Old 08-17-2007, 11:42 AM   #1
Chad W
Member#: 77975
2013 BRZ
Default How much oil in my Hybrid?
I've got a stock STi block with stock ej205 heads....what's me total oil capacity? I always put 4 in and then run the car and add until it looks good, but I'm wondering what my target is.
Chad W is offline   Reply With Quote
Old 08-17-2007, 12:14 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
If you are still running the WRX oil pan and pickup the capacity hasn't changed as long as you use the same dipstick and tube. If you change to an STi oil pan and pick up you need to change the dipstick also. As long as you have the correct dipstick for your application just fill to the full line.
Old 08-17-2007, 12:36 PM   #3
Chad W
Member#: 77975
2013 BRZ
Sweet, thanks I wasn't sure if there was any difference related to oil channel size in the block or size of the crank case.
How much oil in the exhaust is normal? stevenh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-20-2004 08:16 PM
Too much oil in my 05 STi? Hollidark Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-17-2004 04:09 PM
How much oil in IC is OK?? (pics) FreeBMW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 12-18-2002 06:09 PM
dealer put to much oil in my differential or transmission WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-31-2002 05:01 PM
how much oil in block?? Damon Normally Aspirated Powertrain 1 03-03-2001 07:41 PM
