Old 08-15-2007, 07:20 AM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default "Do your own alignment": Supersticky
Alignment Thread:
http://forums.nasioc.com/forums/showthread.php?t=645484
HowTo: 4 wheel alignment (toe and thrust angle)
http://forums.nasioc.com/forums/show....php?t=1093484
Camber gauge information
http://forums.nasioc.com/forums/show....php?t=1691534
I bet $5 that there is more that needs to go here
Old 08-15-2007, 07:47 AM   #2
noboost4u
Member#: 126442
My car is slower
than your car
Couldn't take all that mess up there anymore Jon? Excellent work.
Consolodation FTW!
noboost4u is offline   Reply With Quote
Old 08-15-2007, 12:49 PM   #3
kingbeann
Member#: 99594
2002 WRX Wagon
WR Blue
Originally Posted by ButtDyno View Post
Alignment Thread:
Between these two you have enough to measure and adjust camber, toe, and thrust angle with minimal expense.
kingbeann is offline   Reply With Quote
Old 08-24-2007, 05:44 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I made a diagram of how the camber bolt works since it seems to come up so often and didn't see anything similar in my 30 seconds of browsing. Maybe you want to edit it into a post somewhere?
jamal is offline   Reply With Quote
Old 04-08-2008, 08:28 PM   #5
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
One of the things that need to be added to this thread is the stock aligment numbers for the differnt models.
AbACUZ is offline   Reply With Quote
Old 04-21-2008, 02:25 PM   #6
AbACUZ
Member#: 101898
THIS are the stock aligment figures of a :
(not necesarly represent the figures that are specified in the manual)
http://forums.nasioc.com/forums/show....php?t=1494300
2008 STI .
Front:
Camber left/right: -0.59 / -0.76
Caster left/right: 6.41 / 6.11
Toe left/right: -0.05 / -0.09
Total Toe: -0.14
Rear:
Camber left/right: -1.12 / -1.45
Toe left/right: +0.02 / +0.05
Total Toe: +0.07
Thrust Angle: -0.02
Old 04-21-2008, 02:56 PM   #7
AbACUZ
Member#: 101898
LOOKIE LOOKIE whats eyes phounds and mades fors us :P
2005 SUBARU alignment Specs
Old 07-07-2008, 08:53 PM   #8
PuTTeR380
Member#: 184053
2011 Wrx sedan
black
o really
PuTTeR380 is offline   Reply With Quote
Old 09-26-2008, 11:59 AM   #9
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Nice! I think i may save myself 80.00 and do it myself.
Hayaboosted is offline   Reply With Quote
Old 10-26-2008, 04:30 PM   #10
Ryanpm939
Member#: 158177
2002 Impreza WRX
World Rally Blue
i did this on my friends scooby and it turned out pretty well...
Ryanpm939 is offline   Reply With Quote
Old 12-14-2008, 08:00 PM   #11
96imprezaBeat
Member#: 197470
niceness
96imprezaBeat is offline   Reply With Quote
Old 12-14-2008, 08:00 PM   #12
96imprezaBeat
Member#: 197470
i need to ask a question to you forum peeps then im gonna try that
Old 02-04-2009, 01:32 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
How do you guys reach the toe adjusters with the car on the ground and no lift available?
chimchimm5 is offline   Reply With Quote
Old 02-04-2009, 01:44 PM   #14
wrxracer519
Member#: 149890
09 Forester
Green
i am gonna have to read all this when i get home from work. Cant wait to do my own alignment. I need one bad.
wrxracer519 is offline   Reply With Quote
Old 02-12-2009, 04:11 PM   #15
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
-snip
chazly413 is offline   Reply With Quote
Old 02-17-2009, 10:09 PM   #16
whereswardo
Member#: 201304
2005 Sti
slippery silver
Default Great allignment in san Diego
Jae Lee has a place called Mirage and they do excellent corner balancing race allignments. miramar
whereswardo is offline   Reply With Quote
Old 03-03-2009, 06:20 PM   #17
Butt Dyno
Member#: 17301
is the "dark side"
Added camber gauge thread to the first post.
Thanks flyboymike!
Old 04-11-2009, 10:34 PM   #18
Suby0r-nothing
Member#: 208319
1993 Impreza & 03WRX
Does this work on all model years?
Suby0r-nothing is offline   Reply With Quote
Old 04-22-2009, 08:49 PM   #19
cordeiroa
Member#: 209412
2005 subaru STi
World Rally Blue
Thanks for all the info took some time but it worked.
cordeiroa is offline   Reply With Quote
Old 05-09-2009, 03:46 AM   #20
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I have been doing alignments over 4 years on all of my vehicles in my driveway. I use 2 4 foot levels, 4 bungee cords (to attach levels to the wheels) a tape measure and a bit of common sense.
I can do an alignment better than any laser guided setup.
My steering is tight and I have nearly zero tire wear.
2.5 turbo hyped is offline   Reply With Quote
Old 05-21-2009, 07:33 PM   #21
sooblover
Member#: 132551
04 FXT
so approximately how much does each mark on the camber bolt represent?
sooblover is offline   Reply With Quote
Old 06-13-2009, 08:57 AM   #22
impreza2.0
Member#: 196374
Default Coilover, does this apply?
I get the point that we can do the 3 major points of wheel alignment, but does anyone have a trick for corner-balancing a coilover setup, or should I just drop the $200 for that and a laser alignment? I won't be changing ride height, I just want good traction and even wear (and for my transmission to suffer as little as possible from the stiffness).
impreza2.0 is offline   Reply With Quote
Old 10-09-2009, 10:36 PM   #23
kurtdaniel
Member#: 156150
tnx for the diy..it saved us lots of money collectively..now,,can anyone share to a diy for fan clutch replacement? I need it badly..
kurtdaniel is offline   Reply With Quote
Old 10-26-2009, 03:37 PM   #24
pBiffle
Member#: 148724
2006 Impreza
Garnet (Red)
Niiiiiiice, been meaning to try this for a while, this'll make it much easier on my brain organ.
pBiffle is offline   Reply With Quote
Old 12-24-2009, 11:05 AM   #25
Jerry_NJ
Member#: 233288
2004 Forester
When is alignment needed determines, I mean besides having the dealer put it on the "alignment machine" and making measurements?
If the tire wear is uniform and the car tracks well on a level paved street/highway then no alignment is needed. Is this a sufficient test for alignment need? Of course seeing the tires worn out due to alignment problems is costly too... but in my case my Forester has abouot 40K miles and I've replaced the tires. The original tires do not show uneven wear.
Jerry_NJ is offline   Reply With Quote
HAHA! OT sez, "Do your own homework, loser!" Strider Off-Topic 3 11-13-2007 04:31 PM
The ultimate tax shelter: Owning your own business fuzzycuffs Off-Topic 78 02-19-2007 09:59 AM
You think "Do your chain hang low" is bad...get a load of this: BigWrecKs Off-Topic 28 09-11-2006 05:36 PM
own your own repair shop credit xtc Tri-State Area Forum 16 02-13-2002 08:54 PM
('93-'01) Do not have your own brain? Get one for your battery then. 25psi Impreza Forum 3 04-16-2001 10:38 AM
