Old 08-15-2007, 08:43 PM   #1
homer09
Member#: 97100
2002 2.5RS
Midnight Black Pearl
Default where is the idle screw?
there is quite some talk about it on the forum, and someone even posted pics, but they are now broken.
where the hell is this magical idle screw on 2.5NA engine? i know you're not supposed to touch it (service manual warns agaisnt it), but im curious to at least know where it is.
homer09 is offline   Reply With Quote
Old 09-04-2007, 04:37 PM   #2
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
from what I understand if you touch it the ECU would just adjust it back to whats programed in.
SubaruImpreza_power is offline   Reply With Quote
Old 09-04-2007, 10:23 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
What is compelling you to adjust the idle via the idle adjust screw?
How is your car running?
PhilSine is offline   Reply With Quote
Old 09-04-2007, 10:39 PM   #4
homer09
Member#: 97100
2002 2.5RS
i have wild cams, so idle sucks obviously. but i raise it through the ecu to 950rpm without a problem.
the idle screw is just a curiousity thing, i always hear it mentioned, but cannot locate it for the life of me!
Old 09-05-2007, 01:26 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
The idle adjust screw is located on the accelerator cable linkage. Your linkage has two spots for cables to connect to it. The outboard spot is where the cruise control connects to and the inboard one is where the accelerator cable connects to. At the very tip of where the accelerator cable linkage rests when the throttle is closed is a small screw that can be used to adjust the idle. That screw also has a little nut on it that you have to loosen in order to move the screw. Its either a 7mm or 8mm nut (forget off-hand). That nut is there to hold the screw firm once you get done adjusting the screw so don't forget to tighten it back up.
Where is the idle air control valve? Tattoo! Service & Maintenance 3 10-29-2009 10:10 PM
Where does the union screw that has the filter in it go? fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-15-2007 07:54 AM
any one know how long is the adjustable screw at the back on the HKS SSQV BOV starBug Engine Management & Tuning 3 06-04-2004 10:57 PM
any one know how long is the adjustable screw at the back on the HKS SSQV BOV starBug General Community 1 06-02-2004 07:14 PM
Where is the other headlight adjustment screw? hklaine Legacy Forum 3 03-23-2004 11:13 PM
