Closed Thread
Old 07-09-2007, 01:00 PM   #1
slickrex
Member#: 89983
2005 vf39'd wrx
295whp stealth black
Default which injectors for a vf39?
im picking up a very cheap used vf39 and need some opinions on which injectors to use. ive done plenty of research and the general answer are the jdm sti pinks but im concerned they will they get maxed out close to 280-300whp... should i consider buying 650cc injectors instead??
slickrex is offline
Old 07-09-2007, 01:11 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Sti Pinks are all that you need for that particular turbo that you have chosen. 300whp is close to the max output for the Vf39, so you should be right on
target
JMK508 is offline
Old 07-09-2007, 05:02 PM   #3
fastwrx25
Member#: 126441
03 bugeye
the 06-07 wrx "blue" injectors flow the same or a bit more than the sti pinks.
you can pick up a set of used ones in the personal classifieds for 100-180. good deal imo
fastwrx25 is offline
Old 07-09-2007, 06:01 PM   #4
IIdiceII
Member#: 90438
where are you finding 06 wrx injectors for 100 ^
I went with 650's because i know ill eventually upgrade the turbo again and dont feel like getting different injectors when i do that.
IIdiceII is offline
Old 07-09-2007, 09:21 PM   #5
Foska Oats
Member#: 144081
2003 WRX
Pinks are truly all you need. I am not looking for more than 300 anyway, as I am not going more than say 19 psi if so much on my VF39.
But it all depends on what you are looking for.
For most saying that 300 is close to maxing the VF39, 39's have made in excess of 350.
Foska Oats is offline
Old 07-09-2007, 09:27 PM   #6
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
pawn shop...
yeah, if ya got the coin, get the bigger, 'cuz it ain't like yer gonna stop wanting more POWA... they can tune down for 650cc injectors, if ya find em for $250, they're a good bet...
cellobro is offline
Old 07-10-2007, 11:54 AM   #7
slickrex
Member#: 89983
2005 vf39'd wrx
well if the pinks are sufficient enough it would be a plus so i can run the cobb ots map to the tuner, but if 650's are preferred then it'll be a little extra work getting a limp map from the tuner... should i be concerned about the pinks?
slickrex is offline
Old 07-10-2007, 12:41 PM   #8
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
You should only be concerned about the pinks if you are planning on going with a bigger turbo down the line. As far as a limp map for larger injectors just find someone with a tactrix cable and do it yourself, its really not that hard. You would need to change the injector scalar for sure, probably injector latency and tip in tables as well. Cobb has a good write up on how to do injector scaling around here somewhere, just search for it.
brettm is offline
Old 07-10-2007, 01:08 PM   #9
Foska Oats
Member#: 144081
2003 WRX
THis is true. Wish it was as easy fo rme with the Tactrix, we have piss 90 octane gas her in Jamaica so I have to go to a reputable tuner and he uses a wideband to tune anyway. But I think the pinks are good for him.
Old 07-10-2007, 01:28 PM   #10
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
If all you are doing is upgrading injectors using enginuity should be just as easy for you as it would be for anyone else, octane shouldn't affect tuning for injectors. Its when you start touching your boost/fuel/timing tables where that becomes important.
brettm is offline
Old 07-12-2007, 07:36 PM   #11
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
Im running Deatchwerks 650cc injectors on my VF43'd WRX. They work fine and have a little more room for a larger turbo in the future.
You might want to spring for the more expensive STi Pink 565's because they are known for providing factory-smooth fuel delivery for a very nice idle. My injectors seem to be slightly uneven in spray pattern or something because the idle is kinda lumpy when the car is cold, but this may just be my tune needing to be smoothed out.
WRXDriftR is offline
Old 08-11-2007, 07:38 PM   #12
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
You most likely need to modify the injector latency values if you haven't already. The Deatschwerks latencies are different than stock IME.
blkscooby is offline
Closed Thread
Which injectors for power! Venom911 Service & Maintenance 1 02-29-2008 07:17 PM
Which injectors for the HKS 2530kai Twin Scroll turbo? keirnna Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-23-2008 08:54 AM
which injectors for which turbos? ultramagnus Newbies & FAQs 22 08-06-2007 11:06 AM
Which injectors for stage 3 cobb? ender87i AccessPort 13 05-08-2007 02:33 AM
Poll: Which Injectors for FP18G Turbo Lowball Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-15-2004 06:07 PM
