Old 08-11-2007, 03:11 PM   #1
epson1
Member#: 122909
2003 Evo 8
Apex Silver
Default Prodrive BCS
is the tunning for the GM boost solinoid the same as the prodrive BCS? vise versa. i'm gonna reflash to XPT Stage 2 with the GM Solinoid but i'm unsure if my prodrive BCS will work with the map
epson1 is offline   Reply With Quote
Old 08-11-2007, 08:49 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Post in the right forum.
Use what you are supposed to use and dont think you can out-think the map maker.
Old 08-12-2007, 07:41 PM   #3
epson1
Member#: 122909
2003 Evo 8
Apex Silver
anyone else whose not an asshat?
Old 08-12-2007, 07:47 PM   #4
Freon
Member#: 88322
2009 BMW 135i
While they should react in a similar way, they may not be exactly the same.
In fact, I've found just changing your vacuum lines (diameter and/or length) will affect how the boost control system reacts.
Freon is offline   Reply With Quote
Old 08-12-2007, 08:39 PM   #5
quazimoto
Member#: 70395
No it will not work the way it is supposed to.
quazimoto is offline   Reply With Quote
Old 08-14-2007, 01:55 PM   #6
ironhead1230
Member#: 66419
2008 STI
While I have read the prodrive and gm are similar I wouldn't trust using that map with the prodrive and not logging and fine tuning. The maker of that map agrees and said he could not guarantee how the car would run with the combo. You could very easily overshoot target boost. If you are comfortable logging and making small changes to the map, it should not be very difficult to tune for the prodrive. You should only have to make small changes to the WGDC tables and the turbo dynamics tables.
-Mike
ironhead1230 is offline   Reply With Quote
Old 08-16-2007, 01:09 PM   #7
EdWRX
Member#: 108068
2016 WRX
I have the GM BCS and runs good, and I assume it's cheaper than the prodrive, anyway the only thing u need to tune with the BCS is WGDC and target boost, so that's pretty easy to tune.
EdWRX is offline   Reply With Quote
FS in MI: Prodrive BCS and Forge BOV MrDrift Engine/Power/Exhaust 6 05-17-2007 11:00 AM
WTB: Prodrive BCS 06rexwagon Private 'Wanted' Classifieds 0 03-24-2007 03:53 PM
FS MI: Forge Atmospheric BOV and Prodrive BCS MrDrift Engine/Power/Exhaust 3 01-17-2007 08:20 PM
Prodrive BCS and tha pill (2.0 wrx) Imprezav Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-22-2006 11:12 AM
Appropriate vacuum line size for prodrive BCS? overdose Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-15-2006 03:27 PM
