Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 08-11-2007, 12:52 PM   #1
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default 02-05 vs. 06-07 WRX / STI Exhaust Manifold
I know alot of people always have questions/doubts about the difference between the 02-05 and 06-07 wrx exhaust manifolds....they are in fact different. All of the 02-05 wrx's and 04+ sti/lgt exhaust manifolds are the same...only the 06-07 wrx's are different.
The differences are minor:
-crosspipe in the 06-07 only has one bend compared to the others
-passenger side collector in the 06-07 has a longer/narrower turn back going from the exhaust ports to the up pipe
-driver side collector in the 06-07 is almost identicaly to the rest except for it has a slightly smoother 90* bend. the easiest way to tell what year the driver side collector is is by the positioning of the egt tap button in relation to the divider line between the two ports.
With this side, you absolutely can not fit an 06-07 crosspipe onto an 02-05 wrx design. i've seem some retailers out there saying the pipe fits all years, but this is not true. with that being side...we'll have an option for you 06-07 guys asap
also, you CAN swap out complete manifolds from 02-05 vehicle to 06-07 but not other way around. you CAN NOT mix match parts from the different designs. for example, no putting an 06-07 crosspipe together with the 02-05 end collectors.
oh, and there is no difference in the 02-05 wrx and 04+ sti exhaust manifolds...peopel think the sti is a high performance piece but it simply isnt.
02-05 wrx, 04+ sti/lgt
06-07 wrx
hope that clears it up.
Justin
www.grimmspeed.com
GrimmSpeed is offline   Reply With Quote
Old 08-11-2007, 12:57 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
i guess i should have arranged the pieces in the pics to be the same...o well
Old 08-11-2007, 02:28 PM   #3
DZnutz
Member#: 91837
so which design is better?
DZnutz is offline   Reply With Quote
Old 08-11-2007, 04:33 PM   #4
EMS
Member#: 14116
Justin,
You forgot to tell the 06-07 cast pieces do have thinner wall thickness, they are lighter. Furthermore the 06-07 complete manifold will not fit the older cars or STi! (the crosspipe will not clear the oil filter)
Mark.
EMS is offline   Reply With Quote
Old 08-11-2007, 04:56 PM   #5
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
So dose any one know of one will out flow the other?
And I wish mine where nice and black like that! But there rusty. Oh well Ill just rap them and call it good!
Later.
Badmunky is offline   Reply With Quote
Old 08-11-2007, 05:28 PM   #6
EMS
Member#: 14116
Later.
I didn't measure exact dimensions, as it isn't easy to measure the inside dimensions... But they seem quite identical to me. (except for the outer dimensions!)
Mark.
Old 08-11-2007, 07:27 PM   #7
mrcoder
Member#: 93785
2005 STI
Default good pix
+1 to the thread creator
Facts and pix are good.
mrcoder is offline   Reply With Quote
Old 08-12-2007, 12:16 AM   #8
OKR S06
Member#: 116105
2001 Civic/2006 WRX
Blue/Steel Grey Metallic
Yea....
I found out the hard way on this by using my friends 05 STi driver side manifold to drill and tap for an EGT. Pulled mine off, put my friends manifold on my car and it wouldn't bolt together. So I had to tap mine and now my friends manifold has a nice hole in it. Don't worry he has a header on his car.
OKR S06 is offline   Reply With Quote
Old 08-12-2007, 11:54 AM   #9
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
i'd say the are about equal.
Originally Posted by EMS View Post
Justin,
Mark.
truth. the 06-07 definitely has a thinner wall. i know the older mani's will fit on the new stuff...but i thought i fit a newer mani on the older cars too....maybe not though.
Old 08-25-2007, 03:15 AM   #10
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Question, so the x-over pipes are specific to 06-07wrx and the other models? I wanna send an 06 wrx mani but I guess I cant use the v1 xover with it?
Magnum626 is offline   Reply With Quote
Old 08-25-2007, 04:36 AM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
06+ manifold require 06+ crossover
02-05 manifold requires 02-05 crossover
can't mix and match.
Nuke209 is offline   Reply With Quote
Old 08-25-2007, 09:49 AM   #12
wrxhard
Member#: 108091
Good to know.
wrxhard is offline   Reply With Quote
Old 08-25-2007, 10:18 AM   #13
Tea cups
Member#: 103136
what about the FXT?
Tea cups is offline   Reply With Quote
Old 08-25-2007, 11:25 AM   #14
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
OMG 08 mess!!!
Old 08-25-2007, 01:12 PM   #15
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by Unabomber View Post
OMG 08 mess!!!
That's nasty, ewwww
Old 08-25-2007, 08:13 PM   #16
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
OMG 08 mess!!!
Originally Posted by Nuke209 View Post
That's nasty, ewwww
NO WAI!! thats equal length!!! hell ya...
All4bSpinnin is offline   Reply With Quote
Old 08-25-2007, 08:41 PM   #17
Magnum626
Member#: 62856
MBP SQC#197
So the grimmspeed x-over is for 02-05 wrx and sti 04+ correct?
I guess I have to try and hunt down another set of manis.
Old 08-26-2007, 12:24 AM   #18
neverendingmods
Member#: 23796
2006 STi
white
also, you CAN swap out complete manifolds from any year vehicle to another. for example you can put an 02-05 wrx manifold on an 06 wrx as long as you swap over the entire thing. you CAN NOT mix match parts from the different designs. for example, no putting an 06-07 crosspipe together with the 02-05 end collectors.
06-07 wrx
Justin
www.grimmspeed.com
Very important to know. Some vendors do a core charge and want you to send in stockers after receiving PNP stockers. I've always read the arguements on the " 06-07 header difference" between other years. Pics. don't lie. Thank you.! Also, a strighter pipe always out flows one w/more bends.
neverendingmods is offline   Reply With Quote
Old 08-26-2007, 10:45 AM   #19
Nuke209
Member#: 108089
2003 WRX
NF Performance
Yes, I'll have to correct myself
06+ wrx can only use 06+ wrx crossover
02-05wrx / 04+ sti manifold to only use 02-05wrx / 04+ sti crossover
06+ wrx crossovers....anything on that Grimmspeed?
Old 09-03-2012, 12:32 PM   #20
gregroot198521
Member#: 280844
2006 STi
So, bringing this thread back from the dead: just to make sure I'm getting this right. So the 02-05 & the 08+ WRX have the same headers and x-pipe as the 04+ STi. So by that knowledge, it would be safe to say that if I do hop from my 11 WRX into an 07 STi, I can transfer the exhaust manifold, x-pipe and UP over. Am I understanding right?
gregroot198521 is offline   Reply With Quote
Old 09-03-2012, 06:21 PM   #21
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
You are correct, all of those are the same!
Mike
Old 09-04-2012, 10:53 PM   #22
gregroot198521
Member#: 280844
2006 STi
Mike
Awesome, thanks for the info!! Now here's hoping I have some luck in finding someone willing to sell their stockers...... That, or some lucky bastard will get my car with the PnPed & coated GrimmSpeed headers.... Not if I can help it.....
Old 08-03-2013, 03:51 AM   #23
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
This thread answered all of the questions I was researching
Thanks
rubrduk is offline   Reply With Quote
04-05 & 06-07 Wrx/sti Rear Aprons/spats Lroc130 Exterior/Styling 5 02-20-2010 08:36 PM
07 wrx sti exhaust manifold wrx1321 Engine/Power/Exhaust 0 05-31-2009 03:05 AM
Radiator Shrouds $32+ SHIPPED! 02-05 & 06-07 WRX/STi KillerBMotorsport Engine/Power/Exhaust 16 05-30-2009 01:03 AM
