Old 08-17-2007, 09:58 AM   #1
turbobird14
Member#: 147780
2002 Bugeye WRX
Flippin Awesome
Default WRX Oil Pressure???
ok... i just got the car and maybe i have the "new car paranoia" but there is an autometer sport comp oil pressure gauge installed and i was wondering what is the oil pressure supposed to be at? at idle and while driving..... the reason for the question is that the needle is bouncing around 25-40 psi at idle while warmed up but right when you start the car its pegged past 100 psi....and when im accelerating its at anywhere beetween 80 psi and past 100psi not boosting at all ( 0 vac boost... between 14.4-15.2 wideband O2) do you think there is something wrong with the gauge.... like a line is pinched or restricted....or what about the oil pressure sending unit?? im starting to freek out a little but i cant think of what would cause high oil pressure.... or if its normal? i dont know so help me out
turbobird14 is offline   Reply With Quote
Old 08-17-2007, 10:17 AM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....readings will vary depending on the gauge and it's accuracy. However, the pressures you are seeing seem to be in line with what most will see (myself included). The needle will be ~100 PSI at start up and eventually settle to ~25-30 @ idle and ~75-80 @ speed once the engine is fully warm. A search will reveal several threads on the subject......
Kean is offline   Reply With Quote
Old 08-17-2007, 11:58 AM   #3
turbobird14
Member#: 147780
2002 Bugeye WRX
Flippin Awesome
hey thanks i noticed today on the way to work on highway it was steady at 80 psi and idle at about 35 psi... just wondering because gauge is maxed out at 100.... like i said i still have paranoia setting in...thanks alot
Old 08-17-2007, 01:14 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
....no problem.
Old 08-17-2007, 02:35 PM   #5
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
Oil pressure has nothing to do with vacuum/boost, it's driven by engine speed. It should be 90+ cold and drop as it warms up to about 30 at idle. Numbers all look normal.
woody06967 is offline   Reply With Quote
Old 08-17-2007, 04:25 PM   #6
Feign
Member#: 68604
06 STi
Yep, you're fine. When they are anywhere other than what you're used to seeing in the future then your paranoia can kick into high gear.
Feign is offline   Reply With Quote
Old 08-18-2007, 12:18 PM   #7
turbobird14
Member#: 147780
2002 Bugeye WRX
Flippin Awesome
haha...and if it happens im sure it will
Old 08-30-2007, 12:47 PM   #8
LewisWORX
Member#: 63001
02 WRX Stg. II PnP
I see ~75 psi cold, 25psi at warm idle and around 75 psi when warm as rpms build. Is there some reason that I wouldn't see 100 psi when cold?? My oil level is fine. Sender relocated from block plug using a kit. Any ideas? I use Mobil 1 high milage 10w40.
LewisWORX is offline   Reply With Quote
Old 08-30-2007, 10:42 PM   #9
Newbuggy
Member#: 152042
Unhappy
i think i may have just finished off my motor i got my car a week ago and i was reading 10 psi at idle 25 psi at cuise and under aceleration. so could these numbers be the reason why my motor may have blew?
Newbuggy is offline   Reply With Quote
Old 08-31-2007, 12:17 AM   #10
MasterKwan
Member#: 98961
2003 WRX
Did it have any oil in it? I'd say yes to the question. It probably means the engine was done before you even bought it. Was that the pressure it was running when you bought it? Is so, that should have been a HUGE red flag.
02 WRX Oil Pressure Problem. HVAAJA21 Newbies & FAQs 5 12-06-2011 06:13 PM
WTB: Door trigger and wrx oil pressur sensor ImprezaRSfan! Private 'Wanted' Classifieds 0 07-27-2005 10:41 PM
WRX oil pressure? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-19-2004 05:11 PM
Rs vs wrx oil pressure DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-09-2002 02:21 AM
