Old 08-14-2007, 09:38 PM   #1
van8978
Member#: 132560
Default Hood Scoop Cover
Hey i have a 98 legacy gt and for some reason there is a cover on my hood scoop. would it damage the car anyway if i removed the cover giving the engine more cooling?
van8978 is offline   Reply With Quote
Old 08-14-2007, 09:55 PM   #2
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
US-made Legacies come with the hood scoop insert as standard. It's there because every other country came with a turbo-charged version of the engine. The hood scoop would be where the intercooler would be.
If you remove the hood scoop insert, you run the risk of too much water being forced into the engine bay.
Huffer is offline   Reply With Quote
Old 08-14-2007, 11:22 PM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Which really isn't a risk at all
You may want to freshen some electrical wires with di-electric grease in case a rainstorm really floods the engine, but I doubt you'll really run into any problems. The intake won't be effected by this, and that's where you really want to be concerned about water flooding.
Wiscon_Mark is offline   Reply With Quote
Old 08-15-2007, 12:18 AM   #4
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Well, how much water would actually come through? It's not that big of an opening.
Frogsthatmoo is offline   Reply With Quote
Old 08-15-2007, 12:44 AM   #5
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Not enough water to worry (if you keep your engine properly maintained). I use cleaners and sealers on the engine connections as part of my routine maintenance. There are special sprays you can buy specifically made for cleaning and weather-proofing electrical connections... Your only problem may be that it supposedly rains a ton in seattle, and the more water that gets in, the better chance it has of working its way into elect connects...
janikphoto is offline   Reply With Quote
Old 08-15-2007, 01:07 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Why do you think removing that block-off plate would give the engine more cooling, and why do you think the engine needs more cooling?
Old 08-15-2007, 02:10 AM   #7
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
I have been running without that hood scoop insert now for 4 years. No water problems. When I detail my engine I spray it right down also.
Russell Rogers is offline   Reply With Quote
Old 08-15-2007, 09:55 AM   #8
janikphoto
Member#: 10471
2000 BMW Z3
Yeah, and I should've mentioned earlier that I spray on a can or two of engine degreaser once a year, then hose it off. But, like I said above, I always use the proper greases and sprays on my connections to keep them sealed from moisture. A bit of water won't hurt your engine at all...
Old 08-15-2007, 10:54 AM   #9
spdracr00
Member#: 65823
1996 Impreza L
Red
hehe, it does.. i ran my outback without that plate for almost 2 years.. after an autocross or rallycross you could see all the heat waves just flowing up and out of that scoop.
spdracr00 is offline   Reply With Quote
Old 08-15-2007, 11:16 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
So your coolant and oil temperatures were different?
How about when you're actually driving and you're forcing air into the engine compartment behind the radiator, thereby reducing the differential pressure across the radiator and reducing airflow? Was it running cooler then?
Old 08-15-2007, 11:28 AM   #11
spdracr00
Member#: 65823
1996 Impreza L
Red
after i blew my HG my temp guage never really moved when i had the cover plate of or off. i mostly just used it for venting. but if you look at the SS's they have a scoop, but no intercooler just a chimney but that doesnt seal with the scoop either. like i said i did mine just to help with venting after i race. i also noticed that when i was driving in the snow up to the mountains it stayed cooler than it used to, i could also see the heat rising out of the engine bay all the way up timberline road.
Old 08-15-2007, 11:44 AM   #12
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
What tools do you need to remove this cover?
Old 08-15-2007, 12:03 PM   #13
janikphoto
Member#: 10471
2000 BMW Z3
...i could also see the heat rising out of the engine bay all the way up timberline road.
Heck, I'd remove it just for that effect.
Old 08-16-2007, 01:17 AM   #14
van8978
Member#: 132560
there are screws found around the plate, you can just bend the black cover a little bit and see it easily, i think there are about 6 screws and after those are out the plate is good to be taken off.
Old 08-16-2007, 11:33 AM   #15
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
There are 6 metal screws and a plastic screw that I had to tear off because it was stripped out. But it was rather simple (and I am amazed). I've wanted to do this for so long, but I thought I had to cut stuff.
Just as a tip, it's easier to puncture the heat shield than try and bending it back. It tears really easily and bending it did more noticeable damage than pushing the screw driver straight through it.
Sold 04wrxGreg Exterior/Styling 3 06-13-2010 09:19 PM
Where can you get hood scoop covers? Matt_Chan Vancouver Impreza Club Forum -- VIC 2 11-16-2005 12:38 AM
('93-'01) doo-hickey holding hood scoop cover plate dingo dave Impreza Forum 3 05-26-2003 09:46 PM
('93-'01) Hood scoop cover removal ImprezaRS2000 Impreza Forum 10 07-09-2001 03:56 PM
('93-'01) How to remove hood scoop cover? popnGEAR Impreza Forum 2 05-06-2001 05:23 PM
