Old 09-15-2010, 04:34 PM   #376
SWP impreza GH
Member#: 257488
2011 Wrx Sedan
Sparkling Silver
Will it have any power gain or loss?
SWP impreza GH is offline   Reply With Quote
Old 09-15-2010, 04:41 PM   #377
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Originally Posted by SWP impreza GH View Post
Will factory 08 sti exhaust bolt up to the 08 wrx wagon with minor mods?
Yes, you have to cut your bumper and it will stick out farther and not be perfectly centered in the pre-existing hole on the passenger's side. The muffler weighs about 11 lbs more than your axle back and I doubt you'd feel any difference. It'll probably sound a bit different though.
09rexwagon is offline   Reply With Quote
Old 09-15-2010, 05:34 PM   #378
SWP impreza GH
Member#: 257488
2011 Wrx Sedan
Sparkling Silver
Has anyone done this before?
Old 09-15-2010, 06:23 PM   #379
09rexwagon
Member#: 216135
2011 Civic SI
Yes, is your 08 a base or premium? The only ones who have done it had a 08 Premium or a 09+ WRX. I have a feeling the black diffuser is going to be more forgiving when you cut into it than the body colored bumper of a regular impreza or the base 08 WRX.
Search and you'll find it.
Old 09-28-2010, 02:10 AM   #380
Lboogie
Member#: 171611
2014 FiST
Blk
No, it doesn't stick out further.
And is pretty centered :
Had the resonator cut out of the midpipe to mitigate the "extra 11lbs" from the STi axleback section.
Lboogie is offline   Reply With Quote
Old 09-28-2010, 10:09 AM   #381
09rexwagon
Member#: 216135
2011 Civic SI
Your exhaust guy did a very good job. All the others who have put a STI quad tip on a WRX (as in pure bolt on...your resonator delete may have changed the geometry in a desireable way) have noted the tips stick out an inch or so farther than the stock WRX exhaust and was not perfectly centered in the cutout (closer to the inside of the car).
Old 09-29-2010, 09:13 PM   #382
SWP impreza GH
Member#: 257488
2011 Wrx Sedan
Sparkling Silver
That looks great! What is that add on piece in the first pic? Custom made or aftermarket?
Old 09-29-2010, 09:17 PM   #383
SyvarrisWRX
Member#: 259391
2005 Impreza WRX
Default Heads up
08-2010 STI and Legacies are tuning nightmares. No longer imported american made crap boxes that look lean and mean. Beautiful cars no longer Jap made. American. Chassis is completely different along with engine parts that make the cars terrable at holding a tune. Lots of chain reactions.
SyvarrisWRX is offline   Reply With Quote
Old 09-30-2010, 08:59 AM   #384
btr22
Member#: 116322
2010 WRX Sedan
Red, All Stock
Default Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan
I like the quad tip look and want to hear more boxer rumble which is totally absent from the 2010 sedan. I know the black diffuser would have to be cut/modified to fit the wider quad tips but besides that will it just bolt right on??
btr22 is offline   Reply With Quote
Old 10-06-2010, 05:55 PM   #385
oldmule
Member#: 248444
2010 WRX
2010 is different animal vs the 09 in a lot of cases. It sucks trying to get parts that are supposed to be for 08-10 but won't fit the 10.... All new TMIC, so forget anything for the 09 on it. Redesigned body in some ways - grill, air inlet (already ported the grill area, no sound box). Electrical under dash is a bit different too, I tied in wires to gauges from the fuse panel and it's not the same as pics I was using from an 09.
oldmule is offline   Reply With Quote
Old 10-08-2010, 01:11 PM   #386
09rexwagon
Member#: 216135
2011 Civic SI
TMIC is the same. Call your Subaru dealer and ask for the part number for an 08, 09, 10 WRX. I'd put money that it's the same PN .
Old 10-08-2010, 01:19 PM   #387
Stretch18
Member#: 239822
2010 WRX
t(-_-t)
My window sticker says 100% of parts made in Japan; assembled in Ota Gunma, Japan...
http://www.cars101.com/subaru_windowstickers2010.html
Stretch18 is online now   Reply With Quote
Old 10-08-2010, 01:20 PM   #388
09rexwagon
Member#: 216135
2011 Civic SI
Yeah, that guy's post is just one of those that you need to ignore. Not even worth calling him out on that garbage rambling .
Old 10-28-2010, 06:34 PM   #389
TrueSilver
Member#: 152207
2006 OBP STi
2015 Duramax LML
Can someone clear this up for me on fitments? I have a 2010 STi.
are these parts all the same as far as bolting on?
A. 08-09 STi Downpipe
B. 08-09 STi CBE
and..
A. 08-09 Wrx 5Dr Downpipe
B. 08-09 Wrx 5Dr CBE
TrueSilver is offline   Reply With Quote
Old 11-02-2010, 10:58 AM   #390
BMW_TT
Member#: 242893
I'm looking to get a 2008 WRX STi, are they known to have any issues? This one has 60k miles.
BMW_TT is offline   Reply With Quote
Old 11-02-2010, 11:06 AM   #391
KurtP
Member#: 44836
1999 Fozzy
wtf are you talking about?
KurtP is offline   Reply With Quote
Old 11-21-2010, 08:27 PM   #392
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
B. 08-09 STi CBE
and..
the downpipes from 08 and on wrx and sti are all the same. the catbacks are different. the wrx hatch has one outlet. the sti hatch has 2 outlets.
424wrx is offline   Reply With Quote
Old 11-30-2010, 11:18 AM   #393
i_got_turbo_do_you
Member#: 214604
08 sti
blacked out
subscribed! I will use this info
i_got_turbo_do_you is offline   Reply With Quote
Old 12-05-2010, 04:50 PM   #394
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Posting in here to start...hopefully someone will know.
So I'm going to be doing a TBE install this week. My question is:
What size o2 sensor socket should I buy? My car is a 2009 WRX 5dr.
(No...i don't mind spending an extra $5 on a specific socket. Please don't suggest I just use an open ended wrench or something. I want to ensure nothing gets stripped and that's why I specifically want to buy an o2 sensor socket. Just need to know what size.)
Thanks!
matthew
QwaktastiK is offline   Reply With Quote
Old 12-05-2010, 04:54 PM   #395
09rexwagon
Member#: 216135
2011 Civic SI
7/8" or 22mm.
A trick I've learned over the years with o2 sensors, is to use some catalyst (pb blaster), warm the engine up, get a can of compressed air, turn it upside down and spray it on the O2 sensor. Then put your wrench or socket on there and it pops right off. The compressed air propellant comes out super cold (thank the Joule-thompson effect) and cools it down very quickly and the male threads cool faster than the female and loosen the joint.
Old 12-11-2010, 07:35 PM   #396
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
also one more tip. unplug the wiring under the car for the o2 sensor. then pull out the whole downpipe out,sensor and all. then you can remove and reinstall it in a vise or something. its much easier than removing it under the car.
Old 12-11-2010, 07:36 PM   #397
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
stis are still made in japan sir! good bits of info in this post.
Old 01-27-2011, 09:48 AM   #398
sumfoo1
Member#: 82146
2005 Legacy GT
Any idea what stock boost is? i forgot.
sumfoo1 is offline   Reply With Quote
Old 01-27-2011, 11:39 AM   #399
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
2008 WRX:
11.4psi
2009 WRX:
13.3psi
http://www.insideline.com/subaru/imp...preza-wrx.html
2008 STI:
14.7psi
http://www.popularmechanics.com/cars/news/4234646
2011 WRX:
14.2psi
2011 STI:
14.7psi
http://www.subaru.com/content/static...x/compare.html
Old 01-30-2011, 02:54 PM   #400
Infra_red
Member#: 127001
2008 Legacy 2.5i
02 bugeye got totaled and now I am the proud owner of a 08 Legacy 2.5i. Couldn't afford a GT so what are my options for small power gains if any?
Infra_red is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
