Modification 6 11-14-2006 03:10 PM
