Old 08-10-2007, 07:29 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default Phase II EJ22E manifold - heads?
From waht I understand all phase II stuff is interchangeable..does this apply to the ej22 too?
Im curious to know if usdm wrx heads will bolt up to an ej22e manifold.
mxpunk is offline   Reply With Quote
Old 08-11-2007, 01:21 PM   #2
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
I would say no. Right off the bat, the TGV's come into play.
Regardless, I just looked at my EJ18E and EJ205 heads next to each other and the intake holes are definitely different.
Of course, my EJ18E is a Phase I, but nonetheless, I'd still say they're different.
DerFahrer is offline   Reply With Quote
Old 08-11-2007, 03:48 PM   #3
2006STI365
Member#: 115603
im not to sure about this either, but i would like to find out more. sounds really interesting.
2006STI365 is offline   Reply With Quote
Old 08-11-2007, 04:54 PM   #4
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
SOA part numbers
EJ205 intake mani gaskets: 14035AA421
7/98+ EJ22 and EJ25: 14035AA382
different part number.....pretty safe bet it won't work
Numbchux is offline   Reply With Quote
Old 08-11-2007, 10:01 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks guys..
Old 08-12-2007, 01:04 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
hA! you guys needs to have HANDS ON. The gasket is a different part number, yes. BUT the bolt pattern is the same. It will bolt up just fine. What you worry about is the cam sensor position. It MAY be able to run fine because we're able to do a '96 2.5L DOHC into a SOHC 1.8L Impreza. Started up just fine.
All the Phase 1 EJ18, EJ22 share the same intake mani bolt pattern. All the 96-99 DOHC 2.5L share the straight-across bolt pattern. All 99+ phaseII 2.2L/2.5L and WRX/STi/FXT/LGT and regular models share the same bolt pattern as of current.
If you want I can go put my EJ22E mani on my WRX long block then come back and post.
FuJi K is offline   Reply With Quote
Old 08-12-2007, 04:43 PM   #7
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
1) Because it makes future reference easier, and...
2) Because I'm a total geek...
it would be easier to refer to the Phase II EJ22 as an EJ221. There are EJ221s, EJ222s, and EJ223s, but I just think the 2s and 3s have to do with what trim level of car it's in.
So I hereby designate the Phase II EJ22 as EJ221
I guess it would make sense that the Phase II engines work, as the heads are different than the Phase Is.
Old 08-13-2007, 01:38 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
I just want a pair of phase II EJ22 heads......I got the manifolds to fit it!!!
c'mon Fuji.....give'm up!
Jay Storm
Old 08-14-2007, 09:50 PM   #9
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
post pic a kid!!!
if i were to get a phase II ej22e, i could put some wrx heads on it and have a nice boosted motor! sickness.
Old 08-15-2007, 10:39 AM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Glad to see this got cleared up. I read the first couple of posts and my initial response was WTF do TGV's have to do with it? People without firsthand experience really should learn to bite their tongues.
Jay,
I may have a set for you in fairly short order coming off of my new project car. I will let you know...
Old 08-15-2007, 02:22 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
You da man!!!
Jay,
Old 08-15-2007, 06:48 PM   #12
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
still waiting for pics from fuji..
Old 08-15-2007, 10:03 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
there are a few things you have to do. FYI, that is a WRX intake manifold gasket.
WRX top, 2.5L NA bottem
2.5L top, 2.2L bottem
You have to take off the big metal bracket on the driver side of the intake mani
you can see it's off and also leave the bolt right next to the fuel rail OFF
Here's the bracket
You want to grind away at the end of the rail sos the little alignment pin for the mani-gaskets will clear the manifold.
It's going to be a tight fit. You might want to drill the manifold holes so they're bigger towards the CENTER of the whole manifold.
Here's the manifold on the WRX heads; EJ22T shortblock w/ 96-98 3-layer 2.2L head gaskets. Sorry I didn't have all the bolts on the manifold, but it all lines up. Just a bit tight. FYI: need to run non-WRX/STi/FXT/LGT upper coolant pipe as the header return hardpipe will not clear the NA throttle body coolant hardpipe that's to the driverside of the NA throttle body.
Happy now?
Old 08-15-2007, 10:41 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
very!
im thinking if i ever get a phase II ej22e impreza L i can boost it using wrx heads, slap some ej22t pistons in the block and have a big boost friendly motor.
99 Phase II ej22 into 99 Forester Phase II ej25 subiman2005 Forester Forum 2 10-18-2009 10:39 PM
mxpunk's phase II ej22e wrx build! mxpunk Built Motor Discussion 66 02-16-2009 12:40 PM
WTB: Phase II EJ22 heads Storm Private 'Wanted' Classifieds 1 10-04-2008 11:42 AM
Headgasket VS. Phase II EJ25 to Phase II EJ22 swap- "Simple"? 99legacyL Newbies & FAQs 0 03-01-2008 04:09 PM
low boost on bone stock Phase II ej22e? 970subaru Normally Aspirated with bolt-on Forced Induction Powertrain 12 11-09-2007 05:21 PM
