Old 08-11-2007, 02:16 PM   #1
breakfasteatre
Member#: 131662
1996 Legacy LS
Default Engine mounts dead at only 93 k miles?
My 96 legacy has 93k miles on it. Ive had a rough idle for the past 5k miles or so. I took the car to a mechanic and he said that the rubber in the mounts has deteriorated to the point that the mounts are pretty much just metal now, and that the rough idle is just the vibration caused by there no longer being any rubber to dampen it.
After what happened with the mechanic, i do not trust him. Could this actually be the case?
can i crawl under the car and take a look at the mounts?
breakfasteatre is offline   Reply With Quote
Old 08-11-2007, 08:29 PM   #2
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
You can see the mounts under the car. They will be between the engine block and the engine crossmember, which is just in front of the oil pan (standing at the grille and looking back toward the tailpipe).
Normally you can't tell if an engine mount is worn unless the engine is removed - it's a rubber part so unless it's falling apart it's a bit tough to tell.
It's possible that the engine mounts are shot, but my cars have 93k and 208k on them, with no problems idling.
I bet it's something related to the idle air valve in the car, or maybe a dirty MAF sensor.
Huffer is offline   Reply With Quote
Old 08-11-2007, 10:07 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Stick a jack under the tranny and jack up the motor and watch the motor mounts. If they are toast, they will separate as you jack!
I have toasted one completely in two before myself.
Old 08-12-2007, 12:35 AM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Another way to tell is open the hood up while the engine is running, push the throttle cable to quickly rev the car engine. If the engine moves a whole lot, it's the mounts.
I highly doubt its the mounts though TBH. I just pulled my stock ones out for group N ones and the rubbers look like new after 80k miles and 4 years of NE winter and salt.
rougeben83 is online now   Reply With Quote
Old 08-12-2007, 01:37 AM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I had rough idle and a very very shaky engine when the plug wires and plugs needed replacing. Does it idle smoother when the engine is warmed up? That would rule out mounts as they don't care what the engine temp is...
Wiscon_Mark is offline   Reply With Quote
Old 08-12-2007, 02:44 AM   #6
breakfasteatre
Member#: 131662
1996 Legacy LS
No, the car idles just as bad at all times. I should replace the wires, i was told that was overdue. Where abouts is the idle air valve located?
The mechanic said he cleaned the throttle body, and there was a lot of gunk. It stopped a hesitation problem i was having assumingly from the throttle getting stuck partially closed
Cusco/ Okada/ Engine Mounts/ BOV/ ATP/ Blitz/ GT Spec/ Turbos/ Only at JSC Speed <--- JSC Speed Engine/Power/Exhaust 9 12-08-2008 12:21 PM
radiator is leaking at only 33,600 miles Smythe Service & Maintenance 3 11-20-2008 11:55 AM
2003 WRX Engine mounts, tranny mounts, & pitch stop. 50k miles PhastEddie Drivetrain 2 08-27-2007 06:53 PM
06 STI Engine Mounts, Tranny Mounts, & Pitch Stop mount only 2k miles! PhastEddie Drivetrain 11 02-24-2007 11:41 PM
Dead o2 Sensor only after 9k miles Lever2ooo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-29-2005 11:32 AM
