Mid Atlantic Impreza Club
Old 08-11-2007, 06:34 PM   #1
lowkey
Member#: 17518
2002 wrx
Default Help diagnose my engine problem - ticking/rattling
Coming home on the highway today my engine (2002 wrx) started making a slight ticking noise at about 3500-4500 rpm. Took it home, let it sit for an hour, and now it has a slight ticking at idle that intensifies when the engine is revved.
As far as what caused it, a few minutes before the problem began I filled up with an off brand gas and then bounced off the rev limiter when getting onto the highway. I realize it's probably not bad guess, but I'm hoping it's not a valve problem.
relevant mods: cobb stage 1.
Any thoughts or ideas? Thanks.
edit: video
lowkey is offline   Reply With Quote
Old 08-11-2007, 06:38 PM   #2
mxboy15u
Member#: 105115
Post up a short video of the noise with your hood open, and then you blipping th e throttle with the hood open. You could have rod knock, an exhaust leak, noisy injector etc. A video will really narrow it down.
mxboy15u is offline   Reply With Quote
Old 08-11-2007, 06:42 PM   #3
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
my sti makes so many damn clicking noises, it's really loud, but its always been like that
2.5 Blue Roo is offline   Reply With Quote
Old 08-11-2007, 06:44 PM   #4
lowkey
Member#: 17518
2002 wrx
Sadly this one is definitely new.
I'll try to get a quick video of the engine.
Old 08-11-2007, 06:54 PM   #5
lowkey
Member#: 17518
2002 wrx
Amazing low quality video from my ancient kodak digital camera is uploading. It is *ahem* slightly low quality and a .mov file, but hopefully it will get the point across.
edit: Here's a link. Let me know if it works:
Old 08-11-2007, 07:05 PM   #6
mxboy15u
Member#: 105115
Whew...that is a pretty loud knocking noise. I have only heard a couple engines with rod knock...your video is fairly low quality so its tough to say but it does sound like rod knock to me.
Here is another video of rod knock...
http://sonic.net/~eighth08/womp/00001.mpg
Old 08-11-2007, 07:27 PM   #7
lowkey
Member#: 17518
2002 wrx
After seeing that video (much better quality ), my noise isn't nearly as pronounced or consistent (for lack of a better word) as that, but I don't really know what to say.
Old 08-11-2007, 08:38 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Change your oil, send some in to be analyzed and check the bottom of the drain bucket for yellow metel flakes. Use a cleaned out drain bucket. Cut the oil filter open and examine it for metal. If you find metal, it's probably rod bearing. If you don't then it's probably not. The oil analysis will tell you for sure if the engine's OK.
It could be a timing belt tensioner too. If it's a rod knock, it'll only get worse so, you'll find out sooner or later. Since fixing these engines when they have a knock isn't really in the cards, I doubt it matters whether you keep driving on it. On a conventional inline 4, if you catch it early enough you can probably save the motor. Not apparently on a suby.
Old 08-11-2007, 09:06 PM   #9
AMSTuning.com
Vendor
Member#: 61422
AMSTuning.com is offline   Reply With Quote
Old 08-13-2007, 10:02 AM   #10
lowkey
Member#: 17518
2002 wrx
Well, after starting it cold for the first time since the problem started, it sounds a lot more like the rod knock in the other video posted. Now the next step...recommendations for a shop and new engine?
Locals Help Diagnose my tranny problem autvincereautmori Texas Impreza Club Forum -- TXIC 23 06-27-2008 09:24 PM
Diagnose my engine problem mike270 Normally Aspirated Powertrain 3 05-17-2004 06:30 PM
Help me diagnose my engine problem! imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-27-2003 11:42 AM
Can anyone help diagnose my suspension problem? PaulRex Tri-State Area Forum 10 05-29-2003 04:15 PM
Need help diagnosing an engine problem Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 10 04-07-2003 03:17 PM
