Old 08-14-2007, 03:40 PM   #1
varmint007
Member#: 13626
0298 M5M3
E39E36
Default turn-key Enginuity in-Dash computer
looking for some advice from the Car-PC experts here.
I am getting real lazy about bringing my laptop with me on tuning runs, and I'm constantly wanting to see real-time Knock data - so I'm trying to get a shopping list together for building a hardwired computer right into the car. Then I plan to move the ROMs, logs, etc over wifi or USB drive.
I already have one of these Kenwood Excelon DDX7015
That I'm hoping I can use as a monitor (over s-video) but the touchscreen probably won't help me at all (planning on using wireless keyboard and mouse).
Looking for recommendations for the rest of the hardware. I have a lot of experience building PCs but never for a car.
What kind of budget am I looking at to do it right?
Also, this seems to be a pretty good market for some of you hardware geeks with time on your hands. Build a standalone unit exclusively for tuning, keep the price down (maybe south of $700) and it would sell.
varmint007 is offline   Reply With Quote
Old 08-14-2007, 05:00 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Subscribed because I want to see where this goes.
06rexwagon is offline   Reply With Quote
Old 08-14-2007, 05:11 PM   #3
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
I have some computer connections i might be able to hit up... Actually that wouldnt be a bad idea to do something of that sort, I'll see what i can find for parts and making something cheap that would incorporate everything anyone would need...I think the best part would be the convince of map switching w/o a laptop to carry around...would compliment my anti-lag map that i'm working on pretty well
mxturboracer86 is offline   Reply With Quote
Old 08-14-2007, 05:19 PM   #4
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
my friend makes kits. www.carpc4u.com
the_colombian is offline   Reply With Quote
Old 08-14-2007, 05:43 PM   #5
varmint007
Member#: 13626
0298 M5M3
E39E36
cool - the whole box with screen for about $700 seems reasonable.
After doing some digging I found a barebones version for $360
I already have RAM, a laptop HD, and screen - this may be cheaper than I thought...
Old 08-14-2007, 05:45 PM   #6
scooterforever
Member#: 55011
I would love to see a ready-made solution customized for our application. Varmint007 -- if knock is the primary thing you are interested, you could do what some of us have done. I have a KnockLink which has 5 LEDs that light up depending on severity of knock: two green, two amber, one red. I have these wired to remote LEDs hidden in the center console dash vent, and also have wired the final red LED to fire a really annoying buzzer (low voltage high db Radio shack buzzer) that is also hidden in the dash vent.
scooterforever is offline   Reply With Quote
Old 08-14-2007, 06:17 PM   #7
varmint007
Member#: 13626
0298 M5M3
E39E36
Yeah, I've almost gone that route, but I really need to see *where* the knock happens (load and rpm) in order to tweak timing. Plus I'm addicted to seeing the Enginuity Logger dashboard for a handful of other values like: IAT, manifold, boost error, MAF, CL/OL, AF correction, etc...
If someone does start selling a Hardware tuning solution like this, it would be a cool way to pay the Enginuity team back. A portion of the proceeds should go to them. They could also have a paid support option.
Old 08-14-2007, 07:00 PM   #8
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Only problem i'm finding whether you do the building per mini-box or thru that guys friend's company.... with all the hardware req even if you do it yourself, you are talking $700-$900 total for this option (retail) depending on how cheap you can get everything you need. Most people who have an interest in doing open sopurce arent going to want to pay that, although there are many advantages and it can be incorporated into other standalone systems. Those thoughts aside I still like that idea and am going to look more into it as a marketable tuning solution to come out upon opening up my shop, b/c like i said it can be incorporated into more than just open source tuning.
-side note- For that price it'll be set-up so you can play DVD's, CD's, and do more than just tune... might as well put it to good use the other half of the time.
Old 08-14-2007, 09:34 PM   #9
scooterforever
Member#: 55011
There are a couple of ways to do that (but I hear you on your concerns). From a KnockLink perspective, you can do two things:
1. hook one or more of the LEDs up to a relay that will throw a <5v amount of voltage to an analog logger like the LM-1 (you can use a voltage divider circuit to reduce the normal 12v + to a voltage between 0 and 5v); or
2. assuming that you have removed the stock EGT probe, and that the ECU reads 0-5 volts to calculate EGTs (not sure about this, but I think that is what it does), you could splice the KnockLink with a relay to send a certain amount, say 2 volts, to the EGT signal line. That way you could log EGTs with enginuity, and use that to detect knock.
I followed approach #1. Here's is an example of how I was logging knock. In this particular case, I was having knock on the shift. This was with my old block, which [literally] knocked itself apart. I have a rod as a paperweight now. With the 4EATs, the ECU handles the shift by cutting fueling, and with this tune I had a lean spot on the shift. Boost is maintained through the shift with 4EATs.
Old 08-15-2007, 10:37 AM   #10
varmint007
Member#: 13626
0298 M5M3
E39E36
Ouch - I bet your new block will hold up much better!
That looks like very high RPM knock, which doesn't need much time to kill a motor. How long did it take?
Old 08-29-2007, 07:38 PM   #11
LathanM
Member#: 90486
2004 WRX
WR Blue
I was thinking on doing the same thing then I picked up a Samsung Q1. You can find them new for $700 if you don't go overboard with the features. Used for about $600. It handles everything a laptop does in a more manageable package.
LathanM is offline   Reply With Quote
Old 10-28-2007, 03:00 AM   #12
wjc04wrx
Member#: 58358
I can assist anyone that is looking for a CarPC solution, be it for tuning or anything else you would like it to do. The barebone system that you provide a link for is a barebone system and it uses a cheap motherboard that people have had problems with. I use only Via motherboards on all my systems and they have not failed me nor given me any trouble. You also have to think that for that price, you're only getting a case, power supply, and a cheap motherboard.
If any of you are interested in a CarPC for tuning purposes, I can help you out. Just send me a PM. If you already have some of the parts, you can send them to me and you can avoid that part of the hardware.
wjc04wrx is offline   Reply With Quote
Old 10-28-2007, 09:48 AM   #13
quazimoto
Member#: 70395
quazimoto is offline   Reply With Quote
Old 10-29-2007, 06:27 AM   #14
dynamix
Member#: 122603
They are working on a version of the PSI3 that has OBDII pass through so that you can hook up to a pc aswell. But, this does not solve the OP request.
dynamix is offline   Reply With Quote
Old 10-29-2007, 10:38 AM   #15
varmint007
Member#: 13626
0298 M5M3
E39E36
well it gets part of the way there...pretty cool to be able to monitor a bunch of values with a single DIN device. I never knew that existed.
Old 10-29-2007, 11:51 AM   #16
dynamix
Member#: 122603
It is cool but it could/should be so much better if they could save the logs from it and download them onto say an SD card for later proper analysis.
Old 10-29-2007, 01:00 PM   #17
varmint007
Member#: 13626
0298 M5M3
E39E36
Agreed - there's no way to pull logs from it?
Old 10-29-2007, 01:14 PM   #18
The Deliverator
Member#: 42376
2006 92x Aero
I've been thinking about this for a while.
How about: http://www.fit-pc.com/new/
The Deliverator is offline   Reply With Quote
Old 10-29-2007, 04:18 PM   #19
varmint007
Member#: 13626
0298 M5M3
E39E36
wow $295 is cheap!
comes with Gentoo preinstalled, but I supposed it would be easy enough to install XP.
Old 10-29-2007, 04:38 PM   #20
The Deliverator
Member#: 42376
2006 92x Aero
wow $295 is cheap!
My vision for this doesn't necessarily involve reflashing- I'd actually like to write a program that perpetually collects logs.
I guess you could also slap a small lcd into the dash and use it to flash as well, but I prefer to use a laptop for that- would hate for a bad battery or voltage gremlin to brick my ecu.
Old 10-29-2007, 09:00 PM   #21
varmint007
Member#: 13626
0298 M5M3
E39E36
I'd like to see a hardware/software combo that just simplifies the whole tuning process... Perpetual logging and interesting idea, then when you're done driving, the ability to scroll through some pre-built graphs of your drive.
Also, we certainly need real-time monitoring of the key variables, wifi to deliver the logs to your home network, and it might as well have all the other bells and whistles of a carpc (DVD playing, GPS, mp3, 3G card, full time internet to pull up google to settle arguments while driving , etc..)
Old 10-30-2007, 01:16 PM   #22
Freon
Member#: 88322
2009 BMW 135i
Get a docking station for your laptop and a touch screen.
Freon is offline   Reply With Quote
Old 10-30-2007, 01:33 PM   #23
varmint007
Member#: 13626
0298 M5M3
E39E36
that would work if I had a dedicated laptop, but I use my work laptop for tuning, so I'd have to set it up / break it down each time...
Old 11-11-2007, 01:20 AM   #24
neve_r_est
Member#: 92142
2002 WRX Wagon
I'm looking at doing this as well, but I've still got a ton of research to do both in opensource tuning and carpc building.
You have found www.mp3car.com right? Tons of carpc info floating around the forums there, and some decent kits as well. Just not so much on the tuning end of it, yet.
DG
neve_r_est is offline   Reply With Quote
Old 11-11-2007, 02:53 AM   #25
thechoochman28
Member#: 42900
For deltadash users, just released these free gauge packs...
http://www.quickflashtuning.com/ddgauges.shtml
thechoochman28 is offline   Reply With Quote
FS : 04/05 autoleveling harness for switch in dash knighter Exterior/Styling 6 09-11-2010 02:13 PM
WTT/FS: (IL) Kenwood in dash Nav ayanami22 MWSOC Private Classifieds 17 07-13-2010 10:10 PM
hard to turn key in ignition... Blindeye_03 Normally Aspirated Powertrain 8 03-16-2004 11:09 PM
7" touchscreen computer in dash kennious Off-Topic 31 11-20-2003 03:13 PM
turbo in!! any initial turn key advice? trey? andre? anyone? kid22 Technical Forum Archive 8 09-11-2000 08:12 PM
