Old 04-09-2008, 08:33 AM   #1
nwindyz
Member#: 120644
2004 Faux STI
JBP, Cobb Staged
Default Perrin's Anti Lift Kit ???
I recently purchased the PSRS (aka antilift kit) and was woundering if I actually needed a shop press to install these? It says you do in the prep area but, nothing in the actual instructions. Mine came assembled already in the box greased up and all... So do I need a press is my question? Thanks Alot
nwindyz is offline   Reply With Quote
Old 04-09-2008, 09:54 AM   #2
nwindyz
Member#: 120644
2004 Faux STI
JBP, Cobb Staged
bump!
Old 04-09-2008, 10:52 AM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I thought the ALK was attached with bolts and it was only when you were doing bushings-only (like Whiteline's KCA375) that you needed to use a press.
Butt Dyno is offline   Reply With Quote
Old 04-09-2008, 11:22 AM   #4
Paranoid Fabrications
Member#: 140712
2008 WRX STI
Thats what i thought also. you should be able to just bolt this on.
Shane
Paranoid Fabrications is offline   Reply With Quote
Old 04-09-2008, 11:29 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You need a press for the 08 version. Did you order the right one?
Tony
Old 04-09-2008, 11:35 AM   #6
nwindyz
Member#: 120644
2004 Faux STI
JBP, Cobb Staged
Yes, I did order the right one. It just stated in the instructions that a press was needed, did not say for install or removal or factory bushings or Perrins?
Seems I only needed a press to press the sleeve and the hard bushings together on the ALK.;
(FS) Whiteline Anti-lift kit, Roll center kit, Swaybars (F,R) GR STI m3evobr Suspension/Brakes/Handling 11 05-07-2010 09:19 AM
To Anti-Lift Kit..? Or, Not to Anti-Lift..? PSRS (+Video) krylon General Community 45 11-07-2009 10:10 PM
VA: Whiteline Anti Lift Kit w/ caster kit richy_21 Suspension/Brakes/Handling 26 09-22-2007 12:25 PM
NE1 want a Whitline Anti-Lift Kit? rrsettgast Bay Area Impreza Club Forum -- BAIC 8 06-13-2000 05:59 AM
anti lift kit greg Mid West Subaru Owners Club Forum -- MWSOC 6 05-21-2000 10:02 PM
