Old 01-07-2002, 12:57 AM   #1
pearlblack2.5rs
Member#: 11957
1999 impreza 2.5rs
midnight black pearl
Default serious idle problems on 99RS
alright, heres the problem, i have a 1999imprezars with high mileage 76k to be exact. about a month ago it started idleing very rough after it sat overnightor for a couple hours and the engine cooled down. i would start it and it would jump to about 1500 to 1800 rpm then go down to about 500rpm and the whole car would shake. so i took it to the dealer and they said nothign was wrong with it.(BS) i then too it to a private mechanic and they said it was a number of things all of which have been replaced.(new fuel pump, O2 sensor,spark plugs and wires) none of which solved the problem. then they took the temp of the engine and realized it was about 70 degrees off so they replaced that and that helped. i then took the mechanic for a ride with the computer hooked to the ecu andit said that the fuel line was staying open when it should be closed. the mechanic said that the car will adjust and that this shoould fix it. now about a month later it has all started agian any suggestion as to what this problem might be?( i apologize for the length of this post but to properly explain the problem i had to explain everything) thanks for you help
pearlblack2.5rs is offline   Reply With Quote
Old 01-07-2002, 01:04 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
When was the last time in those 76k miles you changed the fuel filter? Did anyone test the engine vaccuum (as it affects the fuel pressure riser) and the fuel pressure yet?
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 01-30-2002, 01:57 AM   #3
s
Member#: 5376
1999 Impreza 2.5RS
This is happening to me too for the past few winters.
Do you have any follow up on it?
I have around 50k on my car right now, just replaced my fuel filter, but didn't help...
I'll try to do the pressure check asap...
Old 01-30-2002, 02:33 AM   #4
Avenger
Member#: 1234
Check the intake pipe for cracks or air leaks. Since it is a 99, air leaks that bypasses the MAF will casue weird idle problems. Also check your idle air control and see if the throttle body is clean.. Might be dirty.
Avenger is offline   Reply With Quote
Old 03-01-2002, 01:11 PM   #5
Girl'sRS
Member#: 162
1999 Impreza RS
Silverthorne Metallic
I am having EXACTLY the same issues right now!! I took it to the dealer and they said it was the O2 sensor, which I replaced myself. On a whim I just put in some STP Total Fuel System cleaner, but I am still waiting to see if that does anything.
Did you ever figure out what this is?
Thanks,
GirlsRS
Girl'sRS is offline   Reply With Quote
Old 03-01-2002, 02:51 PM   #6
fabulous12
Member#: 6831
98 impreza 2.5RS
black
i started getting that on my 98... changed out the spark plugs and everything was smooth again
fabulous12 is offline   Reply With Quote
Old 03-05-2002, 05:15 PM   #7
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Throttle body
Have you tried cleaning the throttle body? It seems like an obvious thing to try... Gunk from the PCV system collects below the lower lip of the throttle plate and restricts airflow. This makes the IAC valve go crazy.
Use intake cleaner or Chemtool Carb Cleaner.
vvk is offline   Reply With Quote
Old 03-29-2002, 01:43 PM   #8
Girl'sRS
Member#: 162
1999 Impreza RS
Ok, I think I solved it. When my fiance was changing my oil he noticed that the engine had a slight knock. I put in a tank of 93, (I usually use 87). The idle smoothed out immediately. Well, since I dont want to pay for 93 forever, I tried 89... seemed fine. And I just put my first tank of 87 back in and it still seems fine. Im keeping my fingers crossed, but I think the higher octaine did the trick.
Old 03-29-2002, 10:11 PM   #9
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Common items to check: (also gonna repeat what others said)
1. Corrosion on coil pack leads
2. Pull plug on MAF and reseat it
3. If at all possible check fuel pressure. Maybe FPR is going bad?
4. Check throttlebody for build up of gook
5. Check PCV valve
6. Check for leaks in intake. Any leaks after the MAF is gonna make it run funny.
7. Replace fuel filter
8. Check vacuum or look for cracks in vacuum hoses, listen for leaks.
9. Reseat all electrical connections
And so on...
spshultz is offline   Reply With Quote
CEL / low idle problem on STOCK 05 2.5RS 2.5impreza Normally Aspirated Powertrain 22 08-25-2014 07:57 PM
Uneven idle problem on my snowblower nitrohuffer Off-Topic 11 01-12-2005 04:15 PM
high idle problem on 93 1.8 in a 95L scobaru Normally Aspirated Powertrain 2 12-17-2004 12:28 AM
Serious brake problems-Anybody else with "sensitive" ABS on a Forester? wadejg Forester Forum 6 02-03-2004 11:20 PM
idle problem - with A/C on svxxx-26 SVX Forum Archive 7 11-21-2000 07:43 AM
