Old 08-16-2007, 05:51 PM   #1
Dragonbreak
Member#: 96860
2006 STI
Default Would it be safe to turn the car on and move the wheels while on jack stands?
Topic title ..
Dragonbreak is offline   Reply With Quote
Old 08-16-2007, 07:07 PM   #2
REX8
Member#: 24038
Not really seeing a huge issue. When it hits the ground, if it falls, it will stall. On second thought...make sure the car isn't pointed at anything just in case. Be careful.
Old 08-16-2007, 07:18 PM   #3
lev98
Member#: 140529
01 Ferrari 360 spy
My guess would be no the rotational mass of the wheels would probably knock the car off the stands.
lev98 is offline   Reply With Quote
Old 08-16-2007, 07:21 PM   #4
jet8300
Member#: 115844
02 WRX
99 Forester
Are you talking about turning the car on, and turning the steering wheel? Or putting it in gear and letting it go? I have never done either but the former should probably be safe. I don't know about the latter. Probably would not try that one. It wouldn't take much at all to get the wheels spinning like mad and like lev98 said the rotational mass might vibrate that thing right off of there.
jet8300 is offline   Reply With Quote
Old 08-16-2007, 07:27 PM   #5
Dragonbreak
Member#: 96860
2006 STI
Haha! Wow, I just meant to turn the wheel while it's in the air. Not, put it in 1st! lol wow. haha thanks guys.
Old 08-16-2007, 07:31 PM   #6
BonesXMahones
Member#: 56425
Yes, you should be just fine. I do it all the time to make getting to front brake bolts easier and it is also in the recommended procedure for bleeding power steering systems. Naturally, just make sure your stands are at the proper locations and not under the suspension or something silly like that.
BonesXMahones is offline   Reply With Quote
Old 08-16-2007, 07:42 PM   #7
jasonallenross
Member#: 125978
2002 WRX Wagon
Note that you likely don't need to actually turn the car on to turn the wheels when it's on the stand, you just need to turn the key far enough to free the steering lock and it will turn fine since there is no weight on the wheels.
I've done this a lot for dealing with brakes, it makes the job much easier when you get more room for the ratchets and wrenches. You don't need to do it when bleeding the brakes, but for a pad replacement, sure.
jasonallenross is offline   Reply With Quote
Old 08-16-2007, 08:33 PM   #8
snowman87
Member#: 124021
'11 Tacoma
Silverish
^winnar
snowman87 is offline   Reply With Quote
Old 08-16-2007, 08:42 PM   #9
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I start cars that are on jack stands all the time. Easy way to check for exh leaks. You can put it in gear as well, just dont go ripping on it then standing on the brakes. Its perfectly safe if you arent a bonehead. (meaning you have the car on the stands PROPERLY, and arent an idiot about it when its running in the air)
Defiant Autospeed is offline   Reply With Quote
Old 08-16-2007, 08:51 PM   #10
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I've put it in gear and let the engine spin the wheels while on stands. I had a grinding noise while moving and this made it easy to locate.
garface is offline   Reply With Quote
Old 08-16-2007, 09:39 PM   #11
Daniel son
Member#: 103499
90's gc/bc
rusty?
Maybe backing up the jackstands with something a little more ...welll more would be good (think 12"by12" fir under many parts of undercarriage)
Daniel son is offline   Reply With Quote
Old 08-16-2007, 10:51 PM   #12
REX8
Member#: 24038
What? Think about that. Let me know the magnitude of force from the inertia and in what direction it is being applied, then tell us how that would knock the car off the stands.
Old 08-16-2007, 11:38 PM   #13
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
Hmmm... I'm thinking if you get all 4 wheels spinning good and fast, the gyroscopic properties of a rotating mass will actually help stabilize the car. Until you turn the front wheels and introduce precession, thus possibly knocking the car down.
So, um, yeah. Turn the wheels while on stands. Just be carefull.
reddoak is offline   Reply With Quote
Old 08-17-2007, 03:33 AM   #14
mrbalwrx
Member#: 53502
2012 WRX
Read the topic title and knew I'd get a laugh!!
Steering wheel turning is A O K.
Now which of you is going to test the wheel inertia issue? I know one of you is drinking right now and got really curious!!! lol
mrbalwrx is offline   Reply With Quote
Would this be safe to run for a little while? DJS_02_WRX Newbies & FAQs 53 11-12-2009 11:16 PM
would it be safe to install now or wait for a tune? darkinc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 11-04-2008 06:39 PM
Would it be ok to only use two channels on a three channel amp? dickpainter Car Audio, Video & Security 4 04-08-2008 05:01 PM
would it be bad to cap the PCV? subiekid Subaru Conversions 3 01-02-2004 08:11 PM
would it be possible to swap the roof on a 2000 GC8? Chris Lawson General Community 12 01-29-2003 10:11 AM
