Closed Thread
Old 08-11-2007, 12:19 PM   #1
litowrx
Member#: 132418
2004 EJ207
Default Most important gauges?? also prosport gauges question!
Hello guys if you guys where to use some gauges to monitor your engine despite modifications, in what order would you buy them???
wich is the fundamental order to own this gauges...
BOOST
EGT
OIL TEMP
OIL PRESSURE
FUEL PRESSURE
AIR FUEL
i think first is
1. BOOST
2. ???
3. ???
4. ???
5. ???
6. ???
also i have a question i saw this video and wanted to ask if this is possible
http://www.youtube.com/watch?v=dj22OSz6B3A
aparently this guy has a green/white 52mm boost gauge, but he gets the 3 colors is this posible with this gauges...amber gauges will display green and viceversa??
thanx guys i hope you guys will help me, pardon my english, its my foreign language!
litowrx is offline
Old 08-11-2007, 12:27 PM   #2
LewisWORX
Member#: 63001
02 WRX Stg. II PnP
I think boost, oil pressure, egt temp and afr, knock are the most important if you ever plan on tuning. I have all of those and it makes it way easier to see the results of changes. I have 3 glowshift gauges that have 7 colors and I have had nothing but consistant accurate readings from them. If you are just using something like AP then I would think you could get by with just a boost gauge. Oil pressure gives you a good idea if your oil is too thin (or if you oil is low), and egt will just give you piece of mind that you aren't running too hot.
LewisWORX is offline
Old 08-11-2007, 08:17 PM   #3
jfdavis22885
Member#: 145716
08 Lexus IS 350
05 WRB WRX Stg2 (Sold)
i can get red with my green and white prosport, i forgot what wires need to connect to get the effect, bu just test them out when your installing it
jfdavis22885 is offline
Old 08-11-2007, 09:13 PM   #4
dibblejr
Member#: 94070
05 LGT
Boost, EGT, OIL Pressure.
Jay-R
dibblejr is offline
Old 08-11-2007, 09:47 PM   #5
MarineSniper
Member#: 155728
2007 WRX Limited
Do your GS gauges have a Indigo or something close to the WRX dash colors? I've been trying to figure out what will match.
MarineSniper is offline
Old 08-12-2007, 12:52 AM   #6
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Jay-R
+1
Noah is offline
Old 08-12-2007, 12:53 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Unabomber is offline
Old 08-12-2007, 12:55 AM   #8
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Ron do you ever get tired of moderating this forum?
Noah is offline
Old 08-12-2007, 09:05 AM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Not really...I usually don't post here much anymore, just keep an eye on the threads to make sure this is a flame free forum.
Old 08-12-2007, 05:53 PM   #10
Kuper
Member#: 151755
Thats what i got... Boost,EGT,Oil Pressure.
Kuper is offline
Old 12-10-2007, 12:35 PM   #11
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Doh! Moved to the other ol' thread...
Beanboy is offline
Old 12-10-2007, 04:41 PM   #12
john_eldorado
Member#: 164787
I was curious why you would rate Exhaust Gas Temperature over oil pressure. I don't have any experience with turbo-charged cars, but do have more experience tuning older "carbed" cars, and in my experience, the most important "non-factory" gauges is your oil pressure and temp, since you can destroy your engine so quickly if their is a problem in those departments.
Is this because the motor is turbocharged , and it will display if detonation is occurring? Would an Air/Fuel gauge do the same thing?
Thanks
john_eldorado is offline
Old 12-10-2007, 04:59 PM   #13
Uncanny
Member#: 133012
2015 STi
Lightning Red
EGT can give you a good indication of your AFR, thats why its higher than oil pressure. The only thing better than an EGT would be a Wideband O2 AFR
Uncanny is offline
Old 12-10-2007, 05:38 PM   #14
CynicX
Member#: 48199
06 WRX
Thanks
Once you modify your car the oil pressure should be fine. Its a good idea to keep an eye on it as low oil pressure can destroy a motor but generally unless something is going terribly wrong (failing pump, low oil) you wont have a problem.
EGT will let you know when you are about to destroy your motor from racing it. You want to keep it around 1600-1650 max. Anything above that will take its toll on the motor, and eventually melt something. IE a piston...
A wideband A/F is also a very nice gauge to have....Although I'd rather have EGT then a wideband if you are not tuning the car yourself. If you are, then wideband is a must IMO....
CynicX is offline
Old 03-23-2012, 04:20 PM   #15
jlien619
Member#: 296522
2008 WRX
Dark Gray
Has anyone used the prosport gauges? how are they? im looking into buying a oil pressure/and boost gauge from prosport. How reliable are they?
jlien619 is offline
Old 03-23-2012, 05:12 PM   #16
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Search in our car parts review forum with the keyword prosport.
Closed Thread
WTB: Autometer bezel gauge pod + Prosport gauges maxipad Private 'Wanted' Classifieds 8 11-23-2009 04:23 AM
F/s autometer gauge pod, prosport gauges, lamco, greddy sn3akyducky Interior/Dressup/Audio & Security 12 10-14-2008 12:04 PM
ATI Gauge Pod / Prosport Gauges bundle "B" Interior/Dressup/Audio & Security 5 08-04-2008 11:52 AM
Most important gauges?? also prosport gauges question??? litowrx Newbies & FAQs 2 08-11-2007 12:27 PM
what is most important to monitor w/ gauges? Vampyr Interior & Exterior Modification 30 09-27-2005 08:34 AM
