Old 08-14-2007, 03:51 PM   #1
blueb3
Member#: 108471
Default 96 legacy wagon Brake Upgrades
Bang for buck, what should I look for? Rear calipers are about shot, and if I'm going to replace 2, why not 4? Any ideas or suggestions would be greatly appreciated.
blueb3 is offline   Reply With Quote
Old 08-14-2007, 04:02 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Upgrade to GT brakes? You can find used ones really cheap, I bet.
Wiscon_Mark is offline   Reply With Quote
Old 08-14-2007, 04:17 PM   #3
blueb3
Member#: 108471
I figured as much, I have just been out away from the forums for sooooooooooo long, I forgot all the "Subaru's are like Lego's" comments Thanks Mark! Time to go yard searching.
Old 08-14-2007, 05:11 PM   #4
spdracr00
Member#: 65823
1996 Impreza L
Red
PADS!!!! ditch those stock crappy pads and get a good set of pads all the way around.. also i'm sure you're still running stock fluid so a flush would help with pedal feel.. and if you have money left over get some SS brake lines. might as well do it all at once..
spdracr00 is offline   Reply With Quote
Old 08-14-2007, 05:12 PM   #5
spdracr00
Member#: 65823
1996 Impreza L
Red
if you cant find GT/Outback/RS brakes, the older Turbo legacy brakes are the same size as the GT/Outback/RS brakes.
Old 08-14-2007, 05:14 PM   #6
blueb3
Member#: 108471
full upgrade is the idea. Never have gone with stock pads, like to play too much.
Old 08-14-2007, 05:27 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Got some for me?
Old 08-14-2007, 06:31 PM   #8
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
You could go WRX brakes up front, and match it with the H6 upgrade in the back.
Huffer is offline   Reply With Quote
Old 08-14-2007, 11:23 PM   #9
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
His wheels are 15s last time I checked.
Old 08-15-2007, 10:17 PM   #10
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
sounds like he needs to buy some 16'' wrx rims. will the h-6 rears fit under the 16'' oem wrx rims?....cant remember.
~Josh~
Old 08-15-2007, 11:22 PM   #11
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yes, they should, seeing how they fit under other stock Subaru 16" rims. Don't think we had 17s available on anything until the STi in 04. (maybe on the WRX as an extra option)
Old 08-16-2007, 11:47 AM   #12
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I'm upgrading my Legacy to '02 WRX brakes f/r and will have the stock GT bits left over. Rotors are good, calipers work fine.
omahasubaru is offline   Reply With Quote
Old 08-19-2007, 06:35 PM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
My suggestion would be to read this thread:
http://forums.nasioc.com/forums/show....php?t=1320302
And then upgrade the rears only to the 290mm single pots found on the BE/BHs, fresh DOT4 fluid+pads(same material f+r) and possibly ss lines.
ss
subysouth is offline   Reply With Quote
Which Brake MC for Legacy GT Brake upgrade not8player Brakes, Steering & Suspension 3 05-14-2009 05:29 PM
96 Legacy AWD Brake Light pmaryan Brakes, Steering & Suspension 1 08-22-2007 12:43 PM
where to get 96 legacy rear brake shoes for e brake? 2slofouru Brakes, Steering & Suspension 6 07-17-2006 01:20 AM
96 Legacy front brake calipers pistoffjstr Private 'Wanted' Classifieds 8 10-08-2005 03:52 PM
96 legacy wagon GT coolmanlogan1 Newbies & FAQs 4 09-21-2003 12:43 AM
