Old 04-05-2012, 09:58 PM   #1176
2006eg33
Member#: 315603
2006 Impreza
CGM
i have an eg33 2006 impreza
gotta say, i dont know why more people dont do this swap, took about 2 weeks and stupidly simple
2006eg33 is offline   Reply With Quote
Old 04-05-2012, 10:15 PM   #1177
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Emissions thst's why.
Seraphinwolf is offline   Reply With Quote
Old 04-05-2012, 10:18 PM   #1178
2006eg33
Member#: 315603
2006 Impreza
CGM
here in ontario its e tested as a hotrod, so its only held to 1980`s emissions standards.
but if anyone needs help, especially swapping into a latermodel. i can provide lots of info
Old 04-05-2012, 10:27 PM   #1179
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Which doesn't work in mos of the US. EG33's are easy to swap once you decide what your choice of radiator options you wish to use. EG's are swapped in first gen Imprezas all the time.
Old 04-05-2012, 10:49 PM   #1180
2006eg33
Member#: 315603
2006 Impreza
CGM
i used the stock rad. few small differences between the gc and gd. like starter bolt, gas pedal, fuel system, fuel pump controller. etc
Old 04-06-2012, 06:41 AM   #1181
TexasLegacy2.5GT
Member#: 282365
2006eg33, that looks GREAT! How does it sound? If you know the "right people" here in the states you can pass inspection no problem. I really like the fact that you followed through with your swap. Most of the people on here never finish their swap and just become jealous. Ignore the haters and shine!!
GOOD JOB!!
Did you go with 5spd or is your car an auto? The Eg33 eat auto's all the time, no?
TexasLegacy2.5GT is offline   Reply With Quote
Old 04-06-2012, 09:48 AM   #1182
2006eg33
Member#: 315603
2006 Impreza
CGM
car is 5speed.
right now its open headers, so its really loud.
Old 04-06-2012, 10:14 AM   #1183
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Wow thats awesome. Thats what i want to do next but with twin gt30s. About how much you spend?
Old 04-06-2012, 10:37 AM   #1184
2006eg33
Member#: 315603
2006 Impreza
CGM
1300 dollars so far, and that includes an entire 1992 svx
Old 04-06-2012, 12:23 PM   #1185
Seraphinwolf
Member#: 150922
97 OBS EZ30R
4eats are not all the same FYI. Depending on year they changed thing around.
He def did a good job! Have you had a chance to go on a dunno or do any logging?
Old 04-06-2012, 04:52 PM   #1186
2006eg33
Member#: 315603
2006 Impreza
CGM
probably wont have dyno numbers untill summer sometime, got a few bugs to work out
Old 04-06-2012, 06:09 PM   #1187
TexasLegacy2.5GT
Member#: 282365
EG33, looks like a clean swap. Rator makes a great supercharger for the H6...
Old 04-07-2012, 08:12 PM   #1188
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
just out of curiosity, you guys running stock NA H6 swaps, whats your fuel economy like?
Loomin is offline   Reply With Quote
Old 04-07-2012, 10:06 PM   #1189
2006eg33
Member#: 315603
2006 Impreza
CGM
i'll update after my first tank of gas, but i expect highway mileage to suffer considerably. but in town mileage to increase. i'm able to cruise around in 5th at like 1500 rpm.
Old 04-07-2012, 10:27 PM   #1190
TexasLegacy2.5GT
Member#: 282365
What final gear ratio are you using with your EG33?
Old 04-07-2012, 10:32 PM   #1191
2006eg33
Member#: 315603
2006 Impreza
CGM
maybe in the future i'll do 4.444
Old 04-07-2012, 10:57 PM   #1192
TexasLegacy2.5GT
Member#: 282365
3.9 final? Is that stock for the WRX? My ole 99' LGT has a 4.11 final drive ratio. I know I'll need to drop that old gear box out when I swap motors.
Old 04-08-2012, 09:35 AM   #1193
2006eg33
Member#: 315603
2006 Impreza
CGM
its the 2006 2.5i stock final gear.
if you're doing an eg33 swap, any trans will work. my knowledge is limited on ez motors, so i cant comment on them.
Old 04-09-2012, 08:55 AM   #1194
CatfaceType-R
Member#: 81102
Can u please take some pics of firewall clearance and front of engine radiator and bumper clearance. Thx
Also what em are you using? Any other info is great. U make it sound so simple, I don't think a turbo or two would change much, but packaging. I saw a guy have to rewire his whole car, I wonder if it's because of your model year? I'll just let u answer, btw u mind if I shoot u a pm sometime soon?
Thx, carmi
CatfaceType-R is offline   Reply With Quote
Old 04-09-2012, 04:59 PM   #1195
2006eg33
Member#: 315603
2006 Impreza
CGM
i am using the svx ecu, and the 2.5i ecu
2.5 controls starter, alternator, and all the body systems
3.3 controls only the engine. i ran a relay from the 2.5i ignition signal wire to the ecu, which went to the self shut off, ignition signal, and control unit power supply pins on the svx harness. then tapped the svx starter signal, and back up power supply to the respective wires from the 2.5i harness
i ran a second relay to the fuel pump, to run it at full duty since the svx ecu wont control the 2.5i fuel pump controller.
thats it for wiring.
firewall clearance is the same as the 2.5i, infact the 3.3 air intake bolts up to the stock airbox.
rad support clearance isnt too bad. i have about 3 - 3.5 inchs from the crank pulley to the rad support. i just moved the rad directly infront of the support, then trimmed the headlight brackets and the bumper
Old 04-09-2012, 06:51 PM   #1196
juanmedina
Member#: 133146
Nice, What are you using for tuning?
Old 04-09-2012, 07:14 PM   #1197
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Any reason you didn't choose to use a standalone to run the EG33 if you are doing a tandem ECU setup? That's how mine will be setup for running my EZ30R and still passing plug in tying in an STi ECU.
Old 04-09-2012, 08:52 PM   #1198
2006eg33
Member#: 315603
2006 Impreza
CGM
unfortunately for me the svx ecu doesnt allow me to tune it, i used this set up, because i had the ecu from when i stripped the svx, and i just wanted it running.
down the line though i plan to run a megasquirt, but for now, it runs and its fun
Old 04-09-2012, 09:30 PM   #1199
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Yeah I had a Megasquirt for my SVX but then sold it when I was out of work. :-/ Still not sure which exactly I'll end up with for the EZ30R. AEM or ViPec but one of them...
Old 04-09-2012, 10:16 PM   #1200
2006eg33
Member#: 315603
2006 Impreza
CGM
well when i get my megasquirt, i'll have to pick your brain about setting up the sensors. did you use the stock crank and cam sensors? or retrofit an edis-6 system?
Vag-Com cable resource thread cooleys04 Open Source Reflashes 277 09-07-2016 03:25 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
