Old 01-07-2002, 11:09 AM   #1
sovereignmk1
Member#: 11858
1998 Silver Legacy
Default Changing the oil
I was just curious as I was reading on this website http://www.geocities.com/hobiegary/hesitation.htm about hesitation/engine tapping from another post.
When a new filter is installed, it is full of air and not oil. When the engine is started, the oil pump is pushing oil in and air out of the new filter.
Does anyone else fill up the filter with oil before installing it, or am I the only bozo that does it so there is no air being pushed around after a oil change??
/Mark
sovereignmk1 is offline   Reply With Quote
Old 01-07-2002, 11:11 AM   #2
sovereignmk1
Member#: 11858
1998 Silver Legacy
Oh yeah, what is your oil of choice.
/Mark
Old 01-07-2002, 03:26 PM   #3
ToJo
Guest
Member#:
I always fill the oil filter first and put some on the rubber 'O' ring before I install the filter.
Old 01-07-2002, 03:43 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I worked at a Q-Lube (now Jiffy Lube) for nearly 4 years and we never filled the filters with oil. For one reason, most cars have the filter mounted horizonally instead of vertically. Another reason is that the pneumatic oil dispensers weren't designed to work at such a low rate and it could make a mess.
However, we ALWAYS lubed the gasket with a thin film to make sure it made a good deal and would come off a little easier the next time.
Mobil 1. Amsoil sounds great too. Synthetic, period.
DLC is offline   Reply With Quote
Old 01-07-2002, 04:09 PM   #5
subarurabbit
Member#: 4083
2011 OB 3.6R
Default Re: Changing the oil
/Mark
I did that once with my WRX. That engine does run pretty high oil pressure.
Roger
subarurabbit is offline   Reply With Quote
Old 01-07-2002, 09:28 PM   #6
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I always do. I just changed the oil yesterday on a friends explorer and that filter is on a 45 angle. I still put some in there. Better than none I guess.
I suggest one of these too:
http://www.scoobymods.com/mods/impre...drainvalve.php
from our page too:
http://www.scoobymods.com/mods/impreza/oilchange.php
Peaty is offline   Reply With Quote
Changing the oil myself and have questions Subie2 Service & Maintenance 4 09-21-2003 10:48 PM
nearly time to change the oil, need some help and advise warlord225 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-30-2002 11:36 PM
Changing the oil Genner Newbies & FAQs 5 06-16-2002 08:57 AM
Changing The Oil Questions wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-31-2001 04:20 PM
