Old 03-19-2011, 01:25 AM   #401
swagn
Member#: 275079
2009 Impreza
WR Blue Mica
Originally Posted by 2fst4u2c View Post
17" wheels of an 02 wrx will fit a 08 wrx!
All WRX's are 5 x 100mm wheel fitments.
The '04 STi also has 5 x 100mm, so if you come across a set of the BBS wheels that someone is willing to sell you for a decent price, I'd say to jump on it!
swagn is offline   Reply With Quote
Old 08-21-2011, 12:23 PM   #402
Flinkly
Member#: 282219
i just want to know if i can buy a subaru blue t-fitting for my BPV valve. i don't even have an impreza.
Flinkly is offline   Reply With Quote
Old 10-17-2011, 10:53 AM   #403
08wrbrex
Member#: 293186
2006 WRX
will a perrin turbo inlet work from a 04-05 wrx on a 08 wrx?
08wrbrex is offline   Reply With Quote
Old 10-17-2011, 02:16 PM   #404
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Nope.
09rexwagon is offline   Reply With Quote
Old 10-17-2011, 02:40 PM   #405
08wrbrex
Member#: 293186
2006 WRX
ah crap . i was looking around on a friends toatled 05 wrx and that caught my eye. thanks tho!
Old 10-28-2011, 05:56 PM   #406
wayward167
Member#: 253998
13 BRZ
Originally Posted by QwaktastiK
Just FYI: the specific boost your car runs may be different on the stock tune due to varying atmospheric pressure ( elevation for example)
Logged my friends stock 08 at 4500ft and it made 14.5 psi
My 11 at 4300 ft was 16.6
wayward167 is offline   Reply With Quote
Old 11-03-2011, 07:08 PM   #407
A2WREX
Member#: 292143
2010 WRX Premium
Silver PSM
http://performance.importrp.com/spec.../i-174038.aspx
http://performance.importrp.com/act/...0/i-47713.aspx
will these still fit on my 2008 wrx... im assuming they will, but wanted to double check. im was gonna order them tomorrow
thanks in advance
A2WREX is offline   Reply With Quote
Old 11-16-2011, 02:09 PM   #408
lando
Member#: 149637
2010 STI SE
Should make a 2008+ subforum for each model :X Unabomber get crackin!
lando is offline   Reply With Quote
Old 11-25-2011, 07:58 PM   #409
ryanwilder8
Member#: 300267
2010 WRX
GREY
Default wrx to sti turbo upgrade
i have a 2010 wrx with full exhaust intake and a AP with stage 2 tune. i really want to get a STI turbo from a 2010 or 2011 but im not sure what my turbo is or the STI turbo. also im not sure what mods i would need to do. is it as simple as taking off the stock wrx turbo and putting on the STI one? will i need to change the fuel pump, injectors anything?!?! does a WRX and a STI have the same internals? please let me know im new to subarus and really trying to make my car a quick daily driver.
ryanwilder8 is offline   Reply With Quote
Old 12-15-2011, 09:12 PM   #410
chino_487
Member#: 209156
2009 WRX Sedan
SSM
2009+ WRX turbo = VF52
2008+ STI turbo = VF48
its been said that the two are very similar. imo not worth the upgrade. do a quick search and you can find more information on each respectively.
chino_487 is offline   Reply With Quote
Old 12-15-2011, 11:13 PM   #411
PearlRex11
Member#: 284420
2011 WRX Sedan
Don't quote me but from what I've heard the only difference between vf48 and vf52 is in the turbo/intercooler connection. Example: you cannot swap a 2011 wrx intercooler with a 2011 sti one because the piping won't match up due to the point of connection being in different locations. I believe the wrx one runs straight up to the intercooler on the left side whereas the sti connects more in the middle of its intercooler. No difference between the two otherwise. I have heard that the sti internals are not only different but stronger as well. Hopefully that gives you somewhere to start your search.
PearlRex11 is offline   Reply With Quote
Old 01-03-2012, 04:08 PM   #412
Matt08WRX
Member#: 169656
2008 WRX 4DR
SSM 331hp/362tq MPS tune
IMO waste of money. VF52 performs very similar. Just get a pro-tune if you havent already and talk to your local tuner for more info about upgrades.
Matt08WRX is offline   Reply With Quote
Old 02-04-2012, 01:27 PM   #413
Red09WRXtacy
Member#: 302588
09 WRX Hatch
Red
Your friend also has a td04 in his 08wrx. Not the vf52 09+ has.
Red09WRXtacy is offline   Reply With Quote
Old 02-05-2012, 03:19 AM   #414
8toedjoe
Member#: 309161
Default talk about going through the loops
I have been trying to post to find some parts for my 09 FXT... anyone have any knowledge about the factory turbo on an 09 FXT?
8toedjoe is offline   Reply With Quote
Old 02-05-2012, 11:52 PM   #415
2008blackwrx
Member#: 266664
2008 WRX Stage 2
I have an 08. td04 sucks compared to vf52. I did the swap about a year ago, and it screams!
2008blackwrx is offline   Reply With Quote
Old 02-12-2012, 11:10 AM   #416
malloy
Member#: 307872
2013 WRX
Default Turbo warranty
If you replace the turbo heat shield with a grim speed do you know if that will cancell out my warranty. Thank you
malloy is offline   Reply With Quote
Old 02-12-2012, 11:13 AM   #417
malloy
Member#: 307872
2013 WRX
Default 2008+ wrx forums
Yes it would make things much easier.
Old 02-12-2012, 12:24 PM   #418
Matt08WRX
Member#: 169656
2008 WRX 4DR
No...
Old 04-02-2012, 10:59 PM   #419
elbertmurphy
Member#: 268256
2005 STI
will a dc uel header for a 08 wrx fit a 2005 sti?
elbertmurphy is offline   Reply With Quote
Old 04-17-2012, 01:44 AM   #420
stsdude2
Member#: 307161
2008 wrx
Will my 2008 wrx fit on my 2008 wrx?
stsdude2 is offline   Reply With Quote
Old 04-17-2012, 02:12 AM   #421
xlr8onu
Member#: 36015
2014 Grand Cherokee
^^^ My sources say no ^^^
xlr8onu is offline   Reply With Quote
Old 04-17-2012, 11:33 AM   #422
PearlRex11
Member#: 284420
2011 WRX Sedan
Do a search. I think some legacys and foresters will fit your wrx?
Old 04-17-2012, 12:04 PM   #423
stsdude2
Member#: 307161
2008 wrx
I already tried to drop a legacy into my WRX, it just ended up crushing the car and making a huge mess!
Old 04-17-2012, 09:43 PM   #424
PearlRex11
Member#: 284420
2011 WRX Sedan
Sounds like a bushings problem. Upgrade everything to kartboy and add a bov. Then sit back and enjoy.
Old 05-16-2012, 02:38 PM   #425
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
Not sure on the intercooler part, I cant see subaru rotating the turbo slightly to accommodate for a bigger intercooler.
the difference between the 2 turbos is mainly the wastegate to hold boost better, also the dimensions are very very slightly different.
The STi internals are not different other than the pistons which are domed more but only slightly. Between the 2 motors one is no stronger than the other as they both have the same issues with ringlands (as far as pistons go). the big difference in the STi motors are their heads, they flow much better than the stock WRX heads, but I have been told that modded ej255 heads vs modded ej257 heads the 255 heads flow much better.
2011-2012 wrx vs sti is very minimal. The tranny and suspention is what you pay for, as for power, a pro tune on a wrx will get you the same power as a STOCK STi, along with some simple bolt ons.
Jmhm17 is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
