Old 08-13-2007, 08:17 AM   #1
Worknclassbug
Member#: 153236
Default A/C problem on '93 wagon
For some time I've had a problem with the a/c working intermitently. It would sometimes just not come on at all or just shut off after working for a while. Everything was coming on except the compressor. I finally tracked down the problem today. I pulled the glovebox out and dug around a little on the HVAC unit box. I pulled out the fan resistor module so that I could see inside the HVAC box. I could see the evaporator and the thin copper tube that should be the thermocouple device that turns off the compressor when the evaporator gets cold enough. I could not see where it went though. On top of the HVAC box I found another small black box that has two grey wires coming out of the top of the HVAC box going into the back of it and a regular wire connector on the front. I started the car and turned on the a/c and got nothing until I gave the little relay a little pull and then the a/c came on. When I pushed the relay back into it's little cradle I lost the a/c. As long as I had the relay pulled out of it's cradle and hanging the a/c worked. I tried the same thing again today and the same thing happened. I know I have a short somewhere. Probably in the grey wires going into the HVAC box. My question is where can I find a break down of the HVAC sytem of my car so that I can figure out what this relay/sensor thing is called and figure out where the grey wires wind up without pulling out the whole dash. Anybody have any ideas? I'm going to try to snap a picture of the thing tomorrow.
Worknclassbug is offline   Reply With Quote
Old 08-14-2007, 12:20 AM   #2
Ej22techie
Member#: 156051
1997 Legacy L Sedan
it might be the evaporator sensor... they do go bad on these cars.
Ej22techie is offline   Reply With Quote
Old 08-15-2007, 09:22 PM   #3
Worknclassbug
Member#: 153236
It appears that is what I'm looking at. I'm gonna check on a new one tomorrow. Anyone ever replace one? Looks like it may be a pain.
Old 09-04-2007, 09:08 PM   #4
Worknclassbug
Member#: 153236
Turns out it wasn't that bad to disasemble the evaporator unit. The new sensor is $67 but it will be worth it if that fixes the problem. Getting one ordered tomorrow. It looks a little cheap. Looks like something I would make on my workbench. Maybe that's why it failed...lol.
Opinions on '93 Legacy Touring Turbo AWD Wagon abracc Newbies & FAQs 2 12-31-2007 08:50 AM
Engine problem on 96L wagon Automatic toysnyc Legacy Forum 5 11-20-2007 04:08 PM
Simple Question: Will '02 WRX Struts Work on '93 L Wagon? dug-e-fresh Brakes, Steering & Suspension 1 01-11-2006 05:51 PM
'02 WRX suspension on '93 Legacy wagon mch Legacy Forum 5 04-20-2003 12:51 PM
('93-'01) Opinions on '93 Impreza wagon mikemo Impreza Forum 6 06-21-2001 12:36 PM
Message Board Statistics All times are GMT -4. The time now is 04:49 AM.
