Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 08-14-2007, 02:16 AM   #1
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Default 03 WRX w/ EVOIIIBig16g Dyno tuned today!
Went down to harman motive today and got my turbo, injectors, and fuel pump installed and tuned...
I will have the dyno graphs up tomorrow but my numbers were as followed.
THIS IS ON A MUSTANG DYNO!
Mods:
Blouch EvoIIIBig16g turbocharger
650 deatschwers injectors
Prodrive boost control solenoid
walbro 255 fuel pump
Turbo XS FMIC
Cobb Intake
Titek CATTED DP
Helix Midpipe
SPT/Bosal Axle Back
91 octane - 20.5 lbs of boost
262/235
95 octane - 21.6 lbs of boost
281/260
Full boost around 4200 RPM, feels nice.
Here is the Dyno Graph
I am having an issue though...I get very slow boost building in third if I am driving fast. Let's say I am going 1 > 2> then hit 3rd geaer...well boost is great in 1st and 2nd but as soon as I hit 3rd it's as if the car doesn't go any where until after 5k RPMS...It's very strange
Here is the 95 octane dynograph
Erexxx is offline   Reply With Quote
Old 08-14-2007, 02:36 AM   #2
lowranger
Member#: 124370
03 wrx?
Pro tuned by Cobb Tooning
dang congrats, thats the same turbo setup i was going for till some stuff happened. congrats.
lowranger is offline   Reply With Quote
Old 08-14-2007, 03:29 AM   #3
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
nice numbers...made close to the same at Harman with my VF23...252Hp and 241 trq @17 lbs with 91...cant wait for the graphs
Nettalp is offline   Reply With Quote
Old 08-14-2007, 10:10 PM   #4
JF824
Member#: 71460
2007 STi Limited
Nice numbers. Definitely post up the dyno plots so we can see / analyze.
JF824 is offline   Reply With Quote
Old 08-17-2007, 03:08 PM   #5
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
I'd be interested to see your boost pressure plotted on a graph over RPM. My 18G 7cm spools to 14.7PSI around 3800 rpm and to 21+ PSI at just around 4200 rpm with the eBay TMIC setup.
tubbytreats is offline   Reply With Quote
Old 08-17-2007, 03:55 PM   #6
pictureboy
Member#: 85132
2017 Bolt
Nice! I have the same turbo and like it a lot. In fact we have very similar mods.
I think with some playing around you will be able to get full boost a bit sooner than you are seeing now.
Have fun!
pictureboy is offline   Reply With Quote
Old 08-18-2007, 01:26 AM   #7
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Dyno Graph up guys!
Old 08-19-2007, 01:15 PM   #8
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
bump lets get these dyno plots analyzed
Old 08-19-2007, 11:01 PM   #9
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
no responses? wtf
Old 08-19-2007, 11:39 PM   #10
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
Looks pretty good - I have a momentum 40t and it spools allot like that too. I have yet to be able to make good boost below 4000 rpms.
TheShad0w is offline   Reply With Quote
Old 08-20-2007, 06:17 AM   #11
fastwrx25
Member#: 126441
03 bugeye
I thought harman had a dynojet?
fastwrx25 is offline   Reply With Quote
Old 08-20-2007, 08:22 AM   #12
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
My analysis as a TD05H-18G 7cm owner...
1. In your case, this EVO3 16G doesn't spool faster than my eBay TMIC with 18G. I was really on the fence about whether to go EVO3 wheel or 18G wheel, but I've seen many dyno plots that all seem to show the same thing about spool between the two. (Now I know that the 18G with the larger 8cm wheel would probably be a bit slower, but who knows really?)
-- I think in this case, it's really the difference of FMIC vs. TMIC. I have a slower spooling turbo, but have a smaller and shorter tubing intercooler. You have the faster spooling turbo, but have added larger internal volume and longer piping. It pretty much evens out IMHO. I spool 14.7 PSI by 3800 and 21+ PSI by 4200 which is identical to your dyno plot.
2. It also appears that you are on the Prodrive boost control solenoid, which should really help with building boost faster than the stock setup. I'm still on the stock setup (well for a week or so more) until I put on my Perrin EBCS. I'm expecting my spool RPM range to lower once that is installed and tuned.
3. Power levels look good for the EVO3 16G. I think my only disappointment with that setup is the fact that the EVO3 is supposed to spool 500 RPMs faster than the 18G, and in your case it isn't. Other than that, I think the power looks pretty typical of your type of mods and I bet it's fun to drive around town.
Old 08-20-2007, 01:21 PM   #13
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
They used to. THey moved to a huge new facility 3 miles from where they used to be.
and thanks for the break down on what you think...what do you think about the car not hitting full boost in certain gears etc?
Old 08-20-2007, 01:27 PM   #14
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
What gears have you tried? What are the max PSI levels in 3rd, 4th, and 5th gears?
The factory boost control solenoid is not capable of controlling different boost in different gears. Your Prodrive boost control solenoid probably can with specialized engine management, but I would guess that right now it's not doing anything different between gears.
I have no clue why you are having problems as you described. Can you or have you logged with a laptop while driving to capture this event as you've described it? Use ECUExplorer or Enginuity to datalog with the Cobb AP cable and your laptop.
Old 08-20-2007, 01:32 PM   #15
12SECWAGON
Member#: 149258
04 WRX Wagon
Java Black
I dynoed 268/242 on 91 oct on Cobb's Mustang dyno in Salt Lake with a similar set-up but I am reaching peak boost just before 4000RPM. I purchased the adjustable wastegate and had Blouch port my turbo, but the porting should make it spool a little slower...???
12SECWAGON is offline   Reply With Quote
Old 08-20-2007, 05:04 PM   #16
pictureboy
Member#: 85132
2017 Bolt
I throw my dyno plot into the mix. My tuner wind up hittign 295whp, but some reason the dyno operator printed out a slightly earlier run, so I'll go with it. 288.6WHP, 300WTQ.
Mods:
EVOIII 16G
TurboXS FMIC
Perrin short ram intake
Perrin Up
Bosal down
Apexi AVCR boost control
modded stock injectors
Cobb EM
Old 08-20-2007, 05:30 PM   #17
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
My most recent log shows 14.7psi right at 4k, 4500 it rockets to target and pretty much holds relatively steady to the target in the map untill redline. I dont have any dyno comparisons though I'm targeting a bit more boost than most 16g owners though I am right at 23-24 psi. It holds 5.5 load tapering to 5 at redline.
Old 08-20-2007, 05:42 PM   #18
Jstyles21
Member#: 95454
2008 STI
www.CTSUBIE.com
My FPEVOIII gets full boost (19psi) at 3300-3400 rpm with a SSAC FMIC. I have STI pinks, but I'm switching to 650's this Saturday. I'm getting retuned in Sept.
I really hope to hit 300whp, but we shall see.
Jstyles21 is offline   Reply With Quote
Old 08-26-2007, 04:35 PM   #19
Nettalp
Member#: 93812
2004 Wrx wagon
funny cause im having boost issues too...but I have a VF23...it seems like sometimes I can hit full boost at 3300...but sometimes I dont hit till 4200???not sure whats up
2004 WRX - 300HP - $12900 Dyno Tuned, Every Option, Extra Snow Tires and rims scoobiesndoobies Private Vehicle 'For Sale' Classifieds 4 12-01-2008 01:29 PM
'07 WRX stg 2 dyno tuned by Dent Sport - 220whp/320tq - Thoughts? bump909 Proven Power Bragging 17 01-25-2008 08:52 PM
just bought a slightly moded 03 wrx, w/o dyno can anyone gauge my power? joelikewhoa Impreza Forum 1 02-06-2007 02:11 AM
So I had my car dyno tuned today... Need4Boost Proven Power Bragging 15 04-14-2003 10:47 PM
Something interesting while dyno tuning today hayscoob Normally Aspirated with bolt-on Forced Induction Powertrain 31 03-19-2003 07:15 PM
