Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 08-16-2007, 05:30 PM   #1
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
Default Losing Coolant
So this started all of a sudden while I was driving down the freeway to work one morning. My car suddenly ran hot and I had to turn on the heat and limp it home while running in the upper part of my temp guage. I figured i hit an air pocket and changed the coolant, it did the same thing again a few days later, I looked and no coolant in the res. I had my friend who is a subaru mechanic look at it and said my coolant res was broken at the filler neck. Fine got a new one. Still happened. This is what happens, when the engine is up to operating temp and after driving it for a few min i pop the hood and take a look, it seems my coolant is dissapearing out of the overflow its like cooland gushes out of it when I shut off the engine and the hose going into the overflow is boiling out steam. I have looked over the car up and down and I dont see ANY leaks, steam or that sweet coolant smell. Just gushing out the overflow. Does anyone have any suggestions on to what my prob might be
04 WRX 50k miles
I've had a 30R on it since it had 15k
RallyBlue is offline   Reply With Quote
Old 08-17-2007, 01:06 AM   #2
austenf740
Member#: 21519
02 WRB WRX
98 RS
Bad radiator cap?
austenf740 is offline   Reply With Quote
Old 08-17-2007, 03:01 AM   #3
kurtdaniel
Member#: 156150
You may be evaporating your water out of your coolant causing level to be lower. I recommend flushing your coolant and refill it with new coolant and see what that does. Check the drain on the radiator and all your hose connections. Also check your heater core it is up under the dash on the passenger side and see if it is leaking an easy way to tell is if the passenger side floor is wet. Or if you have a sweet smell in your cab of your truck. You know the smell of hot coolant. That is what I recommend. But someone else may have more info on this.
kurtdaniel is offline   Reply With Quote
Old 08-17-2007, 03:43 AM   #4
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
Well I have checked everything stated above and nothing helped.
A friend did tell me that it might be a slight headgasket leak, and that a small amount of exhaust is leaking in the coolant jacket, I have been running a 30R rotated turbo at 20 psi on a stock 205 for over 30k so it just might be time
Old 08-17-2007, 11:22 AM   #5
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
If it is boiling out of the tank, Your thermostat is probably stuck closed. That is the exact same thing that happened to me with one of my cars. I replaced it with the Crucial Racing fail safe thermostat that when it breaks, it stays open so it doesnt overheat, and opens earlier.
http://www.crucialracing.com/products/coolsafe.php
StarDogChampion is offline   Reply With Quote
Old 08-17-2007, 11:58 AM   #6
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Likely it's your headgaskets. I have been through it, twice.
linsavy is offline   Reply With Quote
Old 08-17-2007, 06:27 PM   #7
jevera2k
Member#: 133480
2002 Impreza WRX
blue
Mine is doing something similar but my car when it gets hot only one fan is turning on I dont really know if this is nomal, but I will replace the thermostat and let you know what happens then, good luck.
jevera2k is offline   Reply With Quote
Old 08-17-2007, 07:21 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Yeah, classic HG symptoms. Boiling recover tank isn't really boiling, it's combustion gases from the blown HG. I'd get it checked. They can check the coolant for combustion gases.
Old 08-17-2007, 10:49 PM   #9
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
go to autozone, borrow a coolant leak down tool...pressurize and find out exactly where its gushing out from . otherwise you're just guessing
fastnoypi is offline   Reply With Quote
Old 08-18-2007, 02:55 PM   #10
WRXShawn
Member#: 35742
2002 PPG + FPGreen
I'm having the same issues. I've idled the car and kept the coolant resevoir topped, but at a certain temp, it starts bubbling from one of the lines (rad to coolant resevoir) and I have to put the cap on. Then the overflow fills up and overflows. If I turn the engine off, the overflow will fairly quickly empty out. WTF?
I'm going to Subaru on Monday to test for exhaust gases in the coolant.
WRXShawn is offline   Reply With Quote
Mystery Losing Coolant - Culprit Found denn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-01-2009 07:25 PM
2.5 RS Airlock/losing coolant? monkeyonahill Normally Aspirated Powertrain 1 12-23-2008 03:17 AM
Losing/burning coolant occasional smoking turbo ctrexer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-25-2003 04:20 PM
Losing coolant- major sign of problems to come? RSarte Service & Maintenance 6 11-22-2002 04:23 PM
ah losing coolant!!!! Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 14 08-27-2002 09:27 PM
