Old 08-15-2007, 05:39 PM   #1
thorne
Member#: 130063
2003 WRX
Silb
Default WOT running way rich.
I have googled, I've searched the forums. I've even talked to a tuner. Everyone seems stumped.
So heres the car
2003 WRX 2.0
PNP stock turbo
up/ddwn catless
straight pipe after that
resnator mod
T-flip mod (So I can bleed more air off)
Engunity tune
lc-1 wideband
So when I go wide open throttle I go way rich. I also hit knock sometimes which i think could be because of being so rich.
Here is my logs in CSV format including LC-1 Wideband. I've got the target AFR in the range of 11.1-11.5 in the mid range I can post my map also if anyone wants to look at it. It's in engunity.
http://bamb.ohiogaming.net/thorne/wo...way%20rich.csv
thorne is offline   Reply With Quote
Old 08-15-2007, 06:14 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
I would check your intake calibration table and check your learned fuel trims. The logs don't show your car running THAT rich. It's not bad in my opinion.
Zumble is offline   Reply With Quote
Old 08-15-2007, 11:07 PM   #3
thorne
Member#: 130063
2003 WRX
Silb
they are when I was running 11.3 on the same exact fuel map . I am pretty sure its a boost leak now. I flashed back to a way older map that worked flawless and its the same issue. Thats a 3rd gear pass btw. in 4th it goes into the 9's in 5th I let off when it hit 8.5
Old 08-16-2007, 08:51 AM   #4
Zumble
Member#: 34860
2005 Forester CGM
Okay those last few pieces of info do point to boost leak.
Oil issues as well as running way rich? Subpar04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-19-2009 12:02 AM
Running way rich..HELP PLEASE!! White_Rice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-21-2008 01:52 AM
Running Way Too Rich!!! Robert E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 01-20-2004 04:53 PM
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Bay Area Impreza Club Forum -- BAIC 11 08-04-2002 05:32 PM
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-02-2002 10:48 PM
