Old 10-13-2009, 10:11 AM   #351
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
I will have to say my 09 has some noisy ass relays in the cabin. When you have the front and rear windshield washers on, its just a clicking storm in there. Also when you put the key to on and/or remove the key, all sorts of relay clicking .
09rexwagon is offline   Reply With Quote
Old 10-13-2009, 10:51 AM   #352
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
I'd get that checked out
wawawrx is offline   Reply With Quote
Old 10-18-2009, 01:48 AM   #353
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
does anyone know if 02-07 wrx bov's will fit our 09's?
thatkhmer is offline   Reply With Quote
Old 10-18-2009, 09:53 AM   #354
09rexwagon
Member#: 216135
2011 Civic SI
I stopped by the dealer and the service dept. was closed but I got my sales man to get the keys to a 09 WRX and a 09 Impreza wagon and both of them were identical to the relays in mine. And to explain further, I am very very sensitive to noises from my car so I probably exaggerated above . Usually wiper relays are in the engine bay, but in the Impreza they are under the dash and not very well insulated.
Old 10-22-2009, 11:13 PM   #355
Bryanwrx
Member#: 157349
2010 WRX
read BOV FAQ
Bryanwrx is offline   Reply With Quote
Old 10-23-2009, 05:00 AM   #356
Mr. Ed
Member#: 99211
2014 Legacy
money can't buy you love
no they will not direct bolt on. there are a few companies such as wbr out there that make adapter plates so that you can use any BOV you would like . There are also a few after market bolt on BOV solutions
Mr. Ed is offline   Reply With Quote
Old 11-02-2009, 10:21 AM   #357
angryscientist
Member#: 114300
anything changing in 2010?
angryscientist is offline   Reply With Quote
Old 11-02-2009, 10:29 AM   #358
09rexwagon
Member#: 216135
2011 Civic SI
The back of the car has an AWD sticker .
Old 11-02-2009, 11:15 AM   #359
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Different bearings in WRX?
silver arrow is offline   Reply With Quote
Old 11-05-2009, 07:30 PM   #360
31motors
Member#: 198830
what is this black blower looking thing under the hood by the alternator? 08 sti.
31motors is offline   Reply With Quote
Old 11-05-2009, 10:00 PM   #361
09rexwagon
Member#: 216135
2011 Civic SI
Air pump. Next time you start your car, listen very carefully. It will sound loudish for about 15 seconds. Then you'll hear a pshhhhhhh and the engine will idle quieter. That is the secondary air pump shutting off.
Old 11-05-2009, 11:27 PM   #362
therealratfink
Member#: 192817
2010 WRX STi
Bright Freakin' Red
Yeah, anyway to kill it? I hate that sound. Always louder after stage 2.
therealratfink is offline   Reply With Quote
Old 11-06-2009, 09:26 AM   #363
09rexwagon
Member#: 216135
2011 Civic SI
You can remove it, the tubing, and the driver side valve. However the MAP is inside the passenger side valve so you have to keep it. Then you need to buy blockoff plates and have a tuner to tune out the CELs.
Old 03-30-2010, 02:09 AM   #364
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
will a downpipe from an 04 sti even remotely work on a 2010 sti?
04wrexsti is offline   Reply With Quote
Old 03-30-2010, 08:21 AM   #365
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
nope.
you may be able to cut it, i know some of the 08 sedan owners were able to fenagle the 08 STi DP onto their cars
Old 04-06-2010, 10:16 PM   #366
sonicboom199
Member#: 216804
2008 Impreza WRX
WR Blue
that sway bar measurement is accurate
sonicboom199 is offline   Reply With Quote
Old 06-05-2010, 11:00 PM   #367
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
Would the end of older dp's bolt onto our turbos at least?
Old 06-07-2010, 09:00 PM   #368
McKenzie83
Member#: 207896
11 STi limited
Originally Posted by JDWRX View Post
I measured the swaybars with a digital caliper, the front is 20mm and rear is only 15mm
I run the PERRIN stiff kit which is 25mm f/22mm r and with their endlinks...definitely worth every penny I spent! Current setup is the softest on both the front and rear as I drive some gnarly Kentucky roads.
McKenzie83 is offline   Reply With Quote
Old 06-08-2010, 07:44 AM   #369
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
So if anyone loses a shifter linkage pin while driving, you're not the only one
Old 06-13-2010, 05:16 PM   #370
WRX09MD
Member#: 222160
2014 Audi S4
Glacier White
Mine is super loud for about 10 to 15 seconds after start up. I can here it out of the exhaust and it sounds nasty. I don't like the sound at all. Does not sound healthy.
WRX09MD is offline   Reply With Quote
Old 07-01-2010, 12:39 PM   #371
Kings028
Member#: 241526
2010 WRX Limited
E85 tuned -352hp/389tq
There are actual differences between the two years:
Sway bay is larger, side ground effets are slightly different design, offered in different colors, models (IE. limited) , nav system is slightly different, interior changes (tones, stitching), ECU maps are unique to each year, 0-60 specs are supposebly different (not sure how) but SOA have quoted seperate times for each year.. ('10 being slightly faster)
all in all, pretty much the same, lol subaru didnt just put a badge on a car and say here is our 2010 lineup haha..
Kings028 is offline   Reply With Quote
Old 07-01-2010, 01:31 PM   #372
09rexwagon
Member#: 216135
2011 Civic SI
Front and rear ARBs have the same part number from 09->10
Old 07-13-2010, 07:07 PM   #373
UncleSpud
Member#: 144294
09 WRX Sedan
Sorry--posted here by mistake
UncleSpud is offline   Reply With Quote
Old 07-31-2010, 06:37 PM   #374
oldmule
Member#: 248444
2010 WRX
Was told they fixed suspension problems with the 08-09 models with the 10.... Don't really know what the heck that means though....
Anyone have any ideas????
oldmule is offline   Reply With Quote
Old 09-15-2010, 04:33 PM   #375
SWP impreza GH
Member#: 257488
2011 Wrx Sedan
Sparkling Silver
Will factory 08 sti exhaust bolt up to the 08 wrx wagon with minor mods?
SWP impreza GH is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
