Old 08-11-2007, 03:18 PM   #1
breakfasteatre
Member#: 131662
1996 Legacy LS
Default In the process of removing all exhaust shielding...
So ive been removing all the heat shielding that was wrapped around the exhaust manifold.
Ive removed all of it before the two sides collect together. Now there is a large shield bolted on beyond the 2 into 1 collection that looks like it is covering a cat. Is this the primary cat and the smaller one right behind it is the secondary?
I can see some sort of sensor plugged into it.
Will it be alright if i remove the shielding? I still have a pretty good rattle going on down there.
I know the cat is one of the hottest elements of a running car, should i just leave the shielding on and get used to the noise?
breakfasteatre is offline   Reply With Quote
Old 08-11-2007, 03:28 PM   #2
breakfasteatre
Member#: 131662
1996 Legacy LS
nevermind, i found the answer
Old 08-11-2007, 03:41 PM   #3
what huh
Member#: 128825
2005 Legacy GT
what did the rattling noise end up being because i have it to
what huh is offline   Reply With Quote
Old 08-11-2007, 04:58 PM   #4
breakfasteatre
Member#: 131662
1996 Legacy LS
exhaust heat shields, and people have removed the shield i was asking about without adverse affects
Old 08-11-2007, 09:30 PM   #5
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
So the answer you found is presumably "it's ok to remove the shielding".
Huffer is offline   Reply With Quote
Old 08-12-2007, 05:37 AM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
There are metal straps under and inside the metal shielding that break over time and allow the outside sheet metal shields to rattle against the pipes. I used ss pipe clamps around the ends of the shields and got no more rattles but some people have removed them entirely.
ss
subysouth is offline   Reply With Quote
Old 08-12-2007, 04:54 PM   #7
breakfasteatre
Member#: 131662
1996 Legacy LS
Alex - 1
heat shield - 5 or 6
finnaly got the bottom off, burned my arm on my work light a couple times, got pretty dirty
now the top part, is the easiest way to remove it is to unbolt the cat?
Old 08-13-2007, 10:41 AM   #8
Huffer
Member#: 36735
99 GF8 Impreza 2.0
I actually just used a short sawzall blade and cut the exhaust shield off the bottom, then twisted the top shield up and sliced it off. It looks a bit ghetto up close, but then no-one's looking underneath this car.
Old 09-09-2007, 04:20 PM   #9
01gtlimited
Member#: 120658
01 LGT Ltd
i most definitely have a rattle coming from the shielding on the manifold runners, before the combine. i "fixed" it temporarily on a couple occasions with hose clamps and such, but the rattle is persistent and i'm tiring of it.
how closely do the manifold tubes run to the steering rack boots on yours? i know on mine, the heat shield is about 1/2 th 3/4 of an inch from the boots. my concern is that cutting the heat shield off will eventually melt the boots, which i really don't want to do. have you had a problem with this yet?
01gtlimited is offline   Reply With Quote
Old 09-09-2007, 05:12 PM   #10
Huffer
Member#: 36735
99 GF8 Impreza 2.0
You won't melt the boots.
Old 09-09-2007, 05:21 PM   #11
01gtlimited
Member#: 120658
01 LGT Ltd
cool. i didn't figure there would be a problem, but i just wanted to check and make sure before i go hacking away. thanks.
Old 09-09-2007, 11:02 PM   #12
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
The answer on here was left at a "Presumably".
So, it's ok to remove the shields with no side effects at all? Will it change the sound at all?
Frogsthatmoo is offline   Reply With Quote
Old 09-10-2007, 01:14 AM   #13
silentracer
Member#: 133136
2006 Legacy GT LMT
Altlantic Blue SQC#?
no, i removed my heat shield near the axleback and no more rattle
silentracer is offline   Reply With Quote
Old 09-10-2007, 10:54 AM   #14
Huffer
Member#: 36735
99 GF8 Impreza 2.0
If you do a search, the answer on here is "No problems with removing heatshields". It is more work to do than just clamping the shields, but you will never have to get under the car again to reclamp them.
The only sound that will change is you will avoid having the shields clanking around. It's purely an aesthetic "mod".
Old 09-10-2007, 12:52 PM   #15
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Thanks huffer.
Maybe that's a project for me today.
Old 09-10-2007, 01:10 PM   #16
Huffer
Member#: 36735
99 GF8 Impreza 2.0
^^ no worries.
in the process of building a VF30 setup. when all is said and done which BOV? 280hp_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-15-2006 11:05 PM
in the process of priming turbo. do i need to unplug all 4 coil pack? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-30-2005 10:05 PM
In the process of buying a 02 WRX. blindstuff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-16-2005 06:25 PM
im in the process of eating a dorito sandwhich svek Off-Topic 17 06-05-2005 04:25 AM
front sway links, anyone in the process of making them tdxflex Brakes, Steering & Suspension 2 07-16-2002 07:31 AM
