Old 11-21-2011, 01:16 PM   #276
wrxman60
Member#: 75523
What happened to the pictures? Can they be put back up?
wrxman60 is offline   Reply With Quote
Old 11-21-2011, 07:16 PM   #277
86scotty
Member#: 281858
Default Did my clutch by pulling the engine
Wow, i can't believe how easy it was. Now for the record, it wasn't easy at all. Probably about 12 hours total, but i was due for a coolant flush and new hoses so that's why i went the engine pull route instead of the tranny pull route. The toughest part was getting the rear crankshaft seal out.
Then i had trouble getting the engine back into the motor mount holes, it had shifted forward. I think i could do the job as an easy one day job now that i have done it.
Thanks to all above, i read this thread thoroughly before i started and watched a couple of Youtube videos.
86scotty is offline   Reply With Quote
Old 01-08-2012, 05:38 PM   #278
socool9004
Member#: 220446
2004 WRX
Java Black Pearl
Anyway to resurrect the pictures?
socool9004 is offline   Reply With Quote
Old 01-09-2012, 02:10 PM   #279
kohlby777
Member#: 271073
2003 Impreza WRX
Im about to start changing the clutch on my 03 wrx... anyway to get the pictures back up?
kohlby777 is offline   Reply With Quote
Old 01-24-2012, 03:26 PM   #280
boredazhell20
Member#: 220880
2004 forester xt
subscribed need pictures too =)
boredazhell20 is offline   Reply With Quote
Old 01-25-2012, 08:43 AM   #281
DNut
Member#: 151739
Because I luckily archived the photos and like you guys so much (Well, most of you, anyways ):
[If a mod wants to edit the original posts with these photo links, feel free as I'm not planning on moving them]
step 1: make your car look like this:
step 2: do this
just kidding!
so after 1 or 2 too many AWD launches my stocker was on its way out
time required: it took me and 2 other friends who have never done a wrx clutch before a good 7 or 8 hours to do including a few breaks
tools needed besides sockets, deepwells, and wrenches you will need: a punch, transmission jack, torque wrench, pry bar, 1 (one) m6 * 1.25 bolt (the longer the better), in impact gun made life a lot easier, and the clutch alignment tool (should have came with your clutch)
important torque values (all in ft*lbs) 11.6, 23.1, 36.9, 52.8 these are for the pressure plate, prop shaft, transmission to engine, and flywheel respectively
clutch (duh!), flywheel, pilot bearing, throw out bearing
consumables: brake parts cleaner, grease, pb blaster, loctite thread locker
things you might want to buy: spring pins [(2) these keep the front axles from sliding out], down pipe gasket, all exhaust gaskets from the turbo to down pipe and back
things you might want to upgrade while its all out not covered in this guide: front sways + endlinks, transmission mount, shifter and shift linkage, shift bushings, transmission cross member bushings, rear shifter stay bushing, pitch stop, transmission and rear diff fluid
disconnect the negative terminal on the battery
remove the intercooler to gain access underneath
disconnect the pitch stop
start disconnecting the down pipe
disconnect all the wire harnesses that go into the transmission
remove the starter
remove the slave cylinder from the transmission
what ever you do don't step on the clutch now!
there's a 10mm hex plug that you will need to remove from the transmission in order to free the clutch release fork. we found it was more accessible from the bottom...its on the driver's side of the vehicle near the top of the transmission
once you've pulled the plug out thread a 6mm bolt (m6 * 1.25 the longer the better) bolt into the hole start pulling (this is the shaft that holds the release fork in place)
this should free up the release fork
now make the interior of your car look like this:
disconnect the shift linkage up from the shift lever
we went ahead and disconnected the front half shafts too even though the service manual doesn't tell you do do it until much later. use a punch and hammer to remove the spring pins on each side (the service manual says you should replace them my passenger side one was really beat up)
disconnect the front endlinks
remove the bolt holding the ball joint from the transverse link
you should with a little bit of muscle be able to drop the front half shafts off, try e
go ahead and finish taking off the down pipe (it would probably be best to take the rest of the exhaust off but we didn't)
DNut is offline   Reply With Quote
Old 01-25-2012, 08:45 AM   #282
DNut
Member#: 151739
remove top 4 bolts that hold the transmission and the engine together (the 2 on the left hold the starter on so really just 2 on the right)
now you will need to disconnect the prop shaft
remove the 6 bolts securing the prop shaft protector
important step: make sure to mark the position of how the prop shaft mates with the differential
remove the 4 nuts that hold the prop shaft (if you didn't set the parking brake have someone hold the rear wheels in place while you remove the nuts)
now remove the 2 other bolts that hold the prop shaft up to the body of the car...you should be able to pull the shaft right out now
remove the top 4 bolts that hold the engine and transmission together (the 2 on the right hold the starter on and should be off already)
disconnect the shifter linkage from the transmission, it should be 2 rolds, one where the shifter bushings are and the other right above that, it should just be a nut and bolt for each one
remove the bottom nuts and bolts that hold the transmission to the engine (iirc there are 2 nuts and 2 bolts)
transmission jack time
now remove all the bolts from the transmission crossmembers (air tools help
separating the engine and transmission was a royal pain in the ass for us, we had to lift the front of the engine by jamming a 2x4 behind the cross-over pipe and jacking it up...it finally came loose after yelling some obscenities at it
undo the 6 bolts that hold on the pressure plate to the flywheel, after you get that off if you don't have air tools you'll need something to keep the crank from turning, you can have someone hold a breaker bar + socket on the nut that holds the crankshaft pulley to the crank shaft or jamb a screw driver onto one of the teeth on the flywheel.
hey i've seen that pic already!
Old 01-25-2012, 08:48 AM   #283
DNut
Member#: 151739
eye candy:
13lbs flywheel compared to 2x lbs stock
pretty worn down
a few hot spots on the old one huh?
install the pilot bearing onto the flywheel lightly tap it into place with a hammer
install the flywheel gradually increasing the torque in a crisscross pattern to a final value of 52.8 ft*lbs
put the clutch alignment tool into the pilot bearing
now slide the clutch on
install the pressure plate 6 bolts once again crisscross pattern slowly increasing the torque to 11.6 ft*lbs
important step: after you've reached 11.6 ft*lbs once on each bolt go over it again since you are putting pressure on the fingers of the pressure plate and actually pushing the plate in it will loosen up all the other bolts you just tightened.
install the throw out bearing...it just snaps into place
remove the alignment tool
y helo thar mr turbo
some grease on the transmission spline
make this happen
jack the transmission back up and engage the splines
install the transmission crossmember, make sure the bolts are really tight!
install the bottom 4 fasteners that hold the transmission to the engine
36.9 ft*lbs
install the prop shaft pretty self explanatory
23.1 ft*lbs for the bolts that hold it on to the rear diff, just remember the orientation
install the exhaust back on now i believe the torque value for all those is 26.7 ft*lbs
install the front half shafts, the service manual recommends you use new spring pins
install the transverse link and ball joints
lower the car
install the starter, and the rest of the bolts holding on the transmission to the engine, same torque values as the bottom ones
remember that crazy 10mm hex plug?
now we need to align the release fork and that shaft that holds it in place
the shaft only goes in there one way so you're going to have to turn it and play around with the fork, you can take the boot off and shine a flash light down in there to make it a little easier it took is a little while just be patient
install the pitch stop
mad tight jdm bling yo!
connect all the harnesses back to the transmission (should be 3 plugs + 1 ground)
install the slave cylinder
install intercooler
put shift linkage in side the car back together
profit!
cliffs:
take old clutch out
put new one in
edit: any technicians want to chime on how to tips on how to separate the transmission from the engine?
Old 01-25-2012, 08:49 AM   #284
DNut
Member#: 151739
A little info about the clutch release fork....
First, before you go fiddling with the shaft the fork pivots on, you must get the fork into the release bearing. PRIOR to installing the clutch, become familiar with the bearing.
The bearing is in the center of the pressure plate, and it has two tabs that stick out and curl around, into a pair of square tabs. You'll see I spun the bearing so the tabs are at 9 and 3 o'clock. This helped a ton.
After the trans is bolted on, you need to use a flashlight to look down the shift lever hole. Spot the two square "holes" in the release bearing and put one prong of the fork in each one. It's a little difficult to tell if you've got it right, but here's how to test: start sliding in the pivot shaft. If it binds up, the release fork is incorrectly installed. Keep in mind you will probably have to lift up a little on the fork to get the shaft through it.
The shaft (that's held in place by the 10mm allen plug) engages a tab inside the transmission. I believe this tab is aligned vertically. You'll find, as you try to install the shaft, it often won't slide all the way into the hole, but a portion will block the threads where the plug belongs. Solution, pull the shaft back out a bit, rotate one direction or the other 25 degrees or so, then jam it back in. Eventually it will go all the way in.
Once it's jammed in far enough that the allen plug threads are clear, check the fork again. It should now have very limited movement, none of which is up/down or side/side. Only a little fore/aft.
Remove the M6x1.25 bolt from the shaft and install the allen plug. Install the two bolts for the slave cylinder. Note: The slave cylinder engages a small notched recess about halfway down the release fork, NOT the hole. The hole is for the fork return spring.
Testing the completed install: Now (and not before now) you can press on the clutch. Do it very slowly to ensure the slave cylinder pushrod engages the proper notch on the fork. Have a helper guide it if need be (watch your fingers). Since the piston was probably retracted a bit, you'll need to pump the clutch several times before it will work normally. Watch the lever action of the fork. Does it pivot smoothly and quietly? Does the clutch actually engage/disengage? Why did Britney Spears shave her head? Does it make any abnormal noise? Does it "feel" normal from inside the car?
Other notes:
In this pic you'll see we put grease on the prop shaft slip yoke seal. This was done to prevent damage to the seal as the prop shaft was reinstalled. This is VERY important. You shaould also clean and lightly grease the shift fork shaft to ease installation. Also apply a small glob of grease to the tip of the transmission mainshaft for the pilot bearing, as well as a light coat on the splines.
Great success!
Old 01-25-2012, 12:34 PM   #285
Blue Meanie
Member#: 141648
2002 WRX Wagon
OK, did my own clutch replacement last summer using this guide and another and made some mistakes (flame if you must, I prolly deserve it) so now I need some advice please.
The car's been running 'rough' ever since but I didn't really notice it at first but it seems to be getting worse, with a rattle now coming down off load, so I started looking stuff up...
First, I did not mark the position of the drive shaft so it was out of balance. I found some paint marks on it, from the factory I assume, and lined those up with some improvement but still rough and still the rattle.
Second, there are three little pressure plate alignment pins and one of them fell out when I got the flywheel resurfaced. I didn't notice until I had put everything back together and thought 'well, it's so small, what difference can it make?' and left it with only two of the three in place.
You can see these pins in this pic from someone else's fly:
Third, I found this note in the Subaru manual:
"When installing the clutch cover on the flywheel,
position the clutch cover so that there is a gap of
120 or more between 0 marks on the flywheel
and clutch cover. (0 marks indicate the directions
of residual unbalance.)"
I had not seen this in any of the how-tos and so did not do it. I don't even recall there being any "0"s to line up.
Also, I didn't use lock tight which on hind site I should have.
So, I'm buying another used stock fly and getting resurfaced (and balanced if needed) and am going to drop the tranny again.
The question I have is what else might I have F'd up by running like this for maybe 2K miles? While I'm in there I want to take care of anything else and I can't identify this rattling so I'm worried about the center bearing or something.
Thanks for your help!
Blue Meanie is offline   Reply With Quote
Old 01-30-2012, 04:42 PM   #286
PHRESHKHID
Member#: 298472
2014 FRS
How close is this guide to a 2006 WRX ?
Thanks
PHRESHKHID is offline   Reply With Quote
Old 04-04-2012, 06:09 PM   #287
promted
Member#: 282888
Rally Blue
Default 10mm hex won't budge! Umm...now what...
Okay so I thought I would take a stab at my clutch using the guides here. Everything has been going great until now... I cannot for the life of me get the 10mm hex plug bolt to come off! I first started just spaying with PB Blaster and giving a tug, wouldn't go, sprayed again, waited, then went at it with a breaker bar, still no. Then I got inventive and held the breaker bar underneath and torqued on the wrench by lifting the bar up with a floor jack, all that did was lift my car. So then I thought I would be smart and disconnect steering linkage to get an air gun (IR 6.2 Bar 8,000 RPM) in there... and guess what...wouldn't budge. Now I'm out of options, I don't exactly know how to get this thing off. Any of you guys run into anything like this before?
promted is offline   Reply With Quote
Old 04-04-2012, 07:27 PM   #288
promted
Member#: 282888
Rally Blue
Went at it with a torch and still no luck... I think I might be in trouble because now it's starting to strip. Any advise would be appreciated.
Old 04-09-2012, 04:04 PM   #289
promted
Member#: 282888
Rally Blue
I've been trying to go through the dust boot now to try and access the throwout bearing through that small opening. So far no luck
Old 04-09-2012, 08:54 PM   #290
sorrowfulkiller
Member#: 170439
I <3 Lamp
Bring it to subaru to have them take it out, there is no way to take out the clutch without taking the bearing out.
sorrowfulkiller is offline   Reply With Quote
Old 04-11-2012, 10:36 PM   #291
promted
Member#: 282888
Rally Blue
I got my tranny off, but not the bolt. I was able to go through the gap in the engine and tranny with a wrench and undo the bolts holding my pressure plate down. I wedged a bolt on my flywheel to keep it from spinning. It was a lot slower but I was able to pull the tranny with the pressure plate and throwout bearing still attached. Now I can worry about getting the bolt out with a lot more access.
http://forums.nasioc.com/forums/show...1#post36862337
Old 11-20-2012, 02:12 AM   #292
SLOMatt
Member#: 5040
2002 WRX Cobb Stg2
Platinum Silver Metallic
This thread is a great help when replacing the transmission. The one change I would recommend is to install the release fork and throwout bearing on the transmission and not on the pressure plate. This is what the factory service manual says to do, and it makes it so you don't have to line up the fork and the release bearing after the trans is bolted to the engine. Once you get the fork and bearing on the transmission input shaft use a string or a bungee to pull the fork forward so that the release bearing is pushed all the way back into the bell housing. After you get the transmission installed remove the string and push the fork all the way back to lock the bearing into the pressure plate.
For me the hardest part of this whole process was getting the 10mm cover removed, it was really stuck in place and I ended up breaking a hex socket bit. Lining up the transmission required three jacks (trans jack, another jack to elevate the rear of the trans, and a third to lift the front of the engine).
- Matt
SLOMatt is offline   Reply With Quote
Old 12-01-2012, 11:01 PM   #293
sliders02wrx
Member#: 214004
Default replacing clutch alone. not an option.
I must say this is a great right up!
However: I will add a couple detail. Everthing came apart quickly except the tranny from the car in which I reinstalled the driveshaft guard ( the thing with 6 bolts in it near the rear differential ) which i used to hook two come alongs to to pull the tranny off the motor. Right or wrong this was the only way I was getting it off. And yes i did break about six heat shield bolts no biggy that was an easy fix.
Now putting everything back together,,,, Well. the install of the stage two kevlar clutch the 12lbs. fly wheel etc.. was easy.
lifting the trtanny backup into place with two jacks ( by myself mind you ) was no treat. I spent litterally ALL day trying this alone. to no avail. following the above instructions which were great btw.
at the end of night one I had my girlfriend help me only to discover the clutch fork was wedged behind the throw out bearing instead of in where it belongs.
so take it all the way back out to inspect that i didnt damage anything.
and had to call a friend over the next day to reinstall. it took him and I aboout an hour to reinstall tranny crossmemebers and half shafts.
put everything back together just fine. clutch works great.
sliders02wrx is offline   Reply With Quote
Old 08-11-2013, 05:13 PM   #294
Docsuby79
Member#: 173994
2003 Impreza WRX
Rally Blue
man I wish the pics still worked on this thread..... Anybody got any help on this?
Docsuby79 is offline   Reply With Quote
Old 08-11-2013, 05:25 PM   #295
PSBeachBum
Member#: 279870
2005 WRX Wagon
Help in what?
PSBeachBum is offline   Reply With Quote
Old 08-20-2013, 10:30 AM   #296
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
I was searching through this the other day and was pretty sure he revived them somewhere in the middle so just look through all the pages I think he did that for everybody.
I will need a clutch pretty soon and a really good tuning shop that I used quoted me just 6 hours of labor for the clutch and flywheel installation that's almost too good of a deal to pass up. If I do it myself it will take a whole weekend and I will have to buy more tools, I have the basic stuff but I would need to get torque wrenches and a transmission jack. So it might be almost worth it just to have my shop do it for me even though I think this would be a fun project
Dmochowski is offline   Reply With Quote
Old 09-08-2013, 12:25 PM   #297
icar12
Member#: 339091
Default Cluch replace
I've done clutch changes on car's before, but I have finally met my match. After day's of getting through rusted bolts and seized nuts, I was ready to take the CV axles out. Apparently Subaru used two types of CV's one that needs to be pulled from the trans, and the other has a pin that's pressed out and can be pulled from the spline. The pin type CV is great, and comes apart easily. But, I have the CV that needs to be PULLED from the trans. I used pullers, hammers, pry bars, and I can't get the CV pulled out of the trans. My next step was to remove the ball joint, and tie rod. This is where I threw in my bloody oil soaked rag. With all the rust, working on the garage floor, no torch, and no high powered air gun to remove the seized suspension, I had to pull the plug on this project. Good luck to owners with cars that are in good/newer condition, this a easy job. Many of the pics posted show cars in decent shape, and will make these projects go much smoother.
icar12 is offline   Reply With Quote
Old 12-22-2013, 01:30 PM   #298
rmbr0911
Member#: 376686
Default Circlip Failure
Ok, so I followed this procedure fairly close however the circlip that holds the shift fork down has failed 2x. I thought maybe there was an issue with the clutch kit I bought but at this point I have a feeling I am doing something wrong. Clutch pedal works fine for a short period ( one or two throws ) then bottoms out and won't return. When I tore everything apart, the circlip was popped out .. again?? Help please!!
rmbr0911 is offline   Reply With Quote
Old 03-07-2014, 12:27 AM   #299
lego126
Member#: 377615
thanks 4 the pics. this helped me alot last month
lego126 is offline   Reply With Quote
Old 04-12-2015, 09:48 PM   #300
Kmiller23
Member#: 418506
Default Issue on 1998 cable clutch.
My fork won't engage the clutch fingers.
It seems like the pivot isn't right.
I tore it all apart and replaced lots, but now It's back together and it isn't right.
Any thought?
I miss my impreza.
Kmiller23 is offline   Reply With Quote
exedy stage 1 clutch and flywheel - 03-05 wrx k33p3lz Drivetrain 2 12-10-2009 01:24 AM
FS: WA: NIB: CUSCO front sway bar 02-07wrx, and stock 06-07 clutch and flywheel seventhsign NWIC Private Classifieds 1 04-03-2009 02:51 PM
FS: 02 WRX clutch and flywheel tubbytreats Drivetrain 8 08-06-2007 03:19 PM
how much should a new clutch and flywheel cost xcdhridr Transmission (AT/MT) & Driveline 2 06-11-2007 12:25 AM
How many horsepower can stock clutch and flywheel handle? alvyman Transmission (AT/MT) & Driveline 8 05-28-2003 02:50 PM
