Old 08-11-2007, 02:55 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default )5 STI with Gt35R UR kit, Alchy and AP Pro Tune
This car came out very nice - he basically maxed out the UR maf housing which has modfied to 2 and 7/8's-(having it machined out) - Larger than the stock one but not as large as the huge Perrin one. The idea is to try and keep the smallest MAF we can get away with as a smaller maf gives better resolution and driveability on low rpm / low load conditions. Large MAFs and large injectors can make it a real challenege to get it running as smoth as stock. In the case of this car with shall we say medium maf the driveability and idle was perfect.
This tune was obtained with 21 psi of boost - 50 / 50 meth and h2o mix by Snow and 93 octane. This was the most power and boost we could get with this car until we get a larger MAF, the medium maf was maxed out 100% at 22 psi. (did make 465 whp at 22 psi)! The customer has to choose if he wants to keep the current MAf and power level or of he wants to step up and make even power with a larger MAF and retune the car
[IMG][/IMG]
AL
Dyno Flash is offline   Reply With Quote
Old 08-11-2007, 11:48 AM   #2
mixmatch
Member#: 132057
2007 STi
Urban Gray Metallic
the curves look very nice. what is the purpose of the bottom graph?
does this car have stock block/heads? what size injectors? how much more power do u think itll make with a big MAF?
mixmatch is offline   Reply With Quote
Old 08-11-2007, 12:39 PM   #3
BAMBAMSTI06
Member#: 114814
2006 STI
WR Blue
just out of curiosity is this the same GT35r sti that has been at ICS for weeks that had the hydra originally or is this car a different setup and the other car still remains stuck there
BAMBAMSTI06 is offline   Reply With Quote
Old 08-11-2007, 03:49 PM   #4
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Your a real comedian
The car that is "stuck here" has been done for a long time and the owner is out of the country on vacation - maybe he will come to get it some time soon - no matter its in our long term storeage area with a car cover
The car in the above chart has a AP1 not a hydra and has a stock motor not a built motor - different car
AL
Old 08-11-2007, 04:07 PM   #5
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Numbers look good!
LeeC is offline   Reply With Quote
Old 08-11-2007, 04:37 PM   #6
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Al, any reason you are going from smoothing of 2 to 0 to 5 and now are running this dyno by mph also? I'm just confused with all this changing. I know dynos are tuning tools but you're changing the only consistent things...
wrxfactor is offline   Reply With Quote
Old 08-11-2007, 06:46 PM   #7
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I used MPH on that pass as the car made som much power it shook the optical sensor loose on the radiator support and it lost rpm signal
FYI - I change and alter the smoothing as indicated
Old 08-11-2007, 07:09 PM   #8
gotti
Member#: 62956
06 sti rally car
gottiracing
Funny how any every other dyno and shop is able to handle "that much power" without loosing signals
and it also looks silky smooth as well
gotti is offline   Reply With Quote
Old 08-11-2007, 08:04 PM   #9
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I was able to make 955 with my Evo with no problems on the same dyno - it was just the case that the magnetic base holding the optical pick up vibrated slightly to the side after so many pulls and the singal was lost mid way through our last pull - not the end of the world
Keep in mind that on Subarus we use the optical sensor to simply the process as the coils are ina harder to reach location
Old 08-11-2007, 08:42 PM   #10
bigboy
Member#: 117384
2003 WRX
sonic
nice numbers man!!
bigboy is offline   Reply With Quote
Old 08-11-2007, 10:27 PM   #11
05stisilver
Member#: 128533
05 sti
what are the differences between his setup and yours since you have 100 more hp?.... I'm curious because I'm having a 35r setup installed this week..with supporting mods and some upgrades and I am wanting to see the 550-600 range on race gas....as close to 500 as possible on pump (93)....
05stisilver is offline   Reply With Quote
Old 08-11-2007, 10:34 PM   #12
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
looks sweet - Im in need of some action like that
Kastley85891 is offline   Reply With Quote
Old 08-11-2007, 10:45 PM   #13
BlackFlame
Member#: 100082
Now, Im still a turbo noob, so forgive me if its obvious. But if the customer is looking for driveability would a blow-through-maf be a good idea? Wouldnt that also yeild more power for his setup? Or are those just rediculous to tune and deal with?
BlackFlame is offline   Reply With Quote
Old 08-11-2007, 10:56 PM   #14
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I personally find that a stock style maf is superior as the air temp correction is still functional
When you use a blow through maf it is imperative to set up a second maf sensor to log that data
Old 08-11-2007, 11:06 PM   #15
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
So at what point do you suggest using Speed Density, or do you prefer to tune differently?
Old 08-11-2007, 11:31 PM   #16
BlackFlame
Member#: 100082
So a blow through maf doesnt give accurate readings as to actual intake charge temperature? Sorry--Im just tryin to learn
Old 08-12-2007, 12:57 AM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
If anything I would think Blow-through would be more accuarate since it meters the actual intake charge (cold side IC piping)
With a TMIC the air charge is always hotter then what the MAF reads.
mxpunk is offline   Reply With Quote
Old 08-12-2007, 01:13 AM   #18
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
On a stock ecu the air temp corrections are set up to correct for changes in the abeint air temps as the stock air intake is a cold air source - (drawing air from the under hood scoop). Boost duty cycles, ignition, etc are all set up to vary based upon the ambient air temps.
On a blow through MAf your measured charge temps can vary as much a 30 degress within a single 1/4 mile pass as the intercooler heats up and the turbo discharge temps rise.
It is possible with stand alone systems and also the UTEC to have global fueling and ignition corrections based upon charge air temps
For example an Autronic ecu uses a very sensitive air temp sensor which is designed to be located as near as possible to the throttle body as autronic ecus work on estimated charge air temps at the intake valve
Other stand alones often only rely on air charge temps for extreme global adjustments of the fuel trims when charge temps reach very high or low levels and also for starting in extremely cold conditions.
Depending on how the car is set up - often a ambient air temp sesnor which measure the air temps near the air filter may work better than a charge air temp sensor inside the inatke tube
The UTEC's air temp functions seem to be seldom utilized and many UTEC / Blow Through MAF cars I have seen do not utilize air temp corrections.
I hope this makes sense
Al
Old 08-12-2007, 01:17 AM   #19
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
The issue is not the measurement of the air temp indicated at the sensor but rather how you are setting up the ecu and the corrections which comensate for air temp changes.
I think the air temp sensor would be accurate no matter where you put it - my point is that the stock ecu as set up from OEM is set up for a ambient air temp adjustment and not a charge temp correction.
Old 08-12-2007, 08:29 AM   #20
BlackFlame
Member#: 100082
It does for the most part-I guess I just always thought that blow-through would be more accurate. It still seems as though it might, it just may be more difficult to setup EM for it whenever I get my motor built. Thanks for the feedback
Old 08-12-2007, 01:36 PM   #21
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Lookin good Al!! What RPM was max torque at??
aps2fast4u is offline   Reply With Quote
Old 08-12-2007, 01:52 PM   #22
GBX
Member#: 132764
07 STI Ltd
UGM
AL
then how come you only made 350whp on that car? Its that low for a gt35 on a built motor, even with ecutek??????
GBX is offline   Reply With Quote
Old 08-12-2007, 02:47 PM   #23
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
You do realize you can adjust your ignition advance based on ACT using Cobb? I'm not 100% sure on EcuTek, but I know for a fact you can change the way the ECU adds or retards timing based on ACT's.
ChrisSK is offline   Reply With Quote
Old 08-12-2007, 03:37 PM   #24
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Of course I realize that as I tune with the stock Subaru ecus on a daily basis and see those maps all the time.
The stock ecu's adjustments are designed to act as safeguards to prevent over boosting in very cold ambient air temps or for example to lower the timing when you hit super hot conditions.
I can get into specific explantions as needed.
My point is that when using a blow through MAF thought must be applied in how to set up the ecu to compensate. My suggestion is to run a second maf in the inner fender or close to the air filter to read the abient conditions.
Old 08-12-2007, 03:40 PM   #25
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
In order to carry on an inteligent dialouge we have to be clear
The car which is the subject of this post made a lot more than 350
The other car with the Hydra made a lot more than this car
I am lost
'07 Limited with DP and Intake Pro Tune Dyno Flash Proven Power Bragging 10 08-23-2007 01:39 AM
2003 WRX Stage III with PE1820 - UTEC vs Cobb AP Pro Tune Dyno Flash Proven Power Bragging 30 01-05-2007 11:27 PM
3.5 downpipe with gt35r turbo 05 wrx sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 03-26-2006 05:45 PM
UP/DP and Cobb AP Pro Tuned= Reliable car????? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-12-2005 07:52 PM
Kingpin GT35R turbo kit. 513whp and 475wtq Part 2 Kingpin Proven Power Bragging 153 03-26-2005 10:39 AM
