Old 08-14-2007, 10:23 PM   #1
Ketchup
Member#: 62373
08 Mazdaspeed3
Sonlight Silver
Question MY04 how to replace the low-beam bulb?
Hi all.
I can't figure out how to replace the bulb!
Any help?
Thanks a bunch!
Ketchup is offline   Reply With Quote
Old 08-14-2007, 11:26 PM   #2
Ketchup
Member#: 62373
08 Mazdaspeed3
Sonlight Silver
I did it.
Turn the big cover by tapping on the flange then pop the spring off.
Old 08-15-2007, 11:31 AM   #3
drummerRS2505
Member#: 111331
2005 Impreza 2.5 RS
^^ yeah what he said. remove the black cap (righty tighty lefty losey) then remove the red wire off the bulb. then pop the spring off and remove the bulb. install new bulb (DO NOT TOUCH GLASS WITH YOUR FINGERS) there are a couple holes/tabs you can see by looking in the front of the lens of the headlight to make sure that you lined up the bulb correctly. attach the spring clip back. put on the red wire and install the cap. should be good to go!
LOW- H1
HIGH- 9005
drummerRS2505 is offline   Reply With Quote
Best type of bulbs to replace the low beams on a 09 WRX? KAT_Ayanami Electrical & Lighting 8 01-04-2010 10:24 AM
How to separate high/low beam reflectors from headlight housing? Please help wrxstic Interior & Exterior Modification 0 07-19-2008 10:29 AM
driving light MY04, how to replace bulb dogWagon Electrical & Lighting 1 06-10-2004 07:39 PM
How to change the Low Beam bulbs by yourself? faiwu STi Forum Archive 0 06-30-2003 07:26 PM
What are the low beam bulbs on Morette's for 02WRX? Woodywayne Interior & Exterior Modification 2 10-18-2001 02:52 PM
