Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 08-25-2016, 11:45 AM   #1
Member#: 29440
2015 WRX
Default Alignment Question
About a month ago, I had RCE Yellows installed on my 2015 WRX. The shop sent the car out to get the alignment done. Everything was good for 2 weeks, and the car started pulling to the right if I wasn't holding the steering wheel straight. Had the car re-aligned yesterday, and they said the driver rear and passenger front were wrong. He reset everything to the way it should be and its still pulling to the right. If my alignment is correct, what do I look at next?
DILLIGAF Racing is offline   Reply With Quote
Old 08-26-2016, 11:37 AM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Are you sure the alignment isn't the issue but the crown in the road?
Even with a correct alignment, a car can still pull right or left depending on which way the road is crowned. Roads, and I am not saying every road in the world, are crowned to aid in water run-off.
Other than that, either you went to two different shops who do not know how to do an alignment correctly, or they didn't tighten everything up correctly, or you have damaged suspension pieces that either they were too clueless to identify or ignored.
Samurai Jack is online now   Reply With Quote
Old 08-26-2016, 11:47 AM   #3
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Did you hit a large bump or pot hole?
