Old 08-14-2007, 02:49 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U 2008+ owners...please read....
Congrats on your new car and welcome to the forums!
Now before you start posting, please keep the following in mind:
1. Your car is brand new. Yes, it's just a new year, but for all intents and purposes, it might as well be a Jeep Cherokee as pretty much 100% of the car is new.
2. Will XXX fit my car? Probably not. The turbo is different, the intercooler is different, the exhaust is different, etc.
3. When will manufacturers start making XXX parts? We don't know, please bug the manufacturers.
4. I found XXX parts that will fit, can I bolt them up? Your best bet is to wait for engine management before you start bolting up things. Each car has something called open/closed loop fueling issues mandated by the EPA that can negatively affect vehicle modifications. The wise/safe course of action is to wait for engine management then modify. Yes, you can probably safely get away with simple mods, but the smart thing to do is engine management first, then parts.
5. But I found out that XXXX from an older Subaru will fit on my 2008. Well post that crap here and we'll update this for all to see.
If anyone sees anything to add, please post. The genesis behind this post is to prevent 9000 posts of will XXX fit my 2008. This is an annual annoyance and I'm hoping this may stem some of that.
Old parts that WONT fit:
Exhausts
TMICs
FMICs
Rear sway bars
Intakes for Legacy GT
Old parts that WILL fit:
Downpipes for Legacy GT
BPV/BOV for Legacy GT
Lightweight crank pulley
short throw shifters/bushings
front sway bar
TMIC for Legacy GT
FMIC for Legacy GT (may have to mod to fit)
Turbos for Legacy GT
Clutch and flywheel
THIS LINK contains a huge list of parts that will fit 08/09 cars
STI Exhausts that will fit
Old 08-14-2007, 02:59 PM   #2
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
I'd like to add that a good starting place to look for parts will most likely end up being the Legacy GT boards
mxturboracer86 is offline   Reply With Quote
Old 08-15-2007, 11:59 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
FYI, someone needs to try test fitting this, but I do believe that the 08 WRX Sedan exhaust system is ALMOST same as the Legacy GT exhaust system (including the mufflers!).
It looks like the mufflers mount exactly the same, however the Catback flange looks like it is rotated at a different angle... However, a FULL exhaust may bolt on without any problem, as would a dual muffler kit like the Prodrive mufflers (just axle backs and not the catback)
The 2.5i's (non-turbos) look EXACTLY the same though...
BTW, i'm going by diagrams here not the actual cars, so it will need to be verified first.
Old 08-17-2007, 11:16 AM   #4
IMPRZV1
Member#: 40306
2007 STi, finally!
Suby # 4, UGM
I know all kinds of stuff about the Jeep Cherokee if you need some info just let me know
On the other hand I don't know anything about the 2008 cars though
IMPRZV1 is offline   Reply With Quote
Old 08-17-2007, 12:51 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Score one for the LGT owners! I cannot wait for decently priced turbos that fit the stock location. And rotated manifold setups just got a whole lot better because of the redesign.
wcbjr is offline   Reply With Quote
Old 08-20-2007, 03:15 PM   #6
biz77
Member#: 45119
Cobb is already showing a catted DP, short-shift kit and front sway-bar for the new WRX.
biz77 is offline   Reply With Quote
Old 08-20-2007, 03:32 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Probably because they fit the LGTs.
Old 08-20-2007, 05:02 PM   #8
biz77
Member#: 45119
Part numbers are identical.
Old 08-30-2007, 02:03 PM   #9
vet
Member#: 42194
05 LGT Wagon
GRP, sold 98 2.5rs Acadia
Has it been verified that the turbo fitment is the same as the LGT?
vet is offline   Reply With Quote
Old 08-30-2007, 09:14 PM   #10
Purple
Member#: 116757
08 wrx Rally Blue
Colin McRae RIP!!!
they better start coming up with mods soon, im picking up my impreza tommorow, or if something goes to ***** tuesday after long weekend.
Purple is offline   Reply With Quote
Old 09-13-2007, 02:25 AM   #11
uathatis
Member#: 117300
I'm not sure about the front endlinks... but the rears on this 08 wrx are already a metal type so less benefit (presumably) from changing those out
Not sure about fitment but size wise eyeballing the bars it seems 19-20mm fsb and a 17rsb
uathatis is offline   Reply With Quote
Old 09-13-2007, 12:33 PM   #12
2fst4u2c
Member#: 57589
2011 WRX
A Blu Hue
17" wheels of an 02 wrx will fit a 08 wrx!
2fst4u2c is offline   Reply With Quote
Old 09-17-2007, 06:13 PM   #13
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
Unless someone else does it before me, I'm gonna grab my t-rusty old tape measure and do some measurin' to confirm/deny.
will post my findings.
and not that it belongs in the engine/power forum, but version 7 rims are a fine match, except that booger of a light that tells me the tire pressure is low is getting really annoying...
Old 09-17-2007, 08:29 PM   #14
Damon
Member#: 2902
kick ass!!
Damon is offline   Reply With Quote
Old 09-18-2007, 04:32 PM   #15
FaisalT
Member#: 107097
09 Etnies
Gray/Black
funny, my brothers LGT does the same thing after his 19's.
FaisalT is offline   Reply With Quote
Old 09-18-2007, 05:07 PM   #16
samagon
Member#: 26859
of TXIC
from what I'm told there is a sensor in the wheel, and you can get the sensor from subaru, or tire rack.
I'm gonna see if subaru can just turn off the light from the ECU, otherwise it'll have to wait till I run through these tires.
I'll post the results regardless!
Old 09-18-2007, 07:25 PM   #17
sphereworkz
Member#: 159360
2008 WRX
Gray
Subaru Stars help
Im new to this subaru thing. this is my first subaru and turbo charged car so I want as much info I could possibly get like how do I take care of it. what not to do. Im also thinking about buying some gauges.
sphereworkz is offline   Reply With Quote
Old 09-18-2007, 07:36 PM   #18
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Gauges, wheels/tires, some suspension stuff
are your only choices at the moment. A lot of manufacturers have 08s now and are making parts so we should start seeing stuff soon but it might all be delayed while engine management is figured out.
Old 09-18-2007, 08:34 PM   #19
Wrxified
Member#: 16222
2005 STi
Platinum Silver Metallic
02 WRX had 16" wheels.
Wrxified is offline   Reply With Quote
Old 09-18-2007, 10:48 PM   #20
samagon
Member#: 26859
of TXIC
for the how to's of that nature, you're best off reading lots of FAQs in the general forums.
start here: http://forums.nasioc.com/forums/showthread.php?t=170789
then go here: http://forums.nasioc.com/forums/showthread.php?t=533787
if what you are looking for is not in these two locations, ask questions here: http://forums.nasioc.com/forums/forumdisplay.php?f=34
Old 09-19-2007, 11:32 AM   #21
FaisalT
Member#: 107097
09 Etnies
Gray/Black
I've been trying to get my hands on an LGT factory service manual, so I can get something figured out. I tried buying one on ebay, but they kept refunding me because they were bootleg.
Old 09-19-2007, 05:45 PM   #22
samagon
Member#: 26859
of TXIC
initial findings are that from the bottom hangar (closest to ground) to the flange that bolts to the y pipe on the legacy muffler are 17" even, on the sedan it is 16".
didn't do any measurements on the top hangar for the legacy, but I'm guessing that is off by an inch as well, maybe more.
I'll probably not measure the rest of it though...
Old 09-20-2007, 10:44 PM   #23
ringe
Member#: 49998
2007 WRX CT Stg 2
The wheel needs to be designed to recieve them, I think. Or, when you upgrade you could just take the sensors off your old wheels and bolt them to your new ones and see if they hold pressure. If so you're in luck.
ringe is offline   Reply With Quote
Old 10-06-2007, 09:46 PM   #24
z&cobb
Member#: 12344
2002 2JC
blue
It was an option. Prodrive P7s. I have four sets of wheels. Two came with the car. I picked up another 17" and another 16" set. One of the 16" sets is loaned out for use on an Impreza L (it's not for go, but it shows nice).
z&cobb is offline   Reply With Quote
Old 10-09-2007, 02:49 PM   #25
JDWRX
Member#: 157691
2009 WRX265
I measured the swaybars with a digital caliper, the front is 20mm and rear is only 15mm
JDWRX is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
