Old 11-05-2011, 02:21 AM   #1076
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Oh and anyone wanna buy my second EZ30R longblock?
Seraphinwolf is offline   Reply With Quote
Old 11-05-2011, 10:07 AM   #1077
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Old 11-05-2011, 04:52 PM   #1078
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
^^^^how many times have I asked if you were gonna sell that spare engine
funny to see that my guesses based on the short block geometry was right. I think the cranks are failing not only because of the crank offset but also because the bore spacing tightened up a lot and added more stroke which puts more force on less material for the throws. Look at the overlap between the journals.
Old 11-05-2011, 04:57 PM   #1079
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Hey I said I might! Buy it!!!! AND MAKE THE DAMN FLANGES!!!
Old 11-06-2011, 01:04 AM   #1080
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Now here's a good one.... Either custom headgaskets or plain the heads to increase compression with the EZ's... Problem obviously being the timing cover still has to fit. Any thoughts on it?
Old 11-06-2011, 01:33 PM   #1081
Fuj1wara
Member#: 249207
2010 STi SE
Deck the head, polish for a stupid smooth surface, copper o ring it, polish shortblock mating surface, high tensile strength head studs. At that point it may possible to run without a gasket. Have seen a rather aggressively built engine that got rid of gaskets. It was a billet bottom end, but with proper machining, you could be able to achieve the proper surface. The other option would be O ring all the passages in addition to the cylinder portion. I think between decking the head and this trick to eliminate gaskets all together you would be able to achieve rather high compression. 12 or 13 to 1 is my estimate without doing the math. The question is do you want to do all that machining. I'm thinking you are trying to find a cheap way to reduce cost, yes?
Fuj1wara is offline   Reply With Quote
Old 11-06-2011, 01:38 PM   #1082
Seraphinwolf
Member#: 150922
97 OBS EZ30R
The question wasn't on decking the head but the fact that the EZ's timing cover is solid and a seal for the oil as well. I want to deck the head to 9.0:1 with Supertech 8.5:1 pistons for that 0.5:1 more compression with boost.
I have zero issue about how or why's TO do it. It's how do I get past the timing cover issue?
Old 11-06-2011, 04:27 PM   #1083
Fuj1wara
Member#: 249207
2010 STi SE
You're saying that if you deck the head 20 thou or so that the timing cover will no longer fit properly? Idk, but are the timing cover pieces so precisely machined that a 40 thou difference or even 80 thou difference will make it not fit?
Old 11-06-2011, 04:35 PM   #1084
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Is looking to be the case. I don't want to deck the head only to find I can't fit the heads back on with the timing cover. 8.5:1 is fine with boost and the BW S366, but having 9:1 could def pull a LOT more out of it.
Old 11-08-2011, 11:36 AM   #1085
Drews
Member#: 203951
Originally Posted by nakens View Post
Anyone have a EG33 ecu they want to sell? Just got a '94 EG33 and wiring harness but need to find an ECU.
I have an OBDII ECU and an OBDI ECU for an EG33 layin around that came with the parts in the car. I don't know if the OBDI is any good though. I bought one off eg33GC to be safe.
Originally Posted by eg33GC View Post
me. ****ing usps lost/has drew's original one I did for him
And it was much appreciated, sir. Of course the part I need to reassemble the damn car is on backorder
Originally Posted by Moose88 View Post
DREWS, your RS is never gonna run.
GTFO troll!
Drews is offline   Reply With Quote
Old 11-08-2011, 07:34 PM   #1086
Homemade WRX
Member#: 33782
96 bastard child
I'll trade you flanges for that knocking long block
Old 11-08-2011, 09:12 PM   #1087
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Get custom pistons made for your desired compression. Outfront motorsports gets custom JE pistons made. They are 1k though I believe unless you could just contact JE directly and tell them to make them.
Ben
Old 11-08-2011, 09:17 PM   #1088
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Or for <$480 I can just deal with 8.5:1 Supertech's and still be happy. I'm still trying to stick to SOME kind of budget... :hide:
Old 11-08-2011, 09:48 PM   #1089
PHATsuby
Member#: 13617
2001 Legacy GT back
Right I mean I would go for 8.5:1 anyways and the cheaper setup personally but didn't know how much it was worth to you, if you were looking to deck the heads, not sure how much that costs, if you add it to the 480 maybe it was close the the JE's and you could use all the stock covers with no worries.
Ben
Old 11-10-2011, 09:42 AM   #1090
Drews
Member#: 203951
Who wants to come to my house and do all the work that I don't want to?
Old 11-28-2011, 11:30 PM   #1091
Seraphinwolf
Member#: 150922
97 OBS EZ30R
What was the last we left off talking engine management again? Did we talk Vipec? I know Hydra, Link, and AEM we brought up...
Old 11-29-2011, 08:25 AM   #1092
Duderotomy
Member#: 128726
1990 Nissan Skyline
2007 Forester XT Sports
not sure but my plans include a ViPec V88... eventually.
did AEM offer something that works with the EZ's?
And does anybody know how well the ViPec is at controlling the factory gauges?
Duderotomy is offline   Reply With Quote
Old 11-29-2011, 09:04 AM   #1093
Seraphinwolf
Member#: 150922
97 OBS EZ30R
I was looking at the V88 also, one of our tuners at the shop said he's seen a few work well with Subarus. AEM does not offer one specific to them but it's just the extra cylinders and mapping. I was gonna email them tonight and start asking. Especially if they are willing to help with an EZ specific one. I still want to do a tandem ECU set on mine.
Old 11-29-2011, 01:17 PM   #1094
Duderotomy
Member#: 128726
1990 Nissan Skyline
I would assume that since AEM has something to work a VQ35 that something for an EZ3X shouldn't be too far fetched.
Old 11-29-2011, 02:42 PM   #1095
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Oh it definately can... It's just adding up all the options... I really want to just go AEM. I just want to do as little wiring as possible.
Old 11-29-2011, 07:20 PM   #1096
iana
Member#: 252934
If you're going with AEM, you may as well just ditch that and throw some carbies on it.
For heavens sake, a vipec v88 runs it out of the box.
iana is offline   Reply With Quote
Old 11-29-2011, 07:43 PM   #1097
PHATsuby
Member#: 13617
2001 Legacy GT back
Is Autronic able to run the EZ30R? I assume if one is considering the Autronic the Vipec can do it equally as well?
Ben
Old 11-29-2011, 10:06 PM   #1098
jjelsma
Member#: 30853
2005 Legacy GT/STi
Newbie question: What's the advantage to using a tandem ECU. Tandem as in a standalone and an OE ez30r ECU?
Thanks!
jjelsma is offline   Reply With Quote
Old 11-30-2011, 05:17 PM   #1099
Fuj1wara
Member#: 249207
2010 STi SE
That's also kind of an odd way if phrasing things in my perspective also. Hydra calls it parallel, where the OEM will take care of gauges and still show as good on inspection but does nothing to control the engine.
Old 12-01-2011, 01:20 AM   #1100
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Not OEM EZ ECU. Four banger ECU. There would be no advantage of the EZ ECU since that's what cause all the problems. The idea is let the car just act like a normal Subaru with the actual motor controls being taken care of by the stand alone. Allows for ODB2 plug ins for inspection and you still have a legal factory ECU in thee that's able to give whatever emissions your state requires. All factory ECU will read all the incoming signals from the motor and give all the green lights without actually have a say of telling the motor what to do.
Vag-Com cable resource thread cooleys04 Open Source Reflashes 276 07-13-2016 07:22 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
