Welcome to the North American Subaru Impreza Owners Club Thursday December 25, 2014
Old 08-11-2007, 10:24 PM   #1
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
Default GT35r ej207 - 450 on pump w/water
Sup guys just posting my dyno result from monday. Got dyno tuned at altered atmosphere in maryland. Car has the following mods
v8 ej207 motor
gt35r .82
UR rotated uppipe
greddy 4-1 header
3" catless turboback
UR 1260cc injectors (they were only at 70% idc)
two walbro 255 fuel pumps
turbosmart FPR
fmic
Hydra
Hydramist water injection
Using standard 93 octane, the car made 390 on pump at 22psi then 449 w/ water injection at 27 psi. Dyno was a dynojet awd roller dyno.
Sorry for the crappy photo and Altered Atmospheres no-ink in there printer lol.
ImprezaRSfan! is offline   Reply With Quote
Old 08-11-2007, 10:35 PM   #2
SaabTuner
Member#: 67608
Was it just straight water to raise the effective octane rating, or was there alcohol mixed in to raise the literal octane rating?
In either case. Great numbers.
SaabTuner is offline   Reply With Quote
Old 08-11-2007, 10:45 PM   #3
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
that is so awesome for the stock block...if i recall youve had the gt35r on the bone stock longblock for a while...how many miles and hows it holdin up???
lawn boy is offline   Reply With Quote
Old 08-11-2007, 10:54 PM   #4
WRXsponge
Member#: 79621
Bug Waggy
3.0 PNP
August must be the month of the 207s. Nice numbers. In a 99 RS no less. Bad ass.
WRXsponge is offline   Reply With Quote
Old 08-11-2007, 11:53 PM   #5
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Interesting....What kind of a trans are you using? Got any times yet?
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 08-12-2007, 12:13 AM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
looks good but
time for some cams and an extra 1000rpms on the tach
Old 08-12-2007, 03:12 AM   #7
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
~Anthony.
x2 ... im on the same dilema.
XS_WRX is offline   Reply With Quote
Old 08-12-2007, 03:51 AM   #8
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
running a sti 6speed tranny, so no drivetrain probs at all. Im using windshield washer fluid, $1.05 a gallon. I think its 30% meth, 70% water.
Old 08-12-2007, 04:30 PM   #9
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
nice nice!! I love your car so much. How many miles on this setup, and how do you drive it? I'm only asking because I've been dailying the green on a v7 for a year now and am getting itchy to rotate
Hunter
skiblur is offline   Reply With Quote
Old 08-12-2007, 05:56 PM   #10
Matzo Balla
Member#: 100355
02 JDM STi
RIP 04 JBP WRX
nice.. i love my 207. ^^^ im also wondering the same thing..
Matzo Balla is offline   Reply With Quote
Old 08-12-2007, 10:26 PM   #11
mannslayer
Member#: 94978
i am going with a 3076r 0.82a/r with meth on my 207. i'd rock a 35r but i think its a bit laggy for me. i can always upgrade later tho. ej207 ftw!
congrats on your numbers. thing must pull insane, especially in a gc.
mannslayer is offline   Reply With Quote
Old 08-13-2007, 07:54 AM   #12
sumfoo1
Member#: 82146
2005 Legacy GT
it doesn't
water works as an intercooler meth works as an octane boost thats why many people run combinations of both.
sumfoo1 is offline   Reply With Quote
Old 08-13-2007, 08:05 AM   #13
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.7 @ 102, '09 spec.B
Very nice
def
dug-e-fresh is offline   Reply With Quote
Old 08-13-2007, 08:13 AM   #14
SaabTuner
Member#: 67608
Originally Posted by sumfoo1 View Post
it doesn't
"Effective" was the key word in my statement. It has the same effect as slightly higher octane.
Even in experiments where the air temperature was controlled after the water was injected, so that there was no net cooling effect, there was still an improvement in knock-resistance. NACA did some pretty extensive research on the matter.
Water does more than just cool the air.
-Adrian
Old 08-13-2007, 01:25 PM   #15
wrxhard
Member#: 108091
Nice graph. Spool isn't as bad as i thought it woulda been.
wrxhard is offline   Reply With Quote
Old 08-13-2007, 02:48 PM   #16
Homemade WRX
Member#: 33782
96 bastard child
it doesn't
and just to let you know as well, meth does more than just act as an octane booster. It carries its own oxygen into the combustion and its latent heat of vaporization is better than that of the water. That makes it a better "intercooler"
Old 08-13-2007, 03:15 PM   #17
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
id get the longest gears possible because that thing has some lag... but nice numbers man! cool setup
What downpipe do you have? custom?
All4bSpinnin is offline   Reply With Quote
Old 08-13-2007, 05:25 PM   #18
lethal.adv
Member#: 95652
'12 Outback 2.5i
'10 Legacy 2.5i ltd.
nice work!
vids damnit
lethal.adv is offline   Reply With Quote
Old 08-13-2007, 05:36 PM   #19
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
id really like to get a ride in a 35r/Red setup on a ej207..most owners that have posted, claim its not so bad at all on the street and the graphs dont do justice ..of course that is very subjective.
fastnoypi is offline   Reply With Quote
Old 08-13-2007, 05:55 PM   #20
SaabTuner
Member#: 67608
Originally Posted by Homemade WRX View Post
...and its latent heat of vaporization is better than that of the water ...
No it isn't. Water has roughly 2.6 times the latent heat per unit volume. (water has one of the highest latent heats of any substance, FYI) Methanol just has a higher vapor pressure (sometimes MUCH higher, since water's is dependent on local humidity), so it evaporates more easily, even though you have to evaporate a much larger quantity to get the same cooling effect. Pre-turbo WI solves that problem to some degree, though creating its own plethora advantages and disadvantages.
"The latent heat values of different liquids are shown here:
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
Methanol 1109 kJ/kg"
The density of methanol is around 790 kg per cubic meter, and water is around 1000 kg per cubic meter. (both changing with temperature, slightly) Ergo, even by volume, water absorbs more heat per unit evaporated than methanol.
One cubic meter is one million liters, so ...
Water = 2.256 kJ / liter
Methanol = 0.876 kJ / liter
-Adrian
Old 08-13-2007, 06:10 PM   #21
SaabTuner
Member#: 67608
It carries its own oxygen into the combustion ...
This part is a bit pointless. Technically, water "carries more oxygen" into the combustion chamber than methanol, given than, per unit mass (or volume), it HAS more oxygen.
What it does NOT carry is a large number of weakly-bonded hydrogen atoms- that's why it doesn't burn in air: the bonds of the combustion products would be weaker, and thus the process would require energy, instead of releasing energy.
That's what drives combustion, and energy release- the conversion of substances with weak bonds into substances with strong bonds. Water has VERY strong bonds, and so does Carbon Dioxide, but Methanol does not.
Chemistry (and molecular enthalpies) FTW.
-Adrian
Old 08-13-2007, 06:36 PM   #22
RexFTW
Member#: 107179
2012 S4 Black
03 WRX S400 Black
Gasoline 350 kJ/kg
Water 2256 kJ/kg
Ethanol 904 kJ/kg
-Adrian
Except for the one cubic meter actually being 1 thousand liters, not 1 million.
RexFTW is offline   Reply With Quote
Old 08-14-2007, 01:39 AM   #23
Homemade WRX
Member#: 33782
96 bastard child
I stand corrected on the latent heat values...time to brush up on my thermogoddamnits
now for the oxygen, I should have specified that it carries in it own "usable" oxygen as it has a weak bond.
Old 08-14-2007, 03:36 AM   #24
SaabTuner
Member#: 67608
...now for the oxygen, I should have specified that it carries in it own "usable" oxygen as it has a weak bond.
Eh. That doesn't really make much difference because it still richens the mixture to add methanol. It carries more reducing elements (carbon + hydrogen) than oxygen. So it doesn't add as much oxygen to the combustion as it adds elements that worsen the already too-rich mixture.
What it does do is replace surplus, lower octane rating, gasoline, as well as do a lot more cooling than gasoline, even if maybe not as much as water, under many conditions.
Still a good thing. Just a 50/50 mixture to avoid keeping a flammable liquid mixture around in the trunk or in a tank under the hood.
Old 08-14-2007, 03:38 AM   #25
SaabTuner
Member#: 67608
Oop. That happened when I was thinking of representing the volume in milliliters, then ended up using liters and not going back to change that part. Whoops.
05 STI, World One Built Motor, Hydra, HTA GT35R - 649 whp on Q16/92 pump mix WorldOne Proven Power Bragging 84 11-13-2009 07:02 PM
What is required to reach 500 whp on pump+meth with a gt35r? scutzi128 Built Motor Discussion 32 04-27-2008 05:14 AM
What oil pump and water pump for Spec C EJ207? moss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-27-2006 02:06 PM
coolant leak at tube on back of water pump recce Off-Topic 1 04-23-2006 09:19 AM
