Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 05-08-2013, 10:24 AM   #1451
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Yes I have looked into that. You can get rid of the valve lift stuff by using EZ36 intake cams, valves and springs. Then you won't need to upgrade the oil system, it will be fine. You will probably end up with better driveability too. Maybe lose 10-15 hp though. Oh but gain much better fuel economy.
Marnix is offline   Reply With Quote
Old 05-10-2013, 09:19 AM   #1452
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Should be assembling the EZ30 short block this afternoon after work. Had to order some new alignment pins (from block to heads), but those are supposed to be at the dealer today.
Edit: Dealer ordered the wrong parts (the block to trans pins). Amazingly enough, the correct part number was the one that I gave her when I ordered the pins, but she said that was an '05+ part number and that there was a different number for the '01-04s. *sigh*
Very interesting. You didn't mention the lifters - no need to change those out?
Patrick Olsen is online now   Reply With Quote
Old 05-11-2013, 04:09 PM   #1453
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Got the short block together at the machine shop today and brought it home and mounted it back on the engine stand. Still need to put the oil pan(s) on. Block-to-head pins will get to the dealer on Tuesday, after which I can do the heads. No real hurry, since I still have to do all the electrical stuff and I don't even have the harnesses yet.
Received the OBX header, plus a couple little baby Magnaflow spun cats and a new Y-merge.
I don't know if the cats will go in ahead of / upstream of the flexes, or if I'll just ditch the flexes and put the cats in their place. (AFAIK the stock manifolds don't have flexes like that, so I'm not sure what the need is. They're huge flexes, too - I'm used to ones about 1/3 or 1/4 as long.)
Old 05-12-2013, 11:53 PM   #1454
vicious_fishes
Member#: 158864
2003 GD w/EZ30D swap
about to get my mits on a JDM my03 legacy. ez30R, automatic, NO IMMOBILISER, FULL FRONT CLIP.
can get it running if i just do a complete harness swap but i'm sure i'll end up losing interior lights, central locking etc. no idea if the gauge cluster is going to be plug & play from my my03 rs either.
fun times ahead. anyone help me out here RE: what's plug & play on the harness?
i know i need to do something to convince the ECU that it's not always in neutral but no idea how to do that?
vicious_fishes is offline   Reply With Quote
Old 05-13-2013, 10:33 AM   #1455
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Sorry my mistake - yes, you need to use EZ30R exhaust lifters on the intakes.
Old 05-14-2013, 04:17 PM   #1456
vicious_fishes
Member#: 158864
alright so what's this trickery with getting the ECU from an auto to play nice with a manual. what do i have to do?
Old 05-14-2013, 06:12 PM   #1457
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
EZ30D or EZ30R or EG33?
The answer varies greatly depending.
For the EZ30D, it's fairly simple. Some modifications of the ECU pins & mild TCU trickery should do it; you should be relatively CEL-free and be able to maintain cruise control and ABS.
http://www.rs25.com/forums/f145/t155...z30d-swap.html
For the others, I have no idea. I know the EG33 is OBDI, but it's a more common swap so other people might know. The EZ30R has AVCS and stuff, so I hear it's much more annoying.
TurboLag23 is offline   Reply With Quote
Old 05-15-2013, 10:21 AM   #1458
dragoontwo
Member#: 275500
1992 SVX
In my SVX when I went to a 6 speed, all I did was remove the TCU and wire the clutch switch, and reverse switch into the appropriate wires. The ECU doesn't care about a manual box as long as you do not hook a tcu up.
dragoontwo is offline   Reply With Quote
Old 05-15-2013, 11:45 AM   #1459
vicious_fishes
Member#: 158864
EZ30D. rummaging through the RS25 thread now. i've got a complete front-clip. full harness & all.
Old 05-15-2013, 03:54 PM   #1460
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Sweet.
Keep us updated Haha the more EZ30D + manual trans. build threads, the better. You gonna be running a 5MT or a 6MT?
Old 05-15-2013, 05:29 PM   #1461
Subachouli
Member#: 98777
1970 MGB GT
..and some Subarus
Sweet.
Seconded and subscribed. I'd love to pick up a third generation 3.0 Outback wagon, make it more like a Legacy GT, and convert it to manual transmission. Ideal daily drivah. Only problem is getting it to pass OBD2 inspection in MA with whatever check engine light will be present with the manual swap.
Subachouli is offline   Reply With Quote
Old 05-15-2013, 06:32 PM   #1462
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Lol that's basically my plan for mine. STI drivetrain (6MT, R180), LGT axles, LGT or STI steering rack, LGT brake calipers with aftermarket pads/rotors, coilovers, UEL headers, and a tune.
Now, to get the money to fund that.... Hahaha.
Old 05-15-2013, 07:29 PM   #1463
vicious_fishes
Member#: 158864
Sweet.
5mt. i want to just drop the whole lot into my current GD chassis, so the engine/ECU don't think anything is different at all. problem is it's not quite that simple - apparently i need to wire the transmission control unit so it thinks it's always in gear, MIGHT need to work something out for the fuel pump controller, and no idea if the harnesses are going to plug & play with the current plugs for the lights, locks, ignition key etc. thankfully it's a non-immobiliser type.
unfortunately it's going to be $3.5k to land it all here to find out and to say i hate wiring is an understatement.
Old 05-17-2013, 12:55 PM   #1464
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
So which is it? (I know that really they're all EZ30Ds, but everyone calls the higher HP, plastic intake manifold, AVCS/AVLS version the EZ30R for clarity.) If it's an EZ30D, then the link that was posted to Dyne's swap over on RS25 should help. There are also a few threads here from anders8 about putting an EZ30D into his rally car and running it with a manual transmission. If it's an EZ30R, as you originally said, then I don't know exactly what it would take.
Old 05-17-2013, 03:30 PM   #1465
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
There isna guy on here that got his hands on an EDM Legacy 3.0R Spec B harness and swapped the whole harness and dash into a Forester with the motor. Runs and everything. The trick he found was getting the chipped key resynced with a brand new I programmed US key ar a dealership and it fired up.
Seraphinwolf is offline   Reply With Quote
Old 05-18-2013, 01:55 AM   #1466
vicious_fishes
Member#: 158864
error first time around. EZ30D. single port heads, cable throttle, no AVCS.
Old 05-18-2013, 04:41 PM   #1467
vicious_fishes
Member#: 158864
thanks mate but i don't want to swap the dash too. if the plugs will plug into the heater controls, radio etc in my current dash then that will be awesome but otherwise i'll be getting a professional wiring technician to merge the harnesses. i'm sticking to the KISS principle.
Old 05-21-2013, 02:45 PM   #1468
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Got it. Then we're in the same boat, albeit I'm working with a 6MT and an older chassis.
Old 05-21-2013, 11:14 PM   #1469
vicious_fishes
Member#: 158864
mm i've got a full front clip. i'm tempted to see if i can just transplant the harness from the front clip into my GD. might have a few teething issues like having to rewire the fuel pump or something but they're much simpler than merging harnesses.
Old 05-22-2013, 02:53 PM   #1470
vicious_fishes
Member#: 158864
front clip paid for. now to organise shipping... (well it's quoted. just got to book it in a few hours. i'm really hoping they just ship it port to port rather than road to port to ship to port to road again).
Old 05-22-2013, 06:56 PM   #1471
RedMonkey999
Member#: 191476
2002 2.5RS AW
2007 FXT OBP
I saw a JDM EZ30 engine attached to a 6MT on ebay the other day, and it made me do some digging. According to the Rallispec transmission ids chart, some of the JDM Legacy 3.0Rs came with a 6-speed manual transmission.
Has anyone tried using the ecu from one of those vehicles for a swap?
Edit:
They do exist: http://www.japan-partner.com/Auto/10...-for-sale.html
Found some part numbers for the 6MT ECUs: http://opposedforces.com/parts/legac...llustration_1/
Last edited by RedMonkey999; 05-23-2013 at 12:54 AM. Reason: ECU part numbers added
RedMonkey999 is offline   Reply With Quote
Old 05-23-2013, 10:12 AM   #1472
vicious_fishes
Member#: 158864
anyone know if you can swap the ez30 shortblock with the ez36?
basically an H6 hybrid build?
redmonkey - i'm having a tough time finding the 2003 JDM B4 wiring diagram. you got a line on jap diagrams by any chance?
Old 05-23-2013, 10:26 AM   #1473
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
A high compression, franken-motor h6 would be dope!
...or even just a regular h6 with high compression.
RavensFan7 is online now   Reply With Quote
Old 05-23-2013, 11:00 AM   #1474
RedMonkey999
Member#: 191476
2002 2.5RS AW
2007 FXT OBP
I'm so glad you asked, because I just found an awesome site. I think you should be able to find what you need here: http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/
And here's the full FSM for the 2007 Legacy (including the 3.0R 6MT model!): http://jdmfsm.info/Auto/Japan/Subaru...007/index.html
I'm pouring over the wiring diagram now. It looks so similar to how the '02 Impreza is setup for AT vs. MT, it's giving me hope!
Old 05-23-2013, 01:30 PM   #1475
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Nope, nothing interchanges. Crankshaft of an EZ30D does not fit EZ30R or EZ36R or the other way around. Also heads do not interchange.
Vag-Com cable resource thread cooleys04 Open Source Reflashes 271 03-26-2015 02:13 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
