Old 08-11-2007, 06:26 PM   #1
SubaruDriver502
Member#: 114182
2003 toyota corolla
RIP wrx, damn u bambi!
Default Not hitting target boost
Tuning my buddy's 02 with a tactrix cable. He just got a front mount, intake, TBE, VF39 and sti pinks (565cc) We are trying to get it to boost like my 06 at around 17 or 18 psi. The only thing is no matter how much we mess with the target boost values and WGDC, it still stays at stock boost.
Suggestions?
SubaruDriver502 is offline   Reply With Quote
Old 08-11-2007, 08:44 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Post in the right forum.
Old 08-11-2007, 10:13 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Cobb's instructions have a modified restrictor pill in the mix to get boost control. You can use a interrupt solenoid or try the T-flip mod to get boost up to where you want it. I had a similar issue when trying to get a VF39 to boost 21 psi and did the T-flip and was able to get that boost with about 75% duty cycle.
I can't find a thread on the t-flip right now, but pretty much take the hoses on the stock vacuum T on the boost control lines and make sure that the Solenoid line and Compressor outlet with resistor pill are in a straight line and the wastegate actuator is the one T'd off of that. Stock setup is actuator and compressor outlet are inline and the solenoid is T'd off.
Old 08-12-2007, 02:46 PM   #4
AnthonyA182
Member#: 59990
2011 WRX Hatch
you can try adjusting your wastegate arm.
AnthonyA182 is offline   Reply With Quote
Old 08-12-2007, 03:00 PM   #5
dkan
Member#: 123373
2005 wrb 05 wrx 18g
+1 WG Arm
dkan is offline   Reply With Quote
Old 08-13-2007, 01:29 AM   #6
Master2192
Member#: 83254
98 2.5 RS
04 WRX
^^^You can't adjust the wastegate arms on IHI turbos fellas
Old 08-13-2007, 12:08 PM   #7
R & H Garage
Member#: 139767
Sounds to me like you guys need to verify a few items on the setup.
First you should verify the restrictor is in between the compressor outlet and the "t" in the boost control system. Along with that, make sure you have the right restrictor.
If that is correct, check your IAM. If you experienced some heavy knock events, your IAM can drop rapidly and disable your boost control system reverting you to minimum boost.
If you still have an issue, check for a boost leak. Are your AFRs very rich or MAF voltages unusually high? If so, that is indication of a boost leak.
Lastly, if everything seems to be in order, it's very possible you have a faulty component. Could be the solenoid, could be the turbo, could be a massive up pipe leak (that should be pretty obvious)...
-Dominic
R & H Garage is offline   Reply With Quote
Old 08-16-2007, 01:17 PM   #8
EdWRX
Member#: 108068
2016 WRX
What about the solenoid, the stock one is crap, in stg II maps with stock BCS you almost have to max it out to reach 17psi.
Buy the GM one and probably ur problems will be solved.
EdWRX is offline   Reply With Quote
not hitting target boost, or boost reading is not accurate? toxin AccessPort 5 08-24-2008 08:22 PM
Please help, not hitting target boost, rather yet stock boost either nexxus_01 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-22-2007 06:19 PM
boost fluctuations, not hitting target boost! SILVERHKSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-17-2005 09:23 AM
Not hitting target boost, what could be wrong? rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 10-14-2004 05:00 PM
Not hitting target boost after an installation :( rukkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-15-2004 02:07 PM
