Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 08-10-2007, 08:35 PM   #1
Ryan166
Member#: 95959
1998 Impreza L
Red
Default 1998 EJ22... interference or non-interfence?
1998 Subaru Impreza L
EJ22 ... 2.2 L 4 cylinder aluminum alloy 16 valve SOHC boxer engine
Is my engine interfence or non-interfence? I have heard both... EJ22's from 1997 on, are interference? All SOHC EJ22's are non-interference?
Thanks for any help!
Ryan166 is offline   Reply With Quote
Old 08-12-2007, 06:15 PM   #2
Ryan166
Member#: 95959
1998 Impreza L
Red
Anyone know?
Old 08-13-2007, 12:34 PM   #3
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
Interference, subie havent done non-interference one since the AE if i remember well
Guerice is offline   Reply With Quote
Old 08-13-2007, 12:41 PM   #4
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
The ej22 engines used hydraulic adjusters up through 96 I believe, then in 97 they introduced solid lifters...and hense the ZERO clearance engine...
unfortunitly you have yourself a ZERO clearance motor.... be sure to change your timing belt
IllNastyImpreza is offline   Reply With Quote
Old 08-13-2007, 02:47 PM   #5
Ryan166
Member#: 95959
1998 Impreza L
Red
Thumbs up
Thanks guys
Old 10-04-2007, 03:06 PM   #6
nwskipro
Member#: 93960
'96 Impreza L
so just to double check. a '96 ej22 is non-interference then?
nwskipro is offline   Reply With Quote
Old 10-04-2007, 03:38 PM   #7
bentwrench
Member#: 159403
1998 Impreza
Green
I would venture that engine will bend valves as well. Both the HLA and solid rocker ej22 will.
bentwrench is offline   Reply With Quote
Old 10-04-2007, 04:36 PM   #8
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
ej22 1990-1994 are non interference... 95+ is interference...
Zefy is online now   Reply With Quote
Old 10-04-2007, 10:29 PM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i thought that the dual port ej22 was non-interference and the single port was interference.
~Josh~
Old 10-04-2007, 10:53 PM   #10
bentwrench
Member#: 159403
1998 Impreza
Green
I would always error to the side of caution here, keep up on your maintenece and call your dealer or trusted mechanic if you are unsure, it is a very costly thing to find out the hard way.
Old 10-04-2007, 11:41 PM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
~Josh~
That's the simplified version of the way I see it. I worked on dual port ej22 that skipped teeth. Changed the tensioner and threw a new belt on it and away it went.
Tim Sanderson is offline   Reply With Quote
Old 12-18-2013, 01:32 PM   #12
drfrisker
Member#: 259920
Looking at lots of conflicting information on many of these subaru forums... Found a gates timing belt guide that says 98 legacy 2.2's are non interference.
http://www.gates.com/downloads/downl...older=brochure
drfrisker is online now   Reply With Quote
Old 12-18-2013, 01:39 PM   #13
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
this thread is over 6 years old...
And your link requires a log in or at least it doesn't work for me...
Old 12-19-2013, 12:16 AM   #14
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
97up is definitely interference.
bangedlegacywagon97 is offline   Reply With Quote
Old 12-19-2013, 04:34 AM   #15
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
There is a lot of misinformation in this thread.
This.
1997+ SOHC motors became interference. The 1997+ SOHC motors with the solid valvetrain and the single port exhaust are interference.
The earlier non-interference SOHC EJ22s with the hydraulic valvetrain and dual port exhaust were offered until 1996.
I know this thread is pretty damn old but the link worked for me, so let me say something.
That catalog is very inaccurate as it has marked the 1997-1998 2.2 SOHC marked as non-interference which is false.
It also has a DOHC motor marked as non-interference which is false as well. All 4 cylinder DOHC Subaru motors are interference.
It also has only marked a few of the motors as having timing belt driven water pumps, which is inaccurate as well, because any Subaru with a timing belt has the water pump driven by the timing belt.
Jessekrs123 is offline   Reply With Quote
is 95 wrx ej20g an interferance or non-interferance motor GregBolby Pre-2002 Factory Turbo Powertrain 14 03-27-2010 01:40 PM
96 Impreza EJ22E non-interference or intereference 96GreenLX Normally Aspirated Powertrain 3 01-03-2009 01:06 PM
WTB: Non-interference EJ22 (complete or longblock) for a LeMons car Nashco NWIC Private Classifieds 18 08-12-2008 10:21 PM
EJ22, interferance or not. How to tell? beegeer General Community 9 04-21-2006 12:05 PM
Interference or Non-Interference Engine gypsymoth Service & Maintenance 1 07-21-2003 09:51 PM
