Old 08-13-2007, 11:59 PM   #1
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Default ARP Headstud lube
I do not have any of the ARP lube that came with my studs, what can i use on the nuts when I torque them down other than the arp lube? Can I use engine assembly lube?
Thanks
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 08-14-2007, 06:29 AM   #2
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
I have used lubriplate in the past no problems.
oh did you get my PM about the body kit?
saintluciascooby is offline   Reply With Quote
Old 08-14-2007, 03:09 PM   #3
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
Check w/ your local machine shop. They more than likely have some. I was going to do mine dry as they come with specs for dry and lube, but I was advised against it.
SBW is offline   Reply With Quote
Old 08-14-2007, 03:14 PM   #4
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
I usually just use regular motor oil. The oil will get in there anyway once the engine is run.
ai42 is offline   Reply With Quote
Old 08-14-2007, 08:32 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
+1 for motor oil. I think the FSM actually calls for it.
Acostafan is offline   Reply With Quote
Old 08-15-2007, 04:06 PM   #6
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
Don't use synthetic motor oil - it's so slippery you could potentially stretch the studs. At least, that's what my "Building High Performance Mustang 5.0s" book says...
-Ryan
RyanE is offline   Reply With Quote
Old 08-15-2007, 04:16 PM   #7
saintluciascooby
Member#: 109527
blue
lol you cant be serious. if you torque to spec theres no way to stretch the studs.
Old 08-15-2007, 04:50 PM   #8
Devan M
Member#: 83435
I would contact ARP for the torque speck to use with the lubricant you choose.
Devan M is offline   Reply With Quote
Old 08-15-2007, 10:56 PM   #9
norexyet
Member#: 39149
11 elantra
yea i said elantra
You can use 5w-30 regular oil. I believe it says on the box what to torque the studs to when using motor oil instead of the arp moly. I think they say like 72ft/lbs for the arp moly and i am gonna take an educated guess of 84ft/lbs. for oil
norexyet is offline   Reply With Quote
Old 08-16-2007, 12:37 AM   #10
SBW
Member#: 38469
07 LGT spec-b
you could stretch the threads no?
Old 08-16-2007, 01:40 AM   #11
subie4me
Member#: 89218
The angular torque method that subaru specs is actually the most accurate as it discounts the frictional losses from different lubricates. Now if we could just get arp to give us specs like that!
subie4me is offline   Reply With Quote
Old 08-16-2007, 07:09 PM   #12
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
From ARP's own website (URL available upon request - I don't have enough posts for NASIOC to let me post links)
2. The lubricant used is the main factor in determining friction, and therefore, the torque for a particular installation. Motor oil is a commonly used lubricant because of itís ready availability. If less friction is desired in order to install the fasteners with less torque, special low friction lubricants are available. With special lubes, the required torque can be reduced as much as 20 to 30 percent. It is important to keep in mind that the reverse is also true. If the torque value has been specified for a particular fastener on the basis of low friction lube, installing the fastener with motor oil will result in insufficient preload; the torque has to be increased to compensate for the extra friction caused by the motor oil.
The problem is depending on the lube used, the torque specs change. Therefore, the torque specs for motor oil are higher than the torque specs for synthetic lube. I misspoke by saying not to use synth motor oil - it can be used, but only if you have torque specs for that oil. I guess this is why ARP provides their own lube, so that they can definitively give torque specs.
-Ryan
ARP Headstud Question WhiteWoRX1 Built Motor Discussion 0 04-08-2006 07:08 PM
ARP Headstuds *new in box* foolio Private 'For Sale' Classifieds 4 10-18-2005 08:14 PM
APS Cold air intake, Perrin Oil Catch Can, ARP Headstud Kit, JE Pistons Subaru300hpWRX Private 'For Sale' Classifieds 24 12-12-2004 01:17 AM
FS: ARP headstuds for WRX Bolster Private 'For Sale' Classifieds 9 06-16-2004 10:08 PM
FS: ARP Headstuds for WRX Bolster Texas Impreza Club Forum -- TXIC 1 06-14-2004 09:49 PM
