Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-11-2009, 01:01 PM   #301
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
So i figure this is probably the best place for this post, seeing as im sure another exhaust thread doesn't need to be started.
Im starting to shop for an exhaust (still dont know if its gna be CBE or TBE) and im wondering which exhausts have more of that boxer rumble and which have that loud... semianoying tone. I want an exhaust that is nice and deep even at an idle, something that you hear and go... wtf. lol
wawawrx is offline   Reply With Quote
Old 02-11-2009, 07:48 PM   #302
The_Kasey
Member#: 192772
2011 STI
GREY
Just so everyone knows installing a boost guage on the 08/09 is a bitch! You have to take off the intercooler to hook up the damn thing.
The_Kasey is offline   Reply With Quote
Old 02-11-2009, 08:01 PM   #303
method
Member#: 57849
2008 WRX
^^ The intercooler is 5 bolts. It's not really a bitch.
method is offline   Reply With Quote
Old 02-12-2009, 02:44 AM   #304
The_Kasey
Member#: 192772
2011 STI
GREY
True but its more work than needs to be for a boost gauge haha
Old 02-12-2009, 11:08 AM   #305
method
Member#: 57849
2008 WRX
Yeah I guess I'm with ya there.
Old 02-17-2009, 03:17 PM   #306
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
so has anyone used a tactrix or any OS tune on the 08' WRX yet?
edit: has anyone done straight pipe exhaust? saw a clip on youtube and it sounded pretty good... dont want to end up losing HP or anything though
Old 02-17-2009, 03:52 PM   #307
FkVtech
Member#: 198968
2008 WRX
RIP Soccerkid52688
No its not, you run the wires thorugh the wheel well and poke a hole in the rubber. Its very easy lol.
FkVtech is offline   Reply With Quote
Old 02-28-2009, 11:56 PM   #308
Alpha14
Member#: 116537
Anyone know the size of the front anti-roll bar on the 2.5i Impreza? Couldnt locate any info after a number of searches. Also can the suspension parts (shocks, springs, anti-roll bars) from a '09 WRX be installed on a '09 Impreza 2.5i without issue?
Alpha14 is offline   Reply With Quote
Old 03-01-2009, 06:43 PM   #309
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
If your going to take wrx parts to a 2.5i u might as well grab the STi stuff while your at it. Suspensions shoudl swap clean though
Old 03-06-2009, 05:17 PM   #310
animator659
Member#: 181376
2008 STI
SPT pushed back their release of their 08-09 STI exhaust to may/june...Does anybody have an inside on when COBB will be releasing theirs?
animator659 is offline   Reply With Quote
Old 03-06-2009, 05:30 PM   #311
ILSMKU2
Member#: 77908
2011 E92 ///M3
RIP 11, 09, 06, 03 STI's
Do you really have to remove the intercooler for the boost gauge?
ILSMKU2 is offline   Reply With Quote
Old 03-08-2009, 12:57 AM   #312
animator659
Member#: 181376
2008 STI
Old 03-13-2009, 07:27 PM   #313
Mr. Ed
Member#: 99211
2014 Legacy
money can't buy you love
no
Mr. Ed is offline   Reply With Quote
Old 03-15-2009, 06:48 PM   #314
rrsettgast
Member#: 104
2009 WRX Wagon
Hi,
I have an 09 WRX. I am getting a new DP and a tune by Ed at EQ next weekend. While I didn't discuss it with Ed yet, I am thinking that I should probably upgrade to a larger TMIC. I am thinking a Perrin, because they seem reputable, and there aren't a whole lot of options out there...are there? Anyways, I have a concern with the scoop channel (splitter...or whatever the heck it is called). It channels the air into the footprint of the small stock TMIC. I may have to remove the thing completely to accomadate the larger IC. I am thinking that this isn't going to be effective. Anyone know if this should be a concern? I wonder if I should pick up a STI splitter as it obviously would be better suited to channel the air through the Perrin IC. Anyone have a knowledge about such things?
Thanks
rrsettgast is offline   Reply With Quote
Old 03-15-2009, 11:47 PM   #315
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
Originally Posted by rrsettgast View Post
Hi,
Thanks
i was just looking at my splitter the same way the other day... looks like the splitter is wide enough for an STI TMIC if you take out the (diffusers?) that direct the air inside the splitter... idk if you can do that or not and then DIY air directors
Old 03-24-2009, 01:59 AM   #316
xandi911
Member#: 163991
xandi911 is offline   Reply With Quote
Old 03-24-2009, 09:06 AM   #317
640k
Member#: 160315
2008 STI
you guys don't need a new TMIC. you don't even need a new intake until you start going big. both the intake and TMIC have been proven to handle 400hp. a DP is WELL within the capacity.
640k is offline   Reply With Quote
Old 03-24-2009, 12:47 PM   #318
method
Member#: 57849
2008 WRX
You can get same power with a less agressive tune with a larger TMIC as temps will be lower. I would suggest getting a larger TMIC, it will only help.
Old 03-25-2009, 12:21 PM   #319
ScudRunner
Member#: 196212
08 WRX
Lightning Red
No. But, the instructions for the SPT boost gauge that is out now direct you to do so. So, if you want to follow those directions to the letter, then you do need to remove the TMIC in order to get to the pre-existing hole in the driver's side of the firewall.
ScudRunner is offline   Reply With Quote
Old 04-03-2009, 10:28 AM   #320
DDScooby
Member#: 161876
02 Impreza WRX
Cool
Picking up my Lightening Red 09 WRX on the 23rd and I just ordered the Cobb AP, Invidia V3 DP, TurboXS Up-pipe, Invidia Q300 catback and drop filter. scheduling a Dyno day at EFI Logics for around the1st of May. Will post results after its all said and done....
DDScooby is offline   Reply With Quote
Old 04-03-2009, 11:15 AM   #321
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
dont buy the extended warranty
Old 04-03-2009, 05:54 PM   #322
popnfrresh
Member#: 201756
2009 WRX Premium
Obsidian Black Pollen
I would be careful of all those parts right away. There is a good chane you'll spun bearing in your 2009 < 2000 miles. I would wait.
popnfrresh is offline   Reply With Quote
Old 04-06-2009, 12:37 PM   #323
DDScooby
Member#: 161876
02 Impreza WRX
I thought about putting that in my previous post, that just being a given to break in the motor for the first 3-5k or so. But yes the motor will be properly broke in BEFORE anything is done to it.
Old 04-18-2009, 03:50 AM   #324
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
Originally Posted by beaquel View Post
I sure wish they would, by I have a hunch there won't be one. I just picked up the brand new SPT catalog last Saturday and there's not a single word about any upcoming SPT intakes. I'm guessing they did this to eliminate any liability for warranty costs associated with "potentially" leaned out A/F ratios.
From what I've been reading about to how the car is set up stock to retain the ULEV rating for the 2008 the A/F is already at a point where they aren't going to be able to release an Intake.
AEM seems to think theirs won't hurt the car, but then they don't have to warranty the car...
MurphysLaww is offline   Reply With Quote
Old 04-18-2009, 04:03 AM   #325
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
Originally Posted by jerinm08scoob View Post
Does anyone know how much torque a stock 08' clutch and transmission will hold? I have a premium 08' WRX premium and after smoking a few turbo civics I pulled into Sheetz and I could smell my clutch. The only thing I've done to my car is the SPT exhaust, which sounds nice btw but it isn't extremely loud. Also when I raced I launched from 2k rpms and let the clutch out fairly fast, which may have something to do with that, but I'm still curious.
Got that at about 19,000 miles letting the clutch out in second on a slight incline, probably 1500 to 2000 rpms. Was still smelling/slipping when I took it to the dealer. they did the late 15k service and swore up and down there was nothing wrong with the clutch, but no clutch smell/issue.
Also, not sure if you see this but going into 3rd is iffy unless the pedal is mashed all the way to the floor.
I guess I'll find out tomorrow, as it's going to it's first autocross. If it goes after that, I'm not going to feel right about calling them out on it regardless if there was something wrong it initially.
Guess I'll just put in a ACT at that point or something, because it's going to get AutoX'ed from here on out probably, and elevated from stock.
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 09:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 10:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 01:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 08:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 10:51 AM
