Alaskan Impreza Club
Old 08-12-2007, 05:47 AM   #1
prometheum
Member#: 92003
04 bicycle!
Default installed new clutch and flywheel
http://forums.nasioc.com/forums/show....php?t=1324240
special thanks to jerry for the tips and rodger for the help
already stalled once coming out of the parking lot with the light weight flywheel...its like learning to drive a stick all over again!
prometheum is offline   Reply With Quote
Old 08-12-2007, 12:37 PM   #2
edo2000
Member#: 68709
2012 WRX
red
Very nice writeup and pictures. Thanks. Is that an oem clutch?
edo2000 is offline   Reply With Quote
Old 08-12-2007, 01:14 PM   #3
soldmyboxster
Member#: 65520
Nah, Exedy organic. Since the stock clutch wimped out (see the massive hot spots on the flywheel), upgraded was the way to go.
I added some more info about the shift fork/shaft in the OP's link.
soldmyboxster is offline   Reply With Quote
Old 08-12-2007, 03:22 PM   #4
edo2000
Member#: 68709
2012 WRX
red
Originally Posted by soldmyboxster View Post
...I added some more info about the shift fork/shaft in the OP's link.
THANKS!!!! That info will come in extremely handy.
Old 08-17-2007, 12:13 AM   #5
Errick
Member#: 156885
2002 Impreza WRX
Metallic Silver
Yeah I have the Exedy Organic Clutch, I LOVE IT! I have a ACT Flywheel that has been lying in my garage for about a year now... afraid to install it, heard some things about flywheels and screwing things up.
Has is your combo going so far?
Errick is offline   Reply With Quote
Old 08-17-2007, 12:24 AM   #6
AWDBST
Member#: 80085
11.8 117 Trap
Stock EJ205
How light is your flywheel? And do you have a lightened crank pulley?
AWDBST is offline   Reply With Quote
Old 08-17-2007, 12:28 AM   #7
Errick
Member#: 156885
2002 Impreza WRX
Metallic Silver
yes to the pully and I am afraid I dont remember how much it weighs... I know it is really light, let me check on gruppe-s.com. I was young and didnt know when I bought it.
Old 08-17-2007, 12:30 AM   #8
Errick
Member#: 156885
2002 Impreza WRX
Metallic Silver
I think 13.9lb... but I am really hoping I didnt buy the 9.6 because I might aswell spin my engine out of my car lol.
Old 08-17-2007, 12:35 AM   #9
AWDBST
Member#: 80085
11.8 117 Trap
Stock EJ205
Wiegh it if it is over 12lbs throw it in. As long as you don't have lightned crank pulley.
Old 08-17-2007, 12:37 AM   #10
Errick
Member#: 156885
2002 Impreza WRX
Metallic Silver
oh I have a Perrin Lighten Pully... so just keep using it as a giant paper weight
Old 08-17-2007, 01:41 AM   #11
inkpreza
Member#: 142064
2001 Dodge Ram Sport
1973 MGB
please explain the problen with that combo
inkpreza is offline   Reply With Quote
Old 08-17-2007, 01:45 AM   #12
missiceblast
Member#: 142304
wow even i understood it nice job! so how many launches do you think that was (rhetorical)
missiceblast is offline   Reply With Quote
Old 08-17-2007, 03:38 AM   #13
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
too light and you might set erronous missfire codes.
the flywheel mod was very noticable immediately, at about 5k rpm or so. amazing considering it doesn't technicaly add hp, just takes less away...
00Maddog is offline   Reply With Quote
Old 08-17-2007, 07:03 AM   #14
prometheum
Member#: 92003
04 bicycle!
something about the cam position sensor the car thinks its misfiring under certain conditions...i think i might have been sold a prolight flywheel instead of a street lite one. judging by the pic i took compared to the pic on gruppe-s's website it looks like the 9.6 lbs one. (i bought it from sparky)
but i figured if it was the 9.6 lbs one i figure it would be a lot more difficult to drive. its thrown a check engine light 4 times since i've installed it (130 miles) all for misfires
Old 08-17-2007, 12:50 PM   #15
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
Nice writeup.
I see you used a lift, is that highly recommended?
AKSubie is offline   Reply With Quote
Old 08-17-2007, 04:58 PM   #16
prometheum
Member#: 92003
04 bicycle!
Originally Posted by AKSubie View Post
Nice writeup.
i almost see it as being required
it was a bitch and a half to separate the engine from the transmission
Old 08-17-2007, 05:45 PM   #17
AKSubie
Member#: 6214
01.5 Audi S4
yeaaah, I bet....
Old 08-18-2007, 03:40 AM   #18
Jaylyons1
Member#: 113884
2013 BRZ
Mine used to throw alot of misfire codes also due to the flywheel...
Jaylyons1 is offline   Reply With Quote
Old 08-18-2007, 08:17 AM   #19
prometheum
Member#: 92003
04 bicycle!
used to? did you get a heavier flywheel?
prepping new clutch and flywheel for install Vampyr Transmission (AT/MT) & Driveline 0 05-05-2009 08:26 AM
New clutch and flywheel install...funny noise aspenwhitewrx Transmission (AT/MT) & Driveline 2 01-09-2006 02:43 PM
Wheel hop after installing new clutch and flywheel? wrx2 Transmission (AT/MT) & Driveline 2 11-19-2003 03:45 AM
New Clutch and Flywheel Installed Chewy-WRX Transmission (AT/MT) & Driveline 11 07-30-2003 03:36 PM
Difficulty of installing new Clutch and Flywheel ? Matt Normally Aspirated Powertrain 11 11-30-2000 10:40 AM
