Old 03-05-2009, 08:19 PM   #276
SVXT6
Member#: 159991
1973 GSR,Fuji Rabbit
Yellow with black stripe
Originally Posted by PseudoKirby View Post
but apparently they will lower compression
also I was thinking, swapping in the EG33 prolly will make the car completely illegal for the road wont it?
I was going to put in the stock engine with stock intake and exhaust and try to smog it and hope they dont notice... lol
No Its the EJ22T pistons that lower the compression not the Rods
SVXT6 is offline   Reply With Quote
Old 03-05-2009, 09:11 PM   #277
PseudoKirby
Member#: 203835
2000 2.5RS
oh he just mentioned rods.. lol didnt notice that
PseudoKirby is offline   Reply With Quote
Old 04-01-2009, 08:47 AM   #278
PseudoKirby
Member#: 203835
2000 2.5RS
I have missed out on many chances on buying an impreza.. sucks
anyway if I get a 6 speed front differential, and rear differential with a DCCD all from the same year WRX there should be no problems right? with a DCCD to put most/all of the torque to the rear wheels for some fun times every now and then, would the DCCD handle the power of the H6?
Old 04-01-2009, 06:06 PM   #279
sick1.8t
Member#: 22345
2003 RSX
black
they'll probably notice that the radiator is in a different place, and you probably hacked up your radiator support to make it fit.
sick1.8t is offline   Reply With Quote
Old 04-03-2009, 02:10 AM   #280
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
DCCD is Driver Controled CENTER Differential. It's in the trans but yeah anyways.... Getting matching final drive ratios of hte differential in the rear and in the trans is the key. You can have them swapped out by a shop to match which ever final drive you want. I'm getting a V6 STi RA w/DCCD trans form DS1 and though it comes with a 4.44 final drive I"m likely gonna have it swapped down for a 3.54 or 3.9 and put a R180 rear diff. Wether or not your choice will hold the power is up to how you drive and what you will use the car for. Talk to a trans specialist(Like DS1 Motorsports! DYLAN RULES!) and figure out what you want to do. You can run the original bits if you don't beat on them at all atleast for a little while. If you are spending the money on a 6speed just make sure to get a matching rear diff. Either a "built" WRX R160 with matching final drive or just get the matching R180 STi rear diff. Good luck with that but work on the motor part first. Either you add a H6 to a set up car or you swap a h6 into a car and build around it. Well there is option 3. Over haul the whole car with H6 and everything else while the car is off the road(my choice)
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 04-05-2009, 02:16 AM   #281
m0nkeyballz
Member#: 198411
2001 Subaru RSTI
APEX SILVER
Since this is the official h6 impreza thread I thought I would post here about my potential eg33 swap into a 98 forester. Ive seen motors online and Im wondering what else I will need besides just the basic motor. Obviouslly I will need the main wiring harness for wiring. So I would really appreciate it if someone could add to my list of things I will need to complete the swap.
Thanks in advance,
David
m0nkeyballz is offline   Reply With Quote
Old 04-05-2009, 04:44 PM   #282
sick1.8t
Member#: 22345
2003 RSX
black
the engine with throttle body,
engine wire harness,
ecu wire harness (the part that goes through the firewall),
ecu,
headers although you'll still need a custom exhaust, but its a good start,
to fab an intake that will work with your engine bay.
you can use your tranny and existing mounting points etc, thats all the same.
Old 04-05-2009, 04:48 PM   #283
Seraphinwolf
Member#: 150922
97 OBS EZ30R
If you are RS25.com too search for a thread titled H6 it's kinda the same thread as this but very specific to first gens and most talk is about EG33 swaps.
-Gaddis
Old 04-26-2009, 11:55 AM   #284
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
95 Coupe lightweight proj
Some great info in this thread, keep it going!
Does anyone know of any companies that are making aftermarket non-AVCS cams for the H6? I;m trying to compile a list of everything i want to get before i start tearing things apart.
EDIT: Also does anyone have the specs for the different Stock cams available for the H6?
bump!
carnz-pj-410 is offline   Reply With Quote
Old 04-26-2009, 07:21 PM   #285
Seraphinwolf
Member#: 150922
97 OBS EZ30R
bump!
each of the engines have only one cam profile set per engine. So the EG33 all only have one stock grind, same for the others. Delta Cams can work on any cam profile you want.
-Gaddis
Old 04-27-2009, 01:09 AM   #286
PseudoKirby
Member#: 203835
2000 2.5RS
anyone have any advice on what injectors to use? http://www.ecutune.com/svx-stage2.htm says SR20DET Injectors... but thats a 4 cyl.. buy 2 sets and have 2 injectors left over? or would RB26DETT Injectors also work? (and have a higher flow)
Old 04-27-2009, 08:59 AM   #287
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
RB injectors are supposedly the same as SR injectors, so that would be a good option for you.
Old 04-27-2009, 10:48 AM   #288
Seraphinwolf
Member#: 150922
97 OBS EZ30R
They indeed are aside fromt he flow rates. Any average Subi injector will work too. Anything that will work on a 92-06 Impreza/WRX/STi will work. Deashworks flow calculator points that for my goals on the EZ30R a floow rate of around 400cc or higher. So I'll be looking into a set of STi pinks or other 600cc's to push further for later goals. But yeah the SR and RB injectors work.
-Gaddis
Old 04-27-2009, 11:47 PM   #289
PseudoKirby
Member#: 203835
2000 2.5RS
-Gaddis
but yea all I see is WRX Injectors in set of 4's, do you need to buy 2 sets then, or is there a place you can specially order them? just 6
Old 04-28-2009, 06:50 AM   #290
Seraphinwolf
Member#: 150922
97 OBS EZ30R
You can order just six dirrect form deuchworks. Could just get 2 pairs of 4 and have spares. I will be ordering 3 pairs since I have two H6's Well when ever I get to it. Besides on ebay you see sets of JDM pinks and stuff where one is shot so it's basicly a set of 3. You can always just double up on that.
-Gaddis
Old 05-09-2009, 01:02 AM   #291
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
FYI, I case someone else needs this info:
I plugged my scope into my H6 EZ30R car to take a few measurements.. I didn't have the RH cam sensor wired up, but I'll do that tomorrow and take another snaphot.
Here you can see the 5th falling edge after the single large break which is TDC #1. LH Cam pulse is right about 70 degrees after that, just as the specs above.
Here you can see the start of the fuel injector spraying. Interesting that it is spraying starts about 12 BTDC and finishes about 2 ATDC. The intake valve opens at about 3 ATDC.
Here you can see the coil charging the firing the spark. The dwell is evident (and a bit high.. I need to turn that down some), as well this is at idle where timing is ~ 16 degrees.
I'll follow up with the RH measurements.
Jeff
sponaugle is offline   Reply With Quote
Old 05-09-2009, 12:22 PM   #292
DS1
Vendor
Member#: 111780
^^ Nice info
Jeff- btw I might have a new ECu you might want to try
-Dylan
DS1 is offline   Reply With Quote
Old 05-11-2009, 12:33 AM   #293
JMK167
Member#: 210981
1995 Impreza L Coupe
RED
what is a h-6?
JMK167 is offline   Reply With Quote
Old 05-11-2009, 12:34 AM   #294
JMK167
Member#: 210981
RED
what is the diffrence between my impreza L and a 95 Brighton Coupe
Old 05-11-2009, 12:59 AM   #295
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Originally Posted by JMK167 View Post
what is a h-6?
A flat six engine.
Carter is offline   Reply With Quote
Old 05-11-2009, 07:28 AM   #296
amirul
Member#: 198594
02 Bugeye WRX
Candy Red
alrite, i juz acquire this unfinish project car. my question is, looking @ the pics what suggestion have u got for me. it look like the motor sit too close to the radiator, but juz have enough clearance. My question is, is it possible to move the motor furthur back to firewall???
Any help or suggestion will be greatly appreciated!! Im from Sydney, Australia BTW.
amirul is offline   Reply With Quote
Old 05-11-2009, 02:49 PM   #297
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Yes the engine is close to the radiator. All EG33 H6 swaps into Imprezas will have that issue without converting to RWD to nullify the need for aligning the front axles. Some do try to scoot it back. DS1Motorsport's company project EZ30D swap is scootched back some but not much. The EG33 is a LONG engine so the better option would likely be to just move the radiator a little more forward. BTW.... THAT"S A HUGE F'ING TURBO! :drool: So what about the project is unfinished? Looks mostly done to me. Anywho good luck and let us know if we can answer anything else.
-Gaddis
Old 05-13-2009, 09:59 AM   #298
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
One is yours and one is not?
Old 05-13-2009, 10:13 AM   #299
Homemade WRX
Member#: 33782
96 bastard child
-Gaddis
Did you even look at where his radiator is in the second pic?
You can move the motors back but its just a little bit. You start running into other issues aside from front axle length, driveshaft length, changing mounting holes on trans and motor, shortening the pitch mount, start to have issues with power steering lines and location as well...oil pan to x-member clearance too.
A few things to think about for a little bit of room
Old 05-13-2009, 10:15 AM   #300
Slack
Member#: 17548
The Brighton was the stripped down AWD model. I believe it only had the 1.8l (not positive). The L had more luxuries and the 2.2l.
Slack is offline   Reply With Quote
Vag-Com cable resource thread cooleys04 Open Source Reflashes 277 09-07-2016 03:25 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
