Old 05-16-2012, 04:20 PM   #426
mcuzzin
Member#: 292732
2007 FXT
SGM
Originally Posted by Jmhm17 View Post
Not sure on the intercooler part, I cant see subaru rotating the turbo slightly to accommodate for a bigger intercooler.
the difference between the 2 turbos is mainly the wastegate to hold boost better, also the dimensions are very very slightly different.
The STi internals are not different other than the pistons which are domed more but only slightly. Between the 2 motors one is no stronger than the other as they both have the same issues with ringlands (as far as pistons go). the big difference in the STi motors are their heads, they flow much better than the stock WRX heads, but I have been told that modded ej255 heads vs modded ej257 heads the 255 heads flow much better.
2011-2012 wrx vs sti is very minimal. The tranny and suspention is what you pay for, as for power, a pro tune on a wrx will get you the same power as a STOCK STi, along with some simple bolt ons.
^Like.
Do you know about 04-05 STi TMIC fitment on the 2011's? Whether or not there's modding involved..etc.
mcuzzin is offline   Reply With Quote
Old 06-11-2012, 09:30 AM   #427
DJREMIXED
Member#: 319439
2008 impreza wrx
Default Nice I just got a 2008 WRX two weeks ago
Thanks for the post. I got some good info here.
DJREMIXED is offline   Reply With Quote
Old 06-11-2012, 12:17 PM   #428
Oakley1589
Member#: 304963
2013 BRZ
how about a 2004 wrx cobb intake on an 08 sti? anyone try any of the intakes from the gd's on the gr's?
Oakley1589 is offline   Reply With Quote
Old 09-17-2012, 03:07 PM   #429
TS7XREX
Member#: 287450
2011 Impreza WRX
Satin White Pearl
Way to go offering bad info JMHM17.
Intercoolers do not interchange.
No good info here.
The pistons are not domed more as they are lower compression. Maybe inverted dome?
Many WRX's have been dyno'd to have very similar peak HP and TQ outputs stock. On the STI you also get "upgraded" diffs, Brembo brakes, and 18x8.5" wheels.
My 2 pennies worth.
TS7XREX is offline   Reply With Quote
Old 09-19-2012, 01:46 PM   #430
H0D0R
Member#: 332669
Exclamation Possible issue 2008 Legacy GT
I'm not sure if this is the best place to put this but I couldn't find a more appropriate thread and I am unable to create a new thread because I just created this account.
I just got a 2008 GT last week and am very pleased, but with one possible issue. I have a steep uphill driveway where it is possible to stall-out from not giving enough gas. Thankfully, the first time I stalled the GT was in the driveway and not on a road, because I was unable to restart. The entire car would power on with lights, radio and everything internal, but nothing whatsoever sent to the engine, so it seems like some computer-related issue.
I tried every possible combination I could think of such as trying from reverse, neutral, or first, parking brake on/off, putting the key into different positions and taking it out completely. I honestly do not know exactly what if anything I did different, but it eventually turned on after about 5-10 minutes so I parked in the garage and left it for the night.
The next day I intentionally tried to reproduce the issue to see if it would happen again and if I could figure out what triggered it to eventually work. The same thing occurred and nothing I tried was working at all. I eventually 'gave up' and was just going to park in the driveway so I opened the door to go inside. I figured what the hell, I should try one last time, and lo and behold, it did start up. Therefore, the only thing I can think is that opening the door reset or cleared something related to the stalling but that doesn't really make sense.
I called the dealer and scheduled a service appointment for next week but I figure that it wouldn't hurt to ask here if anyone has experienced anything similar or has suggestions.
H0D0R is offline   Reply With Quote
Old 11-11-2012, 12:40 AM   #431
08subiedude
Member#: 334509
2008 Impreza WRX
White Pearl
Push in the clutch
08subiedude is offline   Reply With Quote
Old 12-20-2012, 12:22 PM   #432
sarahsez00
Member#: 341144
Will it have any power gain or loss?thanks
sarahsez00 is offline   Reply With Quote
Old 02-15-2013, 10:36 PM   #433
Olson_1990
Member#: 334952
08 Wrx
Pearl white
Default i heard trani is stronger
Altho the factory suspention on wrx sucks
Olson_1990 is offline   Reply With Quote
Old 05-13-2013, 08:25 AM   #434
dmerc4
Member#: 356296
Default Bov
I'm new to Subaru, and some people say to stay away from BOV's, then others say that as long as its recirculated it will be fine. What have u guys found to be the best so far?
dmerc4 is offline   Reply With Quote
Old 05-13-2013, 09:16 AM   #435
PearlRex11
Member#: 284420
2011 WRX Sedan
The stock valve on our cars is a recirculating valve not a bov the only reason to get a new recirc valve is if yours is leaking. Bov's release the air into the atmosphere, this air has already been "seen" by the mass air flow sensor and your ecu has determined the fuel needed for that amount of air. Therefore when the air is released instead of recirculated, your car will run slightly rich. Please Google if you need more info, unibombers manifesto probably has bov info in it as well.
PearlRex11 is offline   Reply With Quote
Old 05-13-2013, 10:27 AM   #436
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
read all 18 pages, no mention of header fitment between GD and GR?
header may be slightly different
up pipe may be slightly different
but what about the COMBO of the two? is the turbo in the same location relative to the exhaust ports? IE, will a header up pipe combo from a GD fit on the new cars? they use the same motor, so my inclination is yes, but i havent seen any confirmed results. some people say yes, some people say no.
anyone have a definitive answer?
gsrcrxsi is offline   Reply With Quote
Old 07-03-2013, 03:31 PM   #437
takeadirtnap
Member#: 344507
2010 WRX
will your mom fit on my car?
takeadirtnap is offline   Reply With Quote
Old 12-19-2013, 05:50 PM   #438
bigboy3269
Member#: 296457
Default No 2008
I should have stayed away from the 2008 year and went with 2009, such a difference in the 2 cars
bigboy3269 is offline   Reply With Quote
Old 01-07-2014, 12:20 PM   #439
dead_ringer
Member#: 377848
2013 WRX Sedan
PBP
This is a noob question and it may have already been answered but is the downpipe interchangeable between the EJ motors? Thanks for any help regrading my question and for not laughing (too hard) at my inexperience!
dead_ringer is offline   Reply With Quote
Old 06-09-2014, 04:44 AM   #440
bashar_ra
Member#: 393019
good one thnx
bashar_ra is offline   Reply With Quote
Old 10-22-2014, 02:10 PM   #441
osuguy17
Member#: 359288
Good info thanks
osuguy17 is offline   Reply With Quote
Old 01-21-2015, 07:13 PM   #442
subaru_gc8
Member#: 29292
2004 WRX wagon
o it up any 99BBC zed gain or4 lOkk8oss?[img]http://talent kid . 5
!4=9
[quote=dmerc4;39794692]I'm new to Subaru, and some people say to stay away from BOV's, then others say that as long as its rrecirculation name it will be fine. What havse u6 guys found to be the best so w
Originally Posted by 08subiedude View Post
Push in the clutch
I
e pulpits
Push in the clutch
U
subaru_gc8 is online now   Reply With Quote
Old 04-21-2015, 07:31 PM   #443
Area35
Member#: 419301
2010 Subaru WRX STI
Great info in this thread
Area35 is offline   Reply With Quote
Old 05-23-2015, 06:52 PM   #444
rexefx
Member#: 341518
08 wrx
dark gray
Update
unknown said:
Update: Subaru Recall WVF-16 Turbo Charger Oil Supply Pipe SAFETY DEFECT STOP SALE NOTICE September 22, 2008 As described in a Subarunet notice posted on September18th, Subaru of America, Inc. has initiated a voluntary Safety Recall to inspect, modify and possibly replace the turbo charger oil supply pipe on approximately 16,715 2007 & 2008 Legacy 2.5GT / Outback 2.5XT, 2008 Impreza WRX (except STI) and a very small number of early production 2009 Forester 2.5XT models. Campaign code WVF-16 has been assigned to this Safety Recall. A countermeasure was made in production on vehicles produced beyond the affected range. Please be advised that it is a violation of Federal law for a dealer to deliver a new motor vehicle covered by a recall under a sale or lease until the defect is remedied. Therefore, beginning immediately, any vehicles within the affected range that are currently in your new or used car inventory are placed on STOP SALE until the campaign is performed. Notify all Sales and Service personnel that any vehicles within the affected range are not to be sold until the defect has been resolved. The Defect Affected vehicles may have been manufactured with a turbo charger oil supply pipe that was deformed due to misalignment during the assembly process. If the pipe is deformed, vibration experienced during normal driving could result in a crack developing over time, causing an engine oil leak. There is a safety risk associated with this condition. If leaking oil contacts components operating at high temperatures, an engine compartment fire could result. The affected vehicle range is: Model From To 2007MY Legacy Sedan 2.5GT 7*200020 7*215147 2007MY Legacy Wagon 2.5GT / Outback Wagon 2.5XT 7*300013 7*346075 2008MY Legacy Sedan 2.5GT 8*200004 8*222000 2008MY Outback Wagon 2.5GT 8*300006 8*351020 2008MY Impreza WRX 4 Door 8*500002 8*522433 2008MY Impreza WRX 5 Door 8*800005 8*823185 2009MY Forester 2.5XT 9*700001 9*700139 * Various
rexefx is offline   Reply With Quote
Old 05-23-2015, 06:55 PM   #445
rexefx
Member#: 341518
08 wrx
dark gray
Do your research before purchasing the affected years. Its been a month and I still don't have my car back.
Old 06-01-2015, 06:48 PM   #446
ncsubilover
Member#: 422595
just getting my thrid responce so i can aska question myself!
ncsubilover is offline   Reply With Quote
Old 09-17-2015, 08:30 AM   #447
Shanenoo77
Member#: 430313
Default Boost reading early?
I didn't really see anything that helped me in sticky....
I have a 08 wrx.108k miles. I bought it used. I have a boost gauge on it and it show that I'm making boost before 3000rpm. If I'm running at 2000 and push the throttle more than half way it will show that I'm making boost. Is this normal? The other thing is I'm getting surge. Usually at lower rpm not really after 4500. Time for turbo rebuild? I know plugs need to be changed. Clutch is starting to slip. So I'm looking to knock out all the usual maintenance soon.
Shanenoo77 is offline   Reply With Quote
Old 10-21-2015, 08:10 AM   #448
archie_munoz
Member#: 430777
So i have an 08 wrx. Ive blown 3 turbos in the past 2 months. Could this be my problem? If its a recall would my car be coveres? Ive looked but didnt find an answer. Anything will help thanks.
archie_munoz is offline   Reply With Quote
Old 11-01-2015, 08:10 PM   #449
yungwang
Member#: 423333
bump.
yungwang is offline   Reply With Quote
Old 11-27-2015, 06:14 PM   #450
Jdmsti07
Member#: 435083
Originally Posted by 2fst4u2c View Post
17" wheels of an 02 wrx will fit a 08 wrx!
yes they should fit just fine
Jdmsti07 is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
