#51 |
Member#: 62738
Vehicle:2000 RS,5MT,Silver DeltaCams,Borla,Prodrive |
i was wondering if i should get longer pins so that the manifold will be linged up proper, but i think it might be the machinist side of me talking
becasue when i go to install these on my bare block i'm goignt o gasket match it. Richard
#52 |
Member#: 136396
Vehicle:2012 wrx white |
i found the easiest way when installing our triple thick spacers is to put a tiny piece of temporary tape over the edge to hold the top oem gasket in its place. the pin will still hold the bottom oem gasket and the spacer, but its not long enough to hold the top oem gasket. once you have the IM bolts lined up through the new spacers then just peel the little piece of tape off and there ya go.
Justin www.grimmspeed.com |
#53 |
Member#: 62738
sounds great
#54 |
Member#: 136396
sorry guys..i know i was supposed to do an E85 test in a bucket but i got super busy with the ewg kit release. i'm going to stop at the gas station on the way to the shop here and pick up a little gas can and some e85.
i'll bring zee camera too. |
#55 |
Member#: 167703
Vehicle:2005 '05 2.5RS 5MT '10 Forester X Limited |
Posted this over at rs25 but thought it might be helpful here as well for us new-age DBW guys (05+) as it doesn't appear anyone's thoroughly reviewed yet.
Took the time to install both the 8MM phenolic IM spacer and Group A TB spacer over the weekend with the bro (ASE Mech). We tackled the IM spacer first as we knew it was going to be the more difficult of the two spacers to install. Car: '05 (DBW) 2.5RS Sedan w/ Injen CAI, block back Borla/Stromung exhaust, etc. Conservatively tuned with ECUflash. Phenolic IM Spacer Install: Undid the manifold bolts as well as spark plug wires, TB, vacuum lines, etc to make room and clearance installing the spacer. Everything went extremely smooth until we went to remove the EGR tube (exhaust recirculation tube that runs from the driver side header to the bottom of the driver side intake manifold). We initially tried to completely remove the tube but quickly realize we wouldn't be able to get it back on with the added height of the 8mm phenolic spacer. The tube is stainless and extremely stiff, there would literally be no way to get it back on and threaded correctly if the spacer was installed. To make a long story short we removed everything attached to the IM and ended up creating a clamp/crowbar suspension over the front of the car to lift up the manifold by the attached EGR tube. With a few hundred pounds of force (not real precise, but considering our setup it's tough to gage) on the EGR tube it eventually molded and bent up enough to slide the sandwich of two OEM gaskets and the 8MM phenolic spacer into place. After peeling and scraper the old one off (with care not to get anything into the intake port) we slide the spacer on. OKAY, one side done. The passenger side went alot smoother as it was completely free until we tried to slide the 8MM spacer over the pins on the block. The very front pin (closest to radiator) does not allow the 8MM spacer as it tops out at the engine coolant output tube. We did some small modification with a dremel and grinder to allow it to fit. OKAY, second side done. Time = 4 hours. (3 of which was spent reworking the EGR tube.) Difficult install as a result of the pesky EGR tube. Group A TB Spacer: Falcon already hit this product pretty well. Install was straightforward and easy with two sets of hands. Driving Impressions: Reset ECU and allowed to learn up before any serious testing. Noticeable power gains across all RPMs (2000-6200). Torque is greater at lower RPM's, seems to have brought back MOST low-end torque lost through the CAI. Pulls harder above 3500 and is especially noticeable in 3rd and 4th gear. Engine sound seems louder above 3500 as well, seems to change the acoustics of the intake. (for the better in my opinion). Manifold is much cooler as a result of the IM spacer. Haven't tested fuel mileage yet, but I suspect a slight increase as well. Butt-dyno says 3-5HP, another recommended product, minus the install difficulty of the IM spacer. Last edited by LTracer; 02-10-2008 at 08:00 PM. |
#56 | |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Do you have any data (such as before and after MAFv, g/sec, or g/rev, etc) that backs this up or is it pure speculation? Obviously not asking about the temps since you have data for that. |
#57 |
Member#: 167703
Thanks for asking (unlike some I won't get defensive over 'proving' it). Absolutely no data whatsoever aside from noted 'butt-dyno' and temp increase.
Dynos for pre-DBW seems to suggest a 2HP gain from the TB spacer alone: http://www.rs25.com/forums/showthrea...le+Body+Spacer So to clarify for all above made claims my impressions were never validated by dyno or time test. Intake temp decreased 10-15 holding ambient temp constant. In hindsight I should have logged and saved more parameters than intake temp. I 'swear' I can feel the difference though. (I'll flame myself now so no one else does). Bottomline: highly recommended this product (and phenolic IM) to any DBW owner with the technical expertise to correctly install (or find a reputable shop that will). Really though the TBS isn't that difficult of an install... |
#58 |
Member#: 136396
#59 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
Go check out a dyno chart for a TWE EL header...
#60 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Holy quote from the past, Batman!
#61 | |
Member#: 120
AKIC
Those graphs are pretty much make believe as far as I can tell.Anyway, interesting to see the difference in intake air charge that you measured, LT. Where is the IAT sensor actually located? I would guess it's up towards the throttle body, in which case the temperature difference at the intake port (after the air has flown all the way through the intake manifold) would be even greater. Pat |
#62 |
Member#: 168951
Vehicle:1999 Legacy Outback Black |
I will probably be rebuilding my '99 2.5 DOHC, it is stock from a Legacy Outback; I was trying to figure out if it would make a noticeable difference to install these spacers with my engine or if one would only really feel the difference with a turbo and/or mods and tuning?
Thanks in advance. |
#63 |
Member#: 136396
the IAT sensor is located in the MAF..which sucks because you cant use it to get the temp difference reading of the phenolic pieces because they are after the fact.
#64 |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
#65 | |
Member#: 167703
Seeing as Grimm discounted my intake temp statement (IAT is before IM, must have been another variable that I didn't account for...) I swear I did the ambient vs. IAT math correctly. ![]() I think the best way to test temp difference would be us an IR temp. reader on the intake manifold before and after holding everything else as constant as possible. Grimm, didn't you have some numbers written down on the temp improvement gained by the 8MM spacer? |
#66 | |
Member#: 136396
Justin |
| Thread Tools | |
| Display Modes | |
| GrimmSpeed Phenolic Spacers, HiFlow Crosspipe, and more.. | GrimmSpeed | Engine/Power/Exhaust | 8 | 09-27-2007 03:09 PM |
| FS:(So Cal) APS Inlet, Grimmspeed Phenolic Spacers, Cusco Heatshield and RS-R DP | Drag-On | Engine/Power/Exhaust | 18 | 08-12-2007 02:05 PM |
| Grimmspeed Phenolic Spacers | snwman | Engine/Power/Exhaust | 7 | 07-17-2007 06:18 PM |
| GrimmSpeed Phenolic Spacers | GrimmSpeed | MWSOC Vendor Classifieds | 0 | 07-09-2007 10:39 PM |
| FS MN: Grimmspeed Phenolic Spacers + Gaskets | p@rwrx | Engine/Power/Exhaust | 5 | 07-05-2007 11:54 AM |
