Alaskan Impreza Club
Old 08-11-2007, 07:31 AM   #1
RawCode
Member#: 3115
2002 Impreza 2.5RS
Default 02 RS Front sway bar install question
So I am trying to pull the front sway bar on my 02 RS. Do I need to drop the headers to get it out? I already have the subframe and endlinks removed.
I also removed the jack cradle in an effort to get more room to maneuver the bar and it did help, but the headers combined with the steering rack assembly make it near impossible to remove. And I don't like bending the hard lines for the steering rack either.
I already cracked the nuts for the header loose just to see if I would have any issues, and to my amazement they all were pretty easy. However I was running out of time (had to go to work) so I retightened them and remounted the sway.
Thoughts?
RawCode is offline   Reply With Quote
Old 08-11-2007, 01:52 PM   #2
cooparu
Member#: 67767
2010 WRX
Red
Thoughts?
Remove the headers. I installed my fsb in the spring, at the same time that I installed the headers (on purpose). I didn't remove the subframe, it was enough to have the headers and cat section out. It's still a wriggle and twist to get it in there, but it'll happen.
This is a perfect time to install some EL headers.
cooparu is offline   Reply With Quote
Old 08-11-2007, 07:49 PM   #3
edo2000
Member#: 68709
2012 WRX
red
Not sure about headers, but I didn't have to touch my exhaust manifolds or any other exhaust pieces when I put a Cobb front sway on my WRX.
edo2000 is offline   Reply With Quote
Old 08-11-2007, 08:09 PM   #4
cooparu
Member#: 67767
2010 WRX
Red
N/A's have the headers in the way. These are my current headers and fsb after installation:
And I do remember removing the jack plate too, that was the easiest part.
Old 08-11-2007, 09:09 PM   #5
edo2000
Member#: 68709
2012 WRX
red
^^^ good picture. I'll quit giving useless tips about cars that are different than the current topic.
Old 08-12-2007, 02:38 AM   #6
RawCode
Member#: 3115
2002 Impreza 2.5RS
Maybe I should jsut get new headers like AKOBS says.
He has a lot more clearance. I will post a pic tomorrow.
Old 08-12-2007, 03:04 AM   #7
Firestrike
Member#: 135785
2006 Impreza WRX LTD
Cloaking Device Gray
Does the RS have different shaped headers than the rex? I had no problem with my front sway, just have to twist it around a couple times like those puzzles you see made out of metal in those knick knack shops.
Firestrike is offline   Reply With Quote
Old 08-12-2007, 02:05 PM   #8
cooparu
Member#: 67767
2010 WRX
Red
Yeah, the ebay Borla knockoffs do hang lower than the stockers (well, pre-06, at least). I could probably get a straighter wrx front bar in there with enough clearance.
STi front sway bar install question S2killer Brakes, Steering & Suspension 3 04-05-2007 08:47 PM
Front Sway Bar Install Question?? WRXcellent Brakes, Steering & Suspension 23 02-26-2007 02:03 PM
Front sway bar install question peterex Brakes, Steering & Suspension 2 04-07-2006 05:26 PM
question about cusco front sway bar install anthonyrb98 Brakes, Steering & Suspension 1 09-24-2004 04:15 PM
02 sedan Front sway bar instal Davenow Brakes, Steering & Suspension 1 11-01-2002 12:12 PM
